at_stephan
Flight distance : 17467 ft
FabioV Posted at 4-12 02:30
You country code should be 0049, not 049. I was successful adding a valid address after trying several times, but from the PC, not from the controller. Then I used the controller for finalising the request, using the address added from the PC.
I also tested ver often and now with 0049.Everytime "System Error Please try again later
Perhaps DJI could check if there is a problem on their side?
I will retest it at the weekend ...
Regards |
