DJI Avata 2 - Full throttle and max speed for EU drones, no hacks...
1929 29 4-26 10:43
skyscope
Flight distance : 4318704 ft
As you might already know, the Avata 2's speed is capped in Europe due to its classification as a C1 class drone, which limits its speed to a max of 19 m/s.
With this mod, you'll unlock your C1 Avata 2's full power, and it won't cost you a thing or require any hacking.
And the best part: You can easily choose before each flight whether to fly with reduced power and C1 specifications, or at full power. Thanks DJI, solved my problems described here: https://forum.dji.com/forum.php?mod=viewthread&tid=286299&mobile=2
Take a look…
4-26 10:43
fichek
Flight distance : 1036263 ft
Croatia
Nice, now we have people doing false advertisement for their videos
To sum up, he talks for 12+ minutes in German and when he finally gets to the point it's just ham_cfg_support file which doesn't work if you updated firmware as you should have. Save your time.
4-26 10:52
skyscope
fichek Posted at 4-26 10:52
Interesting summary, although quite meaningless, since I've been running the latest firmware from day one, as always.
4-26 16:58
alex_markov
Flight distance : 40016650 ft
Bulgaria
4-26 22:23
fichek
Croatia
skyscope Posted at 4-26 16:58
Tons of people tried this the moment they got their Avata 2 and reported back that it doesn't work unless you keep prerelease firmware. You either didn't update your goggles, or aircraft, or both, or they're somehow special and different from everyone else's
4-26 22:44
Ive tried the ham_cfg_support file and it does nothing.   If you applied it before the last firmware then it would have activated some channels which I believe stick after the upgrade.
4-27 00:19
skyscope
fichek Posted at 4-26 22:44
"Tons of people tried this the moment they got their Avata 2 and reported back that it doesn't work "
Obviously you missed an important part in the video. Unless they had Fly App 1.13.1 ....
4-27 01:02
fichek
Croatia
Sorry, I'm not that great with German, and the auto-captions are pretty terrible, but yes, I personally had 1.13.1 since day one because that update was released before my Avata 2 arrived and my goggles had ham_cfg_support on them the whole time since I just transferred the card from my old goggles.
4-27 01:20
djiuser_m9qFdCNPdPPN
Austria
fichek Posted at 4-27 01:20
The ham file still works tested it myself 20 minutes ago. The file only changes the power limitation in ce. Frequence is still on CE, which is fine, but the default power in CE was to weak, so ita nice to bypass at least that limitation
4-27 07:09
Bensberger
Flight distance : 1297329 ft
And did you follow the correct power-on sequence of (1) Goggles, (2) RemoteControl, (3) Avata, as he mentioned in the video ...? (8:25)
4-28 14:32
fichek
Croatia
Bensberger Posted at 4-28 14:32
That happens to be the exact order I've always been powering things on (not that I believe the order has anything to do with it, but if it does then it's clear sign of it being a weird edge case which is maybe why not all of us experience it). Just tried a couple hours ago, best I got was ~23m/s down wind.
4-28 14:42
skyscope
Then in your own words:
"You either didn't update your goggles, or aircraft, or both, or they're somehow special and different from everyone else's"
4-29 00:00
fichek
Croatia
skyscope Posted at 4-29 00:00
I guess it's me that' special as now mads tech is also saying it removes speed limit. Sorry for doubting you, but there was definitely confirmation bias with "it doesn't work" from literally everyone I talked to so I didn't question mine not working. I'll try factory restoring.
BTW does it really only work for you if you power stuff up in specific order as Bensberger said above?
4-29 05:07
skyscope
See Post #1...
4-30 14:16
FlugFux
Is there a way to remove the speed limit without enhancing the output sending power ?
5-6 02:10
BadBert
Flight distance : 89751 ft
FlugFux Posted at 5-6 02:10
not so far as i found.
range of the avata 2 is really good in CE power compared to the avata 1 in FCC! (yes, my own experience)
5-7 22:31
DroneVisuals
Flight distance : 114114 ft
fichek Posted at 4-29 05:07
Hi im not sure if you figured it out already but let me tell you my experience in unlocking full speed in manual mode in CE Region.
I'm also on the latest firmware for both goggles and drone.
