Phantom 3 Series firmware update
30003 273 2016-3-15
Not A Speck Of
Flight distance : 666493 ft
gosports1 Posted at 2016-3-15 12:12
Now another BIN File- I told them last time my Computer does not Recognize Bin Files that went out ...
The BIN file is a valid file. The Windows OS doesn't recognize it, but you are not to ask Windows to do anything with it. The DJI aircraft is the device that reads the BIN file, per instructions that live in the same web location that you got the firmware ZIP from (that contained the BIN file).
2016-3-15
Not A Speck Of
tmygun1 Posted at 2016-3-15 13:28
Yes......you usually delete the bin file unless you have to update the extract batteries you might ...
There is no reason to delete the BIN file from the SD card. It doesn't hurt anything being there. In fact, it's a good thing to have it there in case something happens in the field, such as a battery thinking that it needs to be upgraded.
2016-3-15
James'ik
Flight distance : 126804 ft
Well... I was hoping the next firmware will address the horizon issue. Too bad it didn't. It's really very disappointing. On my P3A the camera is almost always tilted to one side and it drifts. It might start level but then it will lean right and slowly go back and continue going and leaning left. Once in a while the camera will lean sharply (about 30-40 degrees) to one side when turning. It's usually to the right.
I wonder if DJI will ever address this issue or is the geofencing more important.
2016-3-15
lee5156
What about the remote controller?  I P3P updated but I'm having trouble with the remote; 1.5.70
2016-3-15
DJI-Ken
Flight distance : 1515312 ft
Sam999 Posted at 2016-3-16 06:19
The solution for those seeing the + sign insted of 1.7.0060 is after upgrading the DJI Go to 2.7.0 a ...
It worked for some and some it did not.
It will eventually show the correct update.And my app never logged me out so my RC update shows 1.5.8 and I had no problem.
But some may see the 1.6+, and it will go away.
Also, none of my settings changed.
2016-3-15
Tintin
dehner Posted at 2016-3-15 12:36
It would be nice if active tracking is available on the P3.
Hi. Active tracking Is now available for the Phantom 3. It's an app (not free) and it is here: Active Tracking.
2016-3-15
GQ.
This the results I have after upgrade. I did have 2 RC update in the last hour.
2016-3-15
DJI-Ken
GQ. Posted at 2016-3-16 08:39
Glad you are all good, but there is only one RC update, 1.5.8
Maybe yours didn't update the first attempt.
2016-3-15
vinojaya6
Indonesia
New update for P3 Standar not raise the range, that same before.
2016-3-15
zutama
Indonesia
DJI-Ken Posted at 2016-3-16 07:22
It will eventually show the correct update.And my app never ...
Is it ok to upgrade the P3A/Pro directly to 1.7 from 1.4? Thank you
2016-3-15
DJI-Ken
zutama Posted at 2016-3-16 09:46
Yes it is ok.
Only if you were under 1.3, you have to stop at 1.3 then go to 1.7.
And if there is an issue, then you can go step by step.
2016-3-15
luciano.mascott
Flight distance : 523363 ft
Argentina
I updated the DJI Go app this morning and then the rc firmware update. Now i can't connect the rc to the aircraft.  The rc status led is solid white.
2016-3-15
Johnny Danger
Flight distance : 2997710 ft
Updates went without a hitch. I just want to thank all you guys and girls who take the time to put those helpful tutorials and other helpful videos and posts regarding the drones.
2016-3-15
Jbundy63
Flight distance : 9583182 ft
All updated!!! Thanks Ken!
2016-3-15
waynegknott
ok DJI can you acknowledge there are some issues with this upgrade, the common one seems to be signal loss. Just let us know you are working on it.
2016-3-15
Not A Speck Of
I upgraded my P3P.
Issues with the upgrade: none. It worked just fine.
Issues with first flight: none, it flew just fine
Issues with settings: Why do you have to change the settings with new firmware? Could you at least warn us that you reset them? While out flying, there as a great sky and I took some photos, only to come home and discover that DNG + JPG was reset to JPG only. I can't post-process photos from a freakin' JPG, I need RAW.
2016-3-15
daveyo240
Has this new update came out yet?
2016-3-15
waynegknott
one other issue I have is that when you go to about when it does connect all I get is the version 1.4.60+ nothing about the RC or app. anyone else have this. As you can see I have a standard.
2016-3-15
daveyo240
We're can I get the upgrade?
2016-3-15
waynegknott
daveyo240 Posted at 2016-3-16 10:24
don,t it is not an upgrade at all, has left me grounded
2016-3-15
daveyo240
No shit . Well thank you for the heads up.
