iamvc2k Posted at 3-13 07:46
I use a ronin s gimbal, before it was still able to charge the battery using the phone's charger, now it can't charge the battery anymore, it doesn't say battery is charged.[view_image]
Thank you for the reply, iamvc2k. Please try the steps below:
• Use another charging cable and charger. The charger must meet the corresponding requirements:
Ronin-S: The fast charge meets the QC standard protocols. The power is not higher than 24 W.
• Check whether the charging environment temperature meets the requirements, the recommended charging environment temperature is 5℃ to 40℃.
• Press the battery level button separately to see if the battery level indicators light up or not. If a new battery is being used, it is recommended to charge the battery for at least 10 minutes to wake it up
• If the issue persists after the grip has been detached and reattached, please send your product back. |
