Controller won’t link
319 5 2-19 14:29
Westy-1
Flight distance : 34813 ft
For some reason I am unable to link my Mavic 3 classic with the controller after using it numerous times. The controller also has a solid red light. I've tried all the methods suggested and nothing seems to work. Any ideas?
2-19 14:29
DJI Diana
Flight distance : 2408 ft
Hi, there. We are sorry to know about this issue you've encountered. Could you please confirm which remote controller you are using with your Mavic 3 Classic? Also, have you tried updating and refreshing the device's firmware? Could you please confirm whether you have already attempted linking using the button combinations? We hope to hear from you. Many thanks.
2-19 16:35
Alan West
DJI Diana Posted at 2-19 16:35
I have the remote with the built in screen.
What is the button combination please?
2-19 23:49
DJI Wanda
Alan West Posted at 2-19 23:49
Hi there, please try as follows, and see if it works.
Method 1: Using Button Combinations
1. Power on the aircraft and the remote controller.
2. Press the C1, C2, and Record buttons simultaneously until the status LED blinks blue and the remote controller beeps.
3. Press and hold the power button of the aircraft for more than four seconds. The aircraft beeps twice after a short beep, and its battery level LEDs blink in sequence to indicate it is ready to link. The remote controller will beep twice, and its status LED will turn solid green to indicate linking is successful.
Method 2: Using DJI Fly
2. Launch DJI Fly, in camera view tap and select Control and then Connect to the Aircraft. During linking, the status LED of the remote controller blinks blue and the remote controller beeps.
Notes:1. Make sure the remote controller is within 0.5 m of the aircraft during linking.
2. Turn off the Bluetooth and Wi-Fi of the remote controller for optimal video transmission.
2-20 00:01
Alan West
DJI Wanda Posted at 2-20 00:01
Tried all these options but still won't connect
2-20 06:04
DJI Diana
Alan West Posted at 2-20 06:04
Thank you for the update. For us to further check, could you please provide us with a video showing the operation so we can properly address it and provide the best solution? Please save it to the shareable link in Dropbox or Google Drive. Thank you for your cooperation.
2-20 13:26
