Bs65 intelligent battery station
1228 9 3-26 15:35
that other drone guy
We recently purchased an m350 rtk with th bs65 intelligent battery station. This system is pretty new and has never been used. I was trying to charge the tb65 and wb37 for the first time, but the battery charger will not charge these batteries. There seem to be stuck on waiting mode, they just show the solid yellow LED lights. If i connect the controller to the battery station there is an error that pops up for the battery station : 'Power supply module not recognised'. i have tried updating firmware, downgrading, refreshing, basically all the firmware tricks and nothing works. Is there anyone who can help with this issue? Stuck in project and thats the only available charger. Any help is greatly appreciated!
3-26 15:35
Hi there, thank you for reaching out. In order to better to assistance, would you please provide us a video recording about the charging operation? We will help you to double-check, thanks.
3-26 20:15
DJI Thor Posted at 3-26 20:15
Hello Mr Odinson. Please see the pictures below:
3-27 04:23
This is what it looks on the interface, and the error it gives
3-27 04:24
LV_Forestry
Flight distance : 4726654 ft
Latvia
I had the same error when using the charging station on a 220V on-board network that was apparently not powerful enough.  On a 220V 20A domestic network, no more problems.
3-27 04:46
LV_Forestry Posted at 3-27 04:46
Thank you for this, so you think it might be a power supply problem? because i tried plugging it on both a 120V and 220V socket, still no change
3-27 05:00
LV_Forestry
Latvia
that other drone guy Posted at 3-27 05:00
If you are on a home network there should be no problem.  I mean a socket in a house.  But why not.
3-27 05:22
LV_Forestry Posted at 3-27 05:22
Thank you captain. Tried different outlets still didn't work. I am worried about that error I'm getting. making me think its likely a hardware issue.
3-27 05:25
LV_Forestry
Latvia
that other drone guy Posted at 3-27 05:25
The next step is to try to update or refresh all firmware.
Then try with a different power source like a big generator i mean 2kw and more (because i use it successfully). Maybe you can give a try in a hardware rent shop, pretexting that you could be interested in renting such device in case of. The condition is to know if it works or not. Or simply tell the truth and request a try only.
After that unfortunately the only way is to send it for diagnosis. Since its a brand new unit never used, DJI may replace it very quickly.
3-27 05:31
LV_Forestry Posted at 3-27 05:31
Thank you captain, i have tried most of those options, except maybe using a 2kw generator. will give that a shot, thanks for the assist
3-27 05:41
