DJI Mic Popping and Crackling Sounds
192 6 5-1 06:14
beachwood_01
I am hearing popping/crackling sounds from my audio track when recording with the DJI Mic. I have performed several tests to determine what is causing it, but have not found any solution. Here are the tests.
1. Testing to make sure mic cord was fully plugged in = still hear popping sounds, no change
2. Physically rubbed the the Lav mic = still hear popping sounds, no change
3. Formatted memory in transmitter = still hear popping sounds, no change
4. Cable test (used both Rode cable and DJI cable) = still hear popping sounds, no change
5. DJI transmitter only (no lav) = still hear popping sounds, no change
The only tests that recorded good audio (no popping) was a direct USB connection.
6. Mic 1 direct direct via USB = no popping
7. Mic 2 tests direct via USB = no popping
- - - - - - - SUMMARY - - - - - - -
From my tests, this appears to be an issue with the transmitter.
Here is a sample file of the audio popping: https://www.dropbox.com/scl/fi/jogm9k4fnze4l9y5o1r7v/Audio-Popping.mov?rlkey=geurmouax0vmtmo20zon22rle&st=5csxytdq&dl=0
5-1 06:14
DJI Natalia
We apologize for any inconvenience caused. Thank you for providing the audio file. In order to address the issue, we kindly ask you to follow the steps outlined below:
1. Adjust the distance between the DJI Mic transmitter and the sound source as needed.
2. Reduce the gain settings on the DJI Mic or the camera, depending on the situation.
If the problem persists, kindly provide us with the following information:
1. A video demonstrating how the DJI Mic transmitter is being worn or mounted.
2. A video showing the distance between the DJI Mic transmitter and the sound source.
3. Details of the gain settings on the DJI Mic, camera, and any other relevant devices.
By providing these details, we will be better equipped to assist you in resolving the issue. Looking forward to your response.
5-2 00:00
beachwood_01
Here are the answers to your questions.
I don't understand the relevance of this request as the sound source is my mouth, so changing the distance using a lav mic isn't really possible unless you're referring to a few millimeters difference.
The gain was already reduced in the original file that I attached: I always record at flat levels (reproduced in the follow up questions and accompanying second video that I created below).
I've created a video  that demonstrates the following:
1. How the DJI Mic transmitter is being worn or mounted.
2. Showing the distance between the DJI Mic transmitter and the sound source.
The gain settings on both the DJI Mic transmitter and receiver, as mentioned in the video, were 0.
Here is the video:
https://www.dropbox.com/scl/fi/xxh6q6ek6dqvu6jubrfw0/Audio-Test-5.2.24.MP4?rlkey=fuczguj9ipk4qd3xp0itksf9f&st=iba1mnzd&dl=0
I didn't mention the camera audio level in the video, but I have photo (below) of the setting, which was +1.
https://www.dropbox.com/scl/fi/xxh6q6ek6dqvu6jubrfw0/Audio-Test-5.2.24.MP4?rlkey=fuczguj9ipk4qd3xp0itksf9f&st=k4itmhol&dl=0
5-2 12:47
beachwood_01 Posted at 5-2 12:47
Hi, there.Thank you for the video you provided. We will further verify it with our engineers and notify you as soon as possible.
5-2 23:14
Hi, there. What model is your phone connected to the DJI Mic?
5-5 22:06
beachwood_01
There is no phone connected to the mic. It is connected to a Sony A7III.
5-6 05:01
beachwood_01 Posted at 5-6 05:01
Hello. Please provide the following information, we will verify further with our engineers.
1. Confirm the specific connection method, provide third-angle video, detailed shooting connection method, and the working status of the interface;
2. Change other connection methods and other devices to confirm whether this exception still occurs;
3. Turn on the TX internal recording at the same time, and confirm where the abnormality occurs in the internal recording audio, the audio output from the RX monitoring hole, and the audio output from the RX to the recording device.
5-6 05:31