What i did was:
- put in the sd card in the goggles, format it using the goggles
- upload the ham file (make sure its not a .txt or anything as that won't work)
- start the goggles and drone, the order didnt matter for me.
- Put it in manual mode and also untick the box called "M Mode attitude limit) for full acro mode
After that im reaching the FCC speeds and full throttle in CE region. Still can't change channels.
5-8 04:37
fichek
Croatia
DroneVisuals Posted at 5-8 04:37
I haven't had a chance to test it again (broken leg), but my microsd card is fine and has ham_cfg_support on it from old goggles. Will try this weekend hopefully.
5-8 07:34
player_87
Flight distance : 777917 ft
The Ham file works fine, as expected when devices are powered up in a specific order, although the battery now lasts only 5-8min when flying at higher throttle
5-8 14:26
fichek
Croatia
player_87 Posted at 5-8 14:26
This is what concerns me, some people saying order matters, and some that it does not. Sounds like the whole thing working at all for some people might be a bug.
5-8 15:04
BadBert
the drone has more power, more rpms, so it is logical that if you use that extra power/speed it consumes more power and drains the battery faster ;)
5-9 23:22
SkyCut
Flight distance : 925860 ft
where I can find this "ham" fille to download?
5-10 09:35
SkyCut
ok i just create it by my own,  I will test it tomorow if it works
5-10 12:17
player_87
fichek Posted at 5-8 15:04
Have you had a chance to test it yourself ? I can confirm from my own experience that If I will power up the drone first then speed is limited. Avata2 is useless/dangerous to use  in manual mode IMO as the drone doesn't have much power to combat moderate to strong winds. Max speed would be ok to live with but limited throttle is another story.
5-10 14:45
fichek
Croatia
player_87 Posted at 5-10 14:45
I’ve only tried a bit around the house once to confirm I was limited to ~19m/s and mostly just flown indoor since I have a broken leg. Hopefully gonna try it again outside today or tomorrow.
While I mostly plan to fly it in N/S as stabilised pitch on gimbal is #1 selling point for me and I have other fpv drones for acro flying, I would still like to have full acro capabilities available if needed. Imagine flying far away in N/S mode and not being able to come back due to wind. Flip to M mode and pitch forward 80 degrees if needed
5-10 22:09
SkyCut
SkyCut Posted at 5-10 12:17
OK guys! IT WORKS 105km/h and better range a bit
9:30 min record battery lasted
5-11 11:12
fichek
Croatia
Finally got to try manual mode again today.
First try 20.6m/s max down wind. Second try I formatted the card, put a brand new ham_cfg_support file on it (even though I've used the same one for years now), turned everything off and turned the drone on first, then goggles and radio, max speed recorded 20.2m/s. Third try I re-flashed firmware on drone and goggles (didn't feel like it made sense to re-flash controllers) and after pairing everything again and rebooting I turned on goggles first, max speed recorded 25.2m/s (that got me excited for a sec as it was pretty close to 27m/s which should be max if it's really unlocked) but only for a split second when going down wind and slowed down to high 19s right after that so I guess it was just a big gust of wind. Fourth try I deleted the ham file and rebooted everything, then factory reset goggles and rebooted again, then added the ham file back again and rebooted one more time for good measure. Now whatever way I turn everything on I consistently get over 27m/s going down wind. Top speed recorded on the next battery was 28.3m/s. I wish I just did factory reset first before trying all that mumbo jumbo voodoo first
Funny thing is I flew around some buildings before and after speed change and noticed zero improvement in penetration so either 1) the RF part of the hack worked for me since day one or 2) CE mode was really freaking good in 2.4GHz at 100mW. Still feels like the fact that this works is a bug. I hope to be proven wrong again. If one of you that need to turn your devices on in specific order for it to work wants to risk trying factory resetting the goggles let me know if that changes anything.
5-11 14:08
AirUnit76
Flight distance : 240443 ft
fichek Posted at 5-11 14:08
Can you change channels manually or are they still locked in auto mode?
5-19 12:20
fichek
Croatia
AirUnit76 Posted at 5-19 12:20
Locked in auto which is fine as I'd never want to mess with magic after seeing how well it worked with Avata 1 and O3AU.
5-19 12:20
nightfly
Romania
fichek Posted at 5-19 12:20
deleted post
5-19 13:12
