C1 classification application system error on address entry
541 15 4-12 06:21
djiuser_XMBrAU2u4GdA
Flight distance : 64879 ft
I live in Belgium, I have been trying for several hours to complete the form for the address during the C1 classification of my DJI Air 2s, each time a system error appears
4-12 06:21
djiuser_YksetA7jHahk
Flight distance : 58809 ft
Hi, I managed by using the website to add the address, then I triggered the C1 certification from the remote. On the remote directly and from the iPhone it failed always.
4-12 07:16
On my dji my.dji.com account I already have an address but it does not appear in the choice, my remote control is rc-n1
4-12 07:31
djiuser_YksetA7jHahk Posted at 4-12 07:16
https://forum.dji.com/forum.php? ... 691&pid=3288697
4-12 08:23
Hello there. Thank you for reaching out and we do apologize for the trouble. Please try to set the system language of your mobile device/RC controller to the language corresponding to the country where you are located, and make sure to stay connected to a stable internet connection when filling in the address again. If the issue persists, please upload a screenshot or screen recording showing the error message on the remote controller for us to check it further. Please keep us posted. We appreciate your cooperation.
4-12 21:18
DJI Paladin Posted at 4-12 21:18
My remote controller is a RC-N1, the problem persist, my location is in Belgium and the data in the form is correctly entered
4-12 23:26
SkyLuk3
Flight distance : 239032 ft
I had same problem, i've tried several times, after a total update of app and drone firmware, after a full reset of drone and settings and other many things but nothing to do.  I've uploaded some  pictures in sequence about problem. Hope in a quick solution of this. Thanks in advance.
4-13 02:02
I finally succeeded by putting all the settings in English rather than French.
4-13 02:40
SkyLuk3
how it's possible on a smartphone samsung s23? inside the dji fly app I can't found nothing to do that. Maybe only changing language on entire android sistem of my phone.
4-13 13:53
SkyLuk3
Right now i've changed the language on my phone and dji fly app now is in english, but the error is still there. Still the same.
4-13 14:00
SkyLuk3
Solved now!! for me it worked by insert your address here: https://repair.dji.com/mycase. I suggest doing it on a PC because, as  tested, it works best on desktop computers. Afterwards, use the same account on the remote controller. The address from your center should be saved on the account and can be used on a remote controller.
4-13 14:21
djiuser_D764IMjx8ZYU
Flight distance : 80902 ft
It is a software bug. Try adding the address here and then select it in the request process.
https://repair.dji.com/mycase/myaddress
It worked and I already requested the label.
4-13 22:24
djiuser_XMBrAU2u4GdA Posted at 4-12 23:26
Thank you for keeping us posted. Please be guided to insert your address here: https://repair.dji.com/mycase/myaddress. I suggest doing it on a PC because, as we tested, it works best on desktop computers. Afterwards, use the same account on the remote controller. The address from your center should be saved on the account and can be used on a remote controller. I hope this helps.
4-14 19:50
modsolo.drone
Flight distance : 3281 ft
Bonjour,
Le problème vient probablement de l'impossibilité de faire la demande en étant sous système Android (smartphone ou DJI RC).
Cela fonctionne parfaitement sous Ios.
C'est à DJI de régler ce problème d'incompatibilité très vite.
Sinon la possibilité de le faire depuis le site web DJI est impossible également car il n'y a aucun espace où l'on peut indiquer son adresse postale.
Si DJI veut bien répondre ce sera avec grand plaisir.
Good morning,
The problem probably comes from the impossibility of making the request while using an Android system (smartphone or DJI RC).
It works perfectly under Ios.
It is up to DJI to resolve this incompatibility problem very quickly.
Otherwise, the possibility of doing so from the DJI website is also impossible because there's no space where you can indicate your postal address.
If DJI would like to respond, it will be with great pleasure.
4-15 00:26
SkyLuk3
I've tried both systems Ios and Android  on my iphone the problem was the same. I solved only throught web site on pc, where i've add my address and only after doing that I've seen the address written on screen of the phone.
4-15 00:33
modsolo.drone Posted at 4-15 00:26
Bonjour,
Hello there. Sorry about the trouble. Please check whether the current DJI RC2 system language is consistent with the language of the country where you are located. You need to modify the RC2 system language to have it be consistent with the local language. Inconsistency will cause a system error. Have a nice day.
4-15 00:59
