david.p.mann
Flight distance : 18669501 ft
OK - I figured it out. This is the procedure that worked for me. Detailed firmware update instructions really should be included in the box on a single sheet of paper. I own a Phantom 3 Pro and an Inspire, but the firmware update procedure for P4 is COMPLETELY different.
1. Connect iPad to RC using an Apple-certified USB-Lightning cable.
2. Power on RC - iPad automatically turns on (that's new)
3. Start DJI GO app
4. Power on P4
5. On main screen of DJI GO app - the one where the P4 picture is displayed, you should get a message that a firmware update is available. (Note: If you enter the DJI GO app and go to Camera screen, you will also get a message that a firmware update is needed, BUT you cannot update firmware from this screen or by tapping on the message. Instead, go BACK to the main screen with P4 picture.)
6. Tap on the DOWNLOAD icon at bottom of screen. Firmware took 7-8 minutes to download even though I have 30-50 kbps high-speed Internet service, so BE PATIENT. If download pauses, just tap RESUME DOWNLOAD.
7. When firmware download completes, DJI GO app will instruct you to connect cable to P4 aircraft using adapter cable. OK this is a little complicated. Here's what I did that worked.
8. Leave P4 and RC powered ON.
9. Disconnect full-size USB connector from the back of the RC leaving Apple Lightning cable attached to iPad.
10. Plug USB connector into DJI-provided adapter cable that has a female USB connector on one end and a micro-USB male connector at the other end of 4-inch cable.
11. Plug micro-USB connector into micro-USB port next to microSD slot on the side of the P4. Do NOT turn off the RC! (NOTE: The first two attempts, I turned the RC off and the firmware update failed to proceed.) So, now your iPad or iPhone will be directly connected by USB cable to the P4 (the RC is now connected only wirelessly to the P4).
12. If you are lucky like I was, the firmware update will start within 15 seconds of plugging micro USB cable into P4.
12. P4 firmware update progress will be displayed as a percentage at bottom of DJI GO app screen.
13. When firmware update completes, you will be instructed to disconnect and then reconnect USB cable to update the firmware upgrade status. (Note: I disconnected the micro USB cable from the P4 and plugged it back in.)
14. DJI GO app should now display message indicating update is COMPLETE and instructs you to reconnect RC.
15. Leaving RC and P4 turned ON, I disconnected the cable from the P4, disconnected the 4-in USB adapter cable, and plugged the USB connector back into the full-size USB connector on the back of the RC. (Note: iPad or iPhone is now cabled directly to the RC (normal cable configuration).
16. I clicked on CAMERA on DJI GO app screen and this brought up the live video screen from the P4. At this point, you can power everything off and back on again, if you wish.
17. No more "firmware update required", but now I got a message indicating COMPASS ERROR, so I took P4 outside and performed COMPASS CALIBRATION.
18. Powered OFF P4, RC and iPad.
19. Powered ON RC (iPad turned on by itself) and restarted DJI GO app.
20. Powered on P4 - after a minute or so DJI GO app indicates aircraft is connected.
21. Press CAMERA icon on DJI GO main app screen and camera screen with live video image from P4 is displayed.
22. BE SURE TO GO THROUGH EVERY MENU AND SET ALL OPTIONS TO YOUR PREFERRED SETTINGS INCLUDING:
- Set Return to Home Altitude
- Imperial vs. Metric Units of Measure
- Camera Photo and Video settings
- Enable Hardware Decoding
- Enable Multiple Flight Mode
- Set Maximum Flight Altitude (20-500M)
- Smart Go Home (ON or OFF)
- Set new Visual Navigation System Settings
I hope this helps others that might be struggling with first P4 firmware update.
- Dave |
