Sparky J
DJI Gamora Posted at 5-2 07:44
Hi, Sparky J. Thank you for reaching out. Are you getting any Remote ID errors? Here are the methods that you can check whether RID functions properly:
Method 1: Before the drone takes off, view the RID status in the corresponding DJI app. The display method varies with the DJI app.
Method 2: Turn on WLAN on any mobile phone. In the “Available networks” list, check whether a character string “RID-1581FXXXXXXXXXXXXXXX” is displayed, which always starts with “RID-”, followed by a 20-digit RID SN, as shown in the following figure. If this character string is displayed and the character string starts with 1581F and is the same as the RID SN, it indicates that the aircraft is broadcasting. The user needs to try to turn WLAN on and off several times because it may take a bit longer for some mobile phones to scan (in general, it can be displayed in 5-10 seconds). This method is also helpful for checking an aircraft’s RID SN.
Thanks for the response.
I'm using the Smart Controller for my Mavic 2 Pro and don't see anything related to RID on the screen. However - when I use an iPad tablet as a control I can see that the the RID is functioning normally, but the RID is not showing on my iPhone Wi-Fi networks. Since I use my smart controller most often, where would I see if the RID is functional on the Smart Controller?
Also - I plan to use the iPad as a secondary controller so that another person can control the camera while I pilot the aircraft using the Smart Controller. I have yet to try the two controller set-up after the latest firmware updates but I assume it will still work. Please let me know if you have any thoughts on that.
Thanks,
Jack |
