Avata 2 - Reached maximum speed of 45.6 mph.
3067 71 4-24 06:08
Flying in manual and getting speed limited to 45.6mph,   as Im in the UK there should not be a speed limit and Im wondering if I should be un ticking the M Mode Attitude Limit option in the Gain & Expo settings.
4-24 06:08
djiuser_cvhEHIaSFk1b
Estonia
What controller do you use? You need rc3 for higher speed that is available if you are located outside of EU. Or maybe Ireland has same limitation
4-24 06:15
KLRSKIR
Flight distance : 28650751 ft
djiuser_cvhEHIaSFk1b Posted at 4-24 06:15
You can only fly Manual Mode with the Controller 3.
4-24 06:32
Coyut
Flight distance : 2559222 ft
In the european region and, probably UK as well, speed and signal strenght is limited due to the C1 EASA rules, which its certified to.
EASA regulates speed max (kinetic energy it produces due of its weight and speed), loudness (dB loudness from the drone trough a rpm limit of the motors) and also signal frequencies and strenght (CE).
There are illegal ways to unlock the FCC signal strenght, which also unlocks its original speed.
But if anything happens you will get legal problems in the EASA area.
4-24 06:44
MRDroneRookie
Flight distance : 2169833 ft
Hi DA.
Yes if you would like it to go faster you should untick attitude limit as attitude limit will limit the pitch and roll axis to a maximum pitch or roll angle. But be careful if you are new to manual mode as unticking this option puts you in full Acro and will allow you to go inverted. Limiting the forward pitch angle will limit the speed.
Also camera angle, although it does not physically limit speed a higher camera angle  ( like 35-40 deg) centers your (horizon) view at higher speeds.
4-24 07:44
Dirty Bird
Flight distance : 41442379 ft
Assuming you are using the FPV Controller 3?  Yes you need to uncheck the attitude limit for max speed, rolling, or flipping.  Note it will only matter when using the FPV3 in Manual mode.  No effect when flying with the MC3.
4-24 07:54
I’m using FPV remote 3
4-24 08:12
Coyut Posted at 4-24 06:44
I’ve seen other UK pilots hit 70mph in the U.K. so I don’t believe you’re EASA rules effect us.
4-24 08:13
MRDroneRookie Posted at 4-24 07:44
Hi DA.
Thanks.  That’s what I had thought but was struggling to find any details in the manual.
4-24 08:14
Dirty Bird Posted at 4-24 07:54
Yes using the FPV remote.  As you can see from the log above I’m in manual mode but being limited, I don’t beleive you can get the other controllers into manual mode.
4-24 08:15
fichek
Flight distance : 1036263 ft
Croatia
DAFlys Posted at 4-24 08:13
UK was still a part of EASA for a while after Brexit, but they've definitely left that too later on and as far as I know they don't have 19m/s limit that we do.
I'd start with disabling M Mode Attitude Limit as that will allow the drone to pitch fully forward and probably go the full 60mph (or more with backwind as seen in some vids mentioned above).
4-24 08:45
fichek Posted at 4-24 08:45
Yeah cheers.   We don’t have the 120m limit on c0 like EASA but we have our own issues too.
4-24 08:50
USER001
I should test my Avata 2 in M mode to see if it's the same.
4-24 08:56
A J
Flight distance : 14588274 ft
DAFlys Posted at 4-24 08:15
Great thread Daf - some really useful info in this.
4-24 14:48
USER001 Posted at 4-24 08:56
You need to buy the FPV Remote controller then.
4-24 23:56
Burt37
Flight distance : 4009 ft
Perhaps you should buy the Avata 2 first, then do the testing...
https://forum.dji.com/forum.php? ... =310015&pid=3297052
4-25 00:41
USER001
DAFlys Posted at 4-24 23:56
And that's what I'm going to do. In my opinion, the Motion Controller isn't satisfying.
4-25 07:16
A J
USER001 Posted at 4-25 07:16
Have you activated the drone yet?
