Cine mode speed
331 5 3-23 12:10
GiannisS
Hello guys, I wanted to share an experience that I had with my Mini 4 Pro. While I was flying in cine mode, the speed was equal to that of the normal mode which is exactly what the specifications mention. However, on the last flight, the speed was close to 6m/s and made me feel a little bit confused. Is there any situation where the cine mode speed is decreased or increased automatically e.g. battery percentage? The weather was clear and not windy at all.
3-23 12:10
Serg SSA
Flight distance : 6406329 ft
In the settings you can limit the maximum speed of cinema mode. Check which one you have installed.
3-23 12:46
GiannisS
yeap I just found it, thank you for helping!
3-23 13:24
The drone will always launch in Normal Mode regardless of what setting you make with the switch.
The Flight Mode switch won't work until after the drone is launched.
3-23 14:04
GiannisS
Labroides Posted at 3-23 14:04
thank you that explains my situation
3-23 14:56
Hi there. Thank you for reaching out. The aircraft can remain in the normal mode when it first takes off and enable obstacle avoidance function by default, ensuring the safety of the aircraft when you take off the aircraft. Also, you can adjust some parameters under Gain & Expo Tuning in the DJI Fly app > General Settings > Control. Should you have other inquiries, feel free to contact us. We appreciate your valued support.
3-30 18:47
