DJI Mic 2 connected to Black Magic Cam app on an iPhone.
3002 17 1-31 15:53
Flying Peacock
Flight distance : 187 ft
Hello.
I connected my DJI Mic 2 with Blackmagic Cam app using bluetooth on my iPhone 15 Pro Max.  Everything was working fine for a couple of days. Then I was unable to hear any of my new recordings. I can see Blackmagic Cam is using DJI Mic 2 as the audio source mic and I see the meters working away as I am talking. All seems to be fine, but when I playback all I get is silence?
I spent a good hour on the phone with a very helpfull Tech. Support guy  from Apple who found nothing wrong with any of my iPhone settings that could be muting the Mic.
Any suggestions.
Ian.
1-31 15:53
DJI Wanda
Hi there, about the issue you mentioned, here are several ways to help you further confirm. First, could you please confirm whether are there any upgraded versions of your mobile phone system and Blackmagic Cam App? If you have an upgraded version, the reason why it cannot be externalized may be due to the version upgrade. It is recommended that you use the DJI Mimo App (which requires the latest version) for recording. Or use these two apps (Filmic Pro, Protake) to record. Second, if your mobile phone or Blackmagic Cam App has not been upgraded, you can turn off the transmitter and then test whether the phone can play sound normally. If it still cannot play sound, there may be a problem with the phone. Third, if your phone can play sound after turning off the transmitter, it is recommended that you use the DJI Mimo App or other two apps (Filmic Pro, Protake), and then test whether the phone can play the sound normally.
2-2 23:25
Flying Peacock
DJI Wanda Posted at 2-2 23:25
Hello Wanda.
Thanks for your reply anf information. As far as I know I have the latest version of everything. I have DJI Mimo and I am using it with my DJI Mic 2 and my Osmo Mobile 6 Gimble, using Bluetooth and they all seem to be working fine. I am waiting to hear back from back from a post I put up on Blackmagic Cam Forum.
I will try using DJI Mimo and Mic 2 only. The iPhone is working fine. I spent an hour with Apple Tech Support going over all the various combinations that could be a problem with the iPhone Mic and it is working fine. The DJI Mic 2 shows up as being connected on Bluetooth but does not show up on the Mic Settings on my iPhone.
Oncea again, thank you for your suggestions. I will try again later today.
Best regards.
Ian.
2-3 11:08
Flying Peacock Posted at 2-3 11:08
Hello Wanda.
Okay, you can also use other two apps (Filmic Pro, Protake) for recording. If you need any other help, please feel free to contact us.
2-3 20:34
Flying Peacock
DJI Mindy Posted at 2-3 20:34
Thank you for your help.
Cheers.
ian
2-9 20:34
Flying Peacock Posted at 2-9 20:34
Cheers.
You're welcome. Have a nice day!
2-16 19:17
COACH7
I bought new dji mic 2 and it is connected successfully to my iPhone 12 pro max, i can’t use it at all with blackmagic app! When i go in the menu of audio source there is the option dji mic2 but each time i tap on it, it doesn’t select it! It been 2 weeks I’m trying to use my mic but it is useless! Any help please?
5-1 08:12
DJI Natalia
COACH7 Posted at 5-1 08:12
Apologies for any inconvenience caused. To assist you better, please clarify whether you are connecting the DJI Mic 2 to your phone via Bluetooth or by connecting a receiver to your iPhone. Once you provide this information, I'll be able to provide you with clear and relevant instructions.
5-1 22:59
COACH7
DJI Natalia Posted at 5-1 22:59
I’m connecting my dji mic 2 via bluetooth.
5-2 11:35
COACH7 Posted at 5-2 11:35
Hi, there. We will further verify it with our engineers and notify you as soon as possible.
5-2 23:15
COACH7
DJI Susan Posted at 5-2 23:15
Any updates from your engineers? It is not possible to make a mic special for Iphone and it is not working at all with iphone!!!
5-3 10:11
COACH7 Posted at 5-3 10:11
Sorry for the late reply. You can check to see if there is any setting for selecting audio input in this software. Or is there a setting to choose Bluetooth input in the audio settings?
5-5 22:15
COACH7
DJI Susan Posted at 5-5 22:15
This is very basic step. It is not the problem please go back to my first comment and see there what is the problem. I have explained clearly the issue. I have the dji mic 2 connected successfully by bluetooth. When i open blackmagic application then i go to audio source, i can see the option of dji mic2 BUT I CAN NOOOTTT SELECT IT.  This is the problem. I have updated my iso to the latest version and the app as well. It doesn’t work with any other third app parties neither. I have tried promouvie, pro take, premiere rush, cinema p3 and the list goes on and on and on. It just doesn’t work.
5-7 01:29
COACH7 Posted at 5-7 01:29
Hello. We see that you have tried to connect to Protake. Did you follow the steps below to set it up?
1. Switch the DJI Mic 2 transmitter to the Bluetooth linking mode and connect it to a mobile phone.
2. Run Protake, and tap the audio waveform icon in the bottom left corner.
3. Select the mic option, then choose Bluetooth to record audio using the DJI Mic 2 transmitter.
5-7 03:41
tiita4.ee
Flight distance : 2064140 ft
Estonia
Mic 2 worked with my iPhone 15 pro only on the first day. Settings will show you BT connection is available. Blackmagic Camera cannot find the microphone. CinemaP3 finds it, but if I choose Mic2 as the input, the recording stops after 23 frames. The phone's Camera app cannot find the microphone. The first day I recorded the interview with the Mic 2 in Cinematic mode and everything worked. I have restarted the devices, reconnected but nothing works. I am very frustrated.
5-8 05:26
tiita4.ee Posted at 5-8 05:26
Hi there, we are sorry for the issue you are encountering. Could you please provide a video showing the issue? You may save it through a shareable link like Google Drive and DropBox, then send the link here. We will check this further for you. Please tell us the firmware version of your Mic 2. And we want to know if you connected via Bluetooth or a receiver.
5-8 22:12
COACH7
DJI Susan Posted at 5-7 03:41
I have tried again the dji mic2 is not available to use in all these applications! As you can see in this promovie app it has been written the mic is not available! Even tho it is 100% connected via bluetooth and it is on and running but it cannot be used at all! It has been more than a month that i can NOT which i have bought this mic i couldn’t use it! Help please! If i have bought another 10 dollar cheap mic from amazon would have been working at least!
5-15 00:40
COACH7 Posted at 5-15 00:40
Hello. Could you please provide a video showing the issue?You can follow these suggestions:
1. You can try changing to another third-party software to see if it can collect the sound.
2. Use the Bluetooth direct transmitter of the Apple mobile phone to record with voice memo (the sound will not start to be collected until 4 seconds) to test whether it can collect the sound.
5-16 18:39
