Heres the problem. If I fly the Mini pro 4 over an open air assembly, I need to have RID on and Prop Guards. If I use the heavier battery with prop guards you have a disclaimer that the collision sensors are disabled and the weight of the aircraft cannot support the bigger battery with the prop guards. If I put just the prop guards on then the weight of the aircraft is still over the 249 grams.
So just selling the accessory puts us over the regulations and requires us to use the RID.
2. DJI Mini 4 Pro does not support obstacle avoidance after installing the propeller guard and cannot actively detour or brake when it senses an obstacle. When using intelligent features, the aircraft will not have obstacle avoidance capability. 3. The aircraft will weigh more than 250 g after installing the propeller guard. Always carefully check and abide by local laws and regulations. If required, obtain the necessary approval and clearance from the related government agencies before flying. 4. Do not use the Intelligent Flight Battery Plus after installing the propeller guard. Otherwise, the weight will overload the drone’s capacity, and flight safety cannot be guaranteed.