4-25 08:07
USER001
A J Posted at 4-25 08:07
Yes. It arrived 9 days ago so I had plenty of time.
4-25 08:10
A J
USER001 Posted at 4-25 08:10
Drop one of the DJI mods a private message to let them know as the Avata 2 avatar should appear in your profile once activated. That way people will know you own the drone.
4-25 08:13
USER001
A J Posted at 4-25 08:13
Ok. I'll do that. But my Forum account is signed in through Google, and I can't do that with DJI Fly.
4-25 08:36
A J
USER001 Posted at 4-25 08:36
At least you can still post footage that you take with it I guess. Is it your first drone?
4-25 08:44
USER001
A J Posted at 4-25 08:44
No, I have a Mini 4 Pro.
4-25 08:44
A J
USER001 Posted at 4-25 08:44
Cool - always nice to have a back up. Have you posted any vids/stills yet. Be good to see some of your work
4-25 08:47
If you order from DJI they delivered mine the next day and you can have both the RC and MC paired at the same time.
4-26 00:33
fichek
Croatia
DAFlys Posted at 4-26 00:33
Yeah, that's one of the best features of Avata 2, being able to just turn one off, turn the other one on, and continue flying
4-26 06:13
fichek Posted at 4-26 06:13
Only problem with that is ve only got three batteries and they dont sell them here yet.
4-26 06:33
fichek
Croatia
DAFlys Posted at 4-26 06:33
Can't you order more directly from DJI?
4-26 06:37
fichek Posted at 4-26 06:37
They dont go in sale here until the middle of may from DJI and none of the DJI stockists here have them any either.
4-26 06:39
alex_markov
Flight distance : 40068986 ft
Bulgaria
I tried once in M with all bells and whistles off (it can flip in the air) and it reached 102 km/h and I am in EU
4-26 22:35
fichek
Croatia
alex_markov Posted at 4-26 22:35
https://youtu.be/mSTpibjJVek
Do you have "auto" greyed out under transmission menu or can you select channels manually? Because it looks like you might be in FCC mode.
4-26 22:56
Nice,  I assume you have the attitude slider off for that.
4-26 23:41
alex_markov
Bulgaria
fichek Posted at 4-26 22:56
It's greyed for sure or at least it was when I checked and I am pretty positive I am in CE mode as the signal is not so great
4-27 00:47
alex_markov
Bulgaria
DAFlys Posted at 4-26 23:41
yep this is first I did but forget to flip after speed check
4-27 00:48
fichek
Croatia
alex_markov Posted at 4-27 00:47
Interesting. We've seen people from UK who have limited power/channels but their speed is not limited. Bulgaria should definitely have speed limited as it's EASA member, but maybe your activation somehow got mixed up (we've seen similar issues rarely on older drones, I know a guy from US who had his Avata 1 activate in CE mode when he first got it).
4-27 00:55
fichek Posted at 4-27 00:55
So far Ive only seen videos from people saying they are not limited in the EU in manual mode,   have we actually confirmed the speed is limited and how exactly would they do that in manual mode if they didnt limit the pitch.
4-27 01:01
fichek
Croatia
DAFlys Posted at 4-27 01:01
I believe throttle is limited. Haven't really tried it much myself since my leg is broken and I've mostly been playing with it indoor in N mode.
4-27 01:10
fichek Posted at 4-27 01:10
Weird,  I ve watched a few Eu videos now, one from Italy where there is no limit.
4-27 01:11
fichek
Croatia
DAFlys Posted at 4-27 01:11
Definitely seems a bit inconsistent, yeah. There's another guy here on the forum who claims ham_cfg_support file unlocks full motor power and speed for him, and others saying it does nothing. Go figure.
4-27 01:35
fichek Posted at 4-27 01:35
ham_cfg_support did for the pre release firmware that the reviewers got,  and I think if you activated it before the firmware upgrade it would stick after the upgrade.
4-27 01:43