2016-3-15
luciano.mascott
Argentina
Can anybody help me? I updated the app, rc firmware and aircraft firmware. Now, the led status of the rc blinks solid white and it doesn't sync with the aircraft. Also, the app recognise that there is a rc connected but it doesn't show version. Thank you for your help!
2016-3-15
waynegknott
luciano.mascott Posted at 2016-3-16 10:55
Can anybody help me? I updated the app, rc firmware and aircraft firmware. Now, the led status of th ...
this update has affected allot of us, hoping DJI will respond soon. I have never seen so many issue with and upgrade. we all can't be doing this wrong.  another issue when I open up the go app it will flash from the inspire screen to the phantom screen and no way to connect. need to turn off everything even the phone and start over. may work may not but alway RC signal weak or no signal.
2016-3-15
fcalba78
New update showed up on the app for my RC. After it was done installing, the gimbal on my P3 Pro started moving like crazy and getting Gimbal Motor Overloaded. I'm not able to update anything else. Anyone else encountered this problem with the Gimbal?
2016-3-15
MadMedic
CAREFUL!!!  New update bricked my P3P!!!!!  Just sits there and beeps for hours!! Changed bin file back to the previous and it still just beeps at me.  Not cool!!!!
2016-3-15
fbarski
I am a newer owner of a P3S and would like to have step by step instructions for doing this update to avoid any issues.  When I open the app on my Samsung S5, it states, "PS Standard 1.4.60 Firmware update".  Thanks!
2016-3-15
waynegknott
fbarski Posted at 2016-3-16 11:45
I am a newer owner of a P3S and would like to have step by step instructions for doing this update t ...
wait a few days read the forum this update has issues
2016-3-15
leorvasquez
I did my update to the new firmware for my Phantom 3 Advanced and didn't have any issues. I did mine via the app and it worked like a charm. Here is a screen capture of the new app and from the About screen for the versions. I'll take her out for a flight tomorrow.
2016-3-15
JockC
Flight distance : 459416 ft
DJI Go 2.7.1 update now available for IOS. Second DJI Go update in just a few days. No details as to what it might have fixed/changed.
2016-3-15
Guerinomaione
Nothing about vibration?
2016-3-15
Cabralkev
Flight distance : 1997861 ft
Still vibrations appear when hovering. Had to lower basic gains to 90 to calm it down at least. Other than that, no problems after update. I did a IMU calibration, following up with a gimbal calibration and compass. Didn't fly for long, but all was good. Hovered a bit, moved around and no issues. Will try again tomorrow though.
2016-3-15
scarper
Flight distance : 59272 ft
tmygun1 Posted at 2016-3-16 04:28
Yes......you usually delete the bin file unless you have to update the extra batteries you might ha ...
I put my second battery in.  It didn't seem to update.
2016-3-15
wellsi
Flight distance : 8330187 ft
luciano.mascott Posted at 2016-3-16 02:55
Read the section of the manual on synching your RC with your aircraft. This is often required after a firmware update.
2016-3-16
DJI-Tim
no vibration
2016-3-16
mdfarys
Hi guys need help here yesterday I upgraded to 1.7. But the update failed(stated on the log), so I tried again but this time round nothing happened when I switch the bird on. So I decided to take a look at the current firmware, it stated 1.7. So did it failed or not ? I can't re update cuz it's already at 1.7.
2016-3-16
Karthik Raju
Are we going to get and update for android like the ios for GoAPP ? because the 2.7.0 version of android does not show the live video feed from the camera. The live video feed however works with the 2.6.1 version which i had prior to update on another device.. anyone has a fix for this? or we have to wait till DJI releases an update for the GoAPP to address this issue.
2016-3-16
tmygun1
Flight distance : 2972497 ft
scarper Posted at 2016-3-16 03:29
That means there was no battery update in this firmware release, just the aircraft.
Not every firmware release updates the batteries.
2016-3-16
luciano.mascott
Argentina
wellsi Posted at 2016-3-16 05:14
Read the section of the manual on synching your RC with your aircraft. This is often required afte ...
I did it.. but the rc seems to be death.. it is not well recognised by the app. The status led blinks solid white..
2016-3-16
Guerinomaione
Hi Ken, i mean if the new firmware solve the vibration issue...
2016-3-16
Bhujang
Flight distance : 534587 ft
All updated. Mine says 1.7.60 in the go app so all good there for me.
Am I right in thinking that there was no battery update so don't need to complete again with my 2nd battery?
2016-3-16
