Corrupt Firmware?
350 7 3-16 16:21
fans60b265e8
Flight distance : 434311 ft
My Air 3 is all out of whack. When I boot it up, none of the led lights on the arms turn on. I tried opening DJI Assistant 2 to do a firmware refresh, but it never shows the current firmware, even though the app recognizes the drone as being connected. Turning on the RC2, it asks me to pair it with the Air 3 (even though they’ve previously been paired) Try pairing it to the RC2 by holding the Air 3’s power button down 4 seconds to enter pair mode, but it never beeps to confirm it’s entered pairing mode. Yet the LEDs on the battery cycle to indicate it’s in pair mode. Then the RC2 stops beeping as if they are paired. Very frustrating considering I’ve had very few flights with it and never been close to a crash.
3-16 16:21
DJI Natalia
I apologize for the inconvenience caused by your usage. May I ask you take a video, upload it to the dirve(like google dirve), and send it to me? This way, I can report to our engineers and help you resolve the issue.
Thank you
3-16 20:21
Hi there. Thank you for reaching out and we do apologize for the inconvenience. Please reinstall the DJI Assistant 2 software on your computer and please use the version on the link below. After installing, please try connecting the aircraft to the software and check if you can now see the firmware and update the unit. We courteously ask you to record the operation and upload it to Google Drive then send the link here so we can also check the behavior of the unit.  Also, please connect the RC to the software, update and refresh the firmware then link them. Rest assured that we will do our best to assist you further with this issue. You may refer to the link below on how to properly link the aircraft to the remote controller. Please keep us posted.
DJI Assistant 2 software: https://www.dji.com/global/downl ... sumer-drones-series
Guide on how to link: https://repair.dji.com/help/cont ... &paperDocType=paper
3-16 20:29
fans60b265e8
DJI Natalia Posted at 3-16 20:21
Thank you
Here is a video showing DJI Assistant 2 works fine on the RC2 but does not show a firmware when Air 3 is plugged in.
https://drive.google.com/file/d/1nDjks93qLjqbQQLHvN46inSXEzbi1eDZ/view
3-17 13:08
fans60b265e8
DJI Paladin Posted at 3-16 20:29
DJI Assistant 2 software: https://www.dji.com/global/downloads/softwares/dji-assistant-2-consumer-drones-series
3-17 13:08
DJI Natalia
fans60b265e8 Posted at 3-17 13:08
Hi there.
Do you have another computer available for cross-testing with DJI Assistant 2 and refreshing the firmware? This could be a result of a failed upgrade. Additionally, can you please describe the situation in which this state occurs?
Thank you
3-17 22:29
fans60b265e8
DJI Natalia Posted at 3-17 22:29
Hi there.
Thank you
The video provided was done on a 2nd computer. Both computers I’ve tried have yielded the same result. When I start the drone, none of the LED lights on the arms light up. It will not pair with the RC2. It has never been crashed, never been wet, etc.
3-18 02:30
fans60b265e8 Posted at 3-18 02:30
Hi there, sorry for the late response. If the issue still persists after testing in another computer device, it is recommended to send back for comprehensive check to ensure the long-term usage. You could register through the following link, https://repair.dji.com/, to create a case and send back for further processing. If you need assistance while submitting, you could also contact with our support service http://www.dji.com/support. Thanks.
3-21 02:36
