Is there a way to take off in manual mode?
499 9 4-22 05:14
zippomakerhotmail.com
Flight distance : 123182 ft
Hi
Is there a way to take off in manual mode? I don't like having to take off in N or Sport and then switch very much.... among other things, the difference in the throttle management between N/Sport and Manual is totally different...
thanks
4-22 05:14
Hi there. Thank you for reaching out. Let me confirm this with our relevant team. We'll keep you posted.
4-22 05:44
DJI Gamora Posted at 4-22 05:44
ok thanks, the strange thing is that when you are in N/Sport you can hover with half throttle, when you switch to Manual, and center the sticks to switch to Manual the Avata accelerates a lot, because the throttle point in manual for hovering it is much lower than N/Sport
4-22 05:52
fichek
Flight distance : 1036263 ft
Croatia
Go into manual mode, then double-press the start/stop button (while holding your throttle down if you haven't modified it to remove spring) to arm the motors, and take off like with any other FPV Drone.
4-22 11:17
zippomakerhotmail.com Posted at 4-22 05:52
Hi, zippomakerhotmail.com. Please check my DM regarding the topic we discussed. Thank you.
4-23 21:37
Coyut
Flight distance : 2559222 ft
I might be wrong. But I think I saw people have set the C2 switch, with the custom function, to arm the motors in Manual.
4-24 06:56
fichek
Croatia
Coyut Posted at 4-24 06:56
Yeah, you can do that too (can only make it so that C2 on top/mid stops motors and C2 on bottom starts them), but by default it's double-press on start/stop button that does it.
4-24 08:20
Dirty Bird
Flight distance : 41442379 ft
Yes.  This assumes you have already unlocked Manual Mode & adjusted your throttle stick for Manual flight.
With the Mode Switch set to Manual & the throttle set at zero, double-tap the Start-Stop button on the top right of the FPV Controller 3.  The motors should start.  Then apply throttle to lift off.
4-24 11:54
Andre Laf
Sure it is not the bottom right button for stop start.
4-24 16:37
thanks everyone, the double tap on start/stop in manual mode works, thanks
5-4 11:53
