Charging my battery in another country.
8962 14 2016-4-24
kwolek.alex
Hey guys im from the USA and i am traveling to Poland (Europe) and i wnated to know will i need a converter or a adapter to charge my batteries safely? Thanks
2016-4-24
phantom-four.co
Croatia
You'll need a travel adapter as the outlet plugs are different.
2016-4-24
DJI-Paladin
Flight distance : 2408 ft
Hello alex, a travel adapter is necessary which you could buy it on ebay or amazon
2016-4-24
GeorgeDonovan
Flight distance : 917336 ft
The DJI charger can handle from 110v to 250v 50hz or 60hz. As DJI-Paladin says you just need an adaptor plug. Remember that Poland uses 220v electricity so dont bring any other electrical things from home unless the have a dual voltage option.
Could I ask you how you plan on getting your drone on the aircraft. Are you going to take it as hand baggage or check it into the hold. Its just that here in the uk we are limited to hand luggage size of 9 x14 x23cm and I have been unable to find a case to take my P3A to Las Vegas that is small enough.
Regards
George
2016-4-25
GeorgeDonovan
Sorry I mean 9 x 14 x 23 inches for the luggage size
2016-4-25
phantom-four.co
Croatia
GeorgeDonovan Posted at 2016-4-25 13:40
Hi George, this backpack is 9.06x13.39x22.05
If you're willing to risk the .06 it might work.
2016-4-25
SajidShah
Flight distance : 627539 ft
Portugal
Dont Forget That In POLAND flying Certificate is must to Fly ...and u dont need any specify adapter ..
2016-4-25
kwolek.alex
GeorgeDonovan Posted at 2016-4-25 07:39
The DJI charger can handle from 110v to 250v 50hz or 60hz. As DJI-Paladin says you just need an adap ...
Hey whats up George! Thanks for the response! I am actually using the DJI Carrying Case!
2016-4-25
kwolek.alex
SajidShah Posted at 2016-4-25 08:54
Dont Forget That In POLAND flying Certificate is must to Fly ...and u dont need any specify adapter  ...
Where can i get the Poland Certificate?
2016-4-25
phantom-four.co
Croatia
SajidShah Posted at 2016-4-25 14:54
US plugs don't fit Polish power outlets so OP does need a travel adapter ;)
2016-4-25
SajidShah
Portugal
phantom-four.co Posted at 2016-4-25 23:57
European and USA charger is same .. JUST  UK Plugs are different
2016-4-25
phantom-four.co
Croatia
SajidShah Posted at 2016-4-25 22:15
Exactly. That's why a travel adapter is necessary. To go between the American plug and the European outlet.
2016-4-25
GeorgeDonovan
Do you know what size the DJI carrying case is or do you mean you are taking it in the white box that it came in.
Either way can you let me know how you get on carrying it onto the aircraft, if you get any grief from security etc.
George
2016-4-25
djiuser_i4gRttFukfG6
I’m traveling to the Philippines what converter do I need to charge my mini pro 3? Plz help I have a idea but not quite sure thank you..
Sam
2023-7-6
Ritch T
Philippines
djiuser_i4gRttFukfG6 Posted at 2023-7-6 05:35
Sam
Philippines outlet are all in 220 volts and the plugs are the 2 pins flat.
6-1 07:07
