Osmo pocket 3 mic problem
1002 27 2-20 08:22
MET_ME
After connecting the microphone, it only records sound when it hears a voice. If the voice stops, the microphone does not record anything at all, even background sounds. After I start talking again, the recording starts after a second, which causes gaps in the audio track.
2-20 08:22
Hi there, may I ask if you're using the DJI Mic 2 transmitter with Osmo Pocket 3? Could you please provide us with a sample footage of the issue for further confirmation?
2-20 23:48
MET_ME
I'm using the microphone that comes with the Creator Combo kit. Yes, I will provide a sample.
I would like to describe the issue again: when the microphone is slightly moved away or the sound is quiet, the microphone stops picking up sound. It only records sound if speaking loudly and not immediately but after a couple of seconds. However, if audio duplication is enabled separately, then the recording is fine.
https://youtu.be/nxA6mAlqXbA
2-21 07:11
MET_ME Posted at 2-21 07:11
Thank you for providing the video to us. May I know the current firmware version the DJI Mic 2 has? And could you please try to connect the Osmo Pocket 3 and DJI Mic 2 via the USB-C adapter to see if the issue is the same. Please keep us updated.
2-22 04:35
MET_ME
HI current firmware version the TX1-04.02.01.13
If I connect the Osmo Pocket 3 and DJI Mic 2 via the USB-C adapter  it has same problem
2-22 07:26
MET_ME
DJI Susan Posted at 2-22 04:35
Hey, anybody answer me?
2-25 20:37
MET_ME Posted at 2-25 20:37
Hi there, sorry for the late reply. The video seems inaccessible now. Could you please send me the video again and keep it open? We will forward this issue to our engineer for further checking.
2-27 02:16
MET_ME
DJI Mindy Posted at 2-27 02:16
https://youtu.be/jCNld0UiboE
2-27 08:15
MET_ME Posted at 2-27 08:15
Thanks, we will forward it to our engineer for further review and confirmation.
2-28 01:47
MET_ME
DJI Mindy Posted at 2-28 01:47
How many days I should wait?
2-29 06:59
MET_ME Posted at 2-29 06:59
We received an update from our engineer that logs are needed for analysis. Please provide us with the following information:
1) Device log + Mic 2 internal recording file;
2) Please tell us whether Mic 2 has Noise Cancelling turned on and whether live streaming is enabled;
3) May I ask if this issue can be reproduced every time? If so, it is best to re-record a video and then export the device log, Pocket 3 original video and Mic 2 internal recording file.
2-29 22:24
MET_ME
Where I can find  logs on the camera?
3-1 02:42
MET_ME
https://drive.google.com/file/d/1_JNFy3f4k8XB27ZCogfZF0lav2pGNjxL/view?usp=share_link
this is Mic 2 internal recording file;
Noise reduction is turned off during recording, but regardless of whether noise reduction is turned on or not, the error persists
Yes this issue  reproduced every time
3-1 02:48
MET_ME Posted at 3-1 02:42
You can follow the instruction below to export the logs: Insert the microSD card into Osmo Pocket 3. Swipe down from the top of the screen, select Settings, choose Device Info, and then tap Export Log to generate log files.
After logs are exported, connect the device to a computer by using a Type-C cable. To locate the log files, open My Computer and access the microSD card drive (with the corresponding drive letter). From there, navigate to the logs folder.
3-1 05:44
MET_ME Posted at 3-1 02:48
Could you please also provide us with the original video?
3-1 05:45
MET_ME
https://drive.google.com/drive/folders/16kmq9kBDg4KG3LlPXRKj7Sb7Zdg7a7Gi?usp=share_link
The log
https://drive.google.com/drive/folders/1-65umcjX9RbvQ8bYGEos96H4b5e5XRbq?usp=share_link
camera + mic
https://drive.google.com/file/d/1b1m_hwhsZNRgdo2PSHbCco6e5jIkNZgp/view?usp=share_link
it Mic 2 internal recording file;
3-1 18:45
MET_ME Posted at 3-1 18:45
The log
Thank you for the files sharing. We forwarded to our engineer to further check on it.
3-1 23:01
MET_ME
Hi can you tell me how much time it takes?
3-6 05:23
MET_ME Posted at 3-6 05:23
Sorry for the late reply. We've confirmed with our engineer that there may be some issue with the internal recording, we recommend you submit a case through the link below and send it back for furrther diagnosis. http://www.dji.com/support
3-7 01:00
MET_ME
Turkey
Can I come  to service center in Thailand I bought it in Vietnam ? For How many days you will take the camera?
3-7 01:04
MET_ME
Turkey
And what should I choose in the website Online Repair Process? Which country? can you give me more instruction please
3-7 01:10
MET_ME Posted at 3-7 01:04
Please note that DJI does not provide global warranty, customers can obtain warranty service only at a designated DJI repair center in the region where the customer purchased the product. However, depending on part availability, customers can obtain cross-regional repair service at an additional charge. You can also provide us with the serial number for further confirmation.
3-7 01:31
MET_ME
Turkey
serial number 5WTZM1J00218P1
Okay^ ccm you tell me which service center in Thailand can help me with this issue and how much it will cost ?
3-7 01:35
MET_ME Posted at 3-7 01:35
Thanks for the information provided. Upon checking, the unit is a South Korea version. If you want to get it repaired in Thailand, it's needed to send it back for assessment first. After the assessment, you will receive a quotation. We also sent you a PM, you can take a look.
3-7 01:43
MET_ME
Turkey
How many days it can take?
3-7 01:44
MET_ME Posted at 3-7 01:44
This depends on many factors such as shipping time, we recommend you contact the service center for confirmation.
3-7 02:03
MET_ME
Online Repair Process this form I need to fill?
3-7 02:06
MET_ME Posted at 3-7 02:06
Since you're in Thailand, you do not need to fill out an online repair case, you can directly contact the service center I sent to you via PM.
3-7 02:29
