Gimbal attitude error 40027 at startup
12
16726 45 2022-11-28
GRID AGENCIA Posted at 2-8 06:13
I have the same problem, I updated according to the tutorial. But my problem was not resolved. Does anyone have any other solution?
Hi there. Is it the same 40027? If you already tried updating the firmware or refreshing it using the DJI Assistant 2, please try calibrating the gimbal. Have a nice day.
2-9 00:42
djiuser_Sio9S2UAhdiY
Flight distance : 22959 ft
Philippines
hi idk how to fix this error last time my brother borrow my drone and i think he crash it and i fix the propellers and this error showed up and idk how to fix this so please help me my drone is dji 4 pro “possible gimbal error. (Code:40027
3-4 20:34
djiuser_Sio9S2UAhdiY Posted at 3-4 20:34
Hi there. The mounting angle of the DJI Mini 3 Pro gimbal rubber damper might have been changed after the crash resulting in the previous calibration parameters of the gimbal becoming incompatible, which causes the gimbal attitude to become inaccurate during flight. You can try calibrating the gimbal to fix this. However, as mentioned it crashed, for flight safety, it is more advisable to send it back to DJI for inspection. You can submit a Repair Request on the DJI website or use this link: https://repair.dji.com/. We appreciate your patience and understanding. Have a great day ahead.
3-4 21:04
djiuser_Qs4WTsHh0ycT
I'm having the same issue. Everything is up to date and I've recalibrated multiple times.
4-27 09:48
djiuser_Qs4WTsHh0ycT Posted at 4-27 09:48
Hi there. Thank you for reaching out. Please send the aircraft back for further diagnosis if the issue persists after calibrating. You can submit a repair request here (https://www.dji.com/global/support). The warranty can be applied depending on the assessment's outcome, including your unit's warranty period. Please feel free to keep us posted if you have further concerns. Have a nice day
4-27 19:24
fansfa87add4
Flight distance : 21017 ft
fans0dba1935 Posted at 2023-2-7 23:45
Hi guys I fixed this 40027 very easy to made … was in my case probably this same is in yours, I was made just wrong calibration on the first page “safety” you have two types of calibration like deon calibration and IMU or something like this, it’s wrong you need to go to second page “camera” there you’ve got just gimbal calibration and that’s it !! Let me know if it’s working
100% you are correct I did the same as you suggested and it worked perfectly DJI get your act together first start your rc2 controller is way slower than the rc1 and I don't think that many four pro handles as well as the many three pro
5-11 05:52
12
