Phantom 3 Series firmware update
1234567
30035 273 2016-3-15
digdat0
Flight distance : 11896378 ft
carsforlife150 Posted at 2016-3-19 21:59
I clicked "go" ...my question is, how to update it? Via app or SD card?
http://youtu.be/aSPRLjnTwc4
Try that vid, will go step by step.
2016-3-19
patryshoek
carsforlife150 Posted at 2016-3-19 15:56
Ok, so I'm new one here and don't know a sh*t about updating new firmware. Bought my new P3A no more ...
Bought my P3A two months ago and the firmware was updated in shop (V01.06.0040). Now I get the message to update to the latest version but, reading about all the different problems people have, I am worried (if not scared) to follow this suicide mission. Why can't DJI do what, for example, cellphone companies do to give you the option to update (upgrade) your fw - it's your choice if you want to or not. If you are happy with your current fw, leave it. Don't fix it if it is not broken! I'm also a newbie and don't want to end up with a $1600 paper weight (=ZAR20000.00 - that is the price tag in South Africa because ot the current exchange rate).
2016-3-19
Larsaunitz
Flight distance : 384406 ft
As I wrote earlier the test flight went well.
I will try another run tomorrow if weather is okey.
App Vesion 2.7.1
Aircraft 1.4.6.0+
Dont know where to check the remote controller version.
2016-3-19
mjlstudios
Flight distance : 1540131 ft
digdat0@gmail.c Posted at 2016-3-19 11:12
If your RC version is below v1.3 DO NOT FOLLOW THE INSTRUCTIONS WHEN UPGRADING THE RC If your RC version is v1.3 or higher upgrade your RC through the GO app only.
2016-3-19
mjlstudios
patryshoek Posted at 2016-3-19 12:04
Bought my P3A two months ago and the firmware was updated in shop (V01.06.0040). Now I get the mes ...
You don't have to update. You can keep the firmware you are using now.
2016-3-19
TomWolves
Flight distance : 110577 ft
Hello DJI-Tim, could you tell me what the latest version of the remote controller is? what I have now is 1.5.70 is this the latest one? Thank you for your time.
2016-3-19
Mr.buGSy
Flight distance : 820712 ft
Hi all,
I can also confirm the vibration issue. Just upgraded the firmware and it keeps vibrating like crazy while hovering. I preformed an IMU recalibration, but the problem prissiest. What the hell happened? I don't dare to fly it like I normally do, only a few meters of the ground.  I'm kind of disappointed. Please fix this DJI. I'm hoping that I don't have downgrade the firmware to fix the issue...
p.s It's not a "unbalanced props" issue!
2016-3-19
Donnie
Flight distance : 3636782 ft
TomWolves Posted at 2016-3-19 13:43
Hello DJI-Tim, could you tell me what the latest version of the remote controller is? what I have no ...
  I assume you are flying the Phantom Advance or Pro Correct ?  The RC Transmitter should be 1.5.80.  Look on the  general settings "About "  and confirm this.  The DJI go App will tell you if you need the update.
Hope this helps - Donnie
2016-3-19
mizzle09
Nightingale Posted at 2016-3-15 11:38
Getting weak RC signal inside with RC next to my Phantom. Is this normal?
Same here. Signal bounces between 'good' and 'poor'. I don't believe it did that prior to the firmware update...
2016-3-19
TomWolves
Donnie Posted at 2016-3-19 15:39
I assume you are flying the Phantom Advance or Pro Correct ?  The RC Transmitter should be 1.5.8 ...
yes, I'm flying Phantom3 ADV. I had to restart my app, when I did it said update required. Thank you! How do I get to the Follow me, Point of interest( POI), and Waypoints. I could not find it on the new Go app? Thank you for your help.
2016-3-19
Donnie
TomWolves Posted at 2016-3-19 15:03
yes, I'm flying Phantom3 ADV. I had to restart my app, when I did it said update required. Thank y ...
  First you must enable "Mult Flight mode" in the DJI go app under MC (aircraft) settings.  Then it is kind of silly but you must be in the air to acces these settings.  Get in a Hover about 40 feet high (At least) and out a bout 100 feet in front of you, then flip the toggle from GPS mode"P"  down to "F" mode.  Here you will have access to POI, Way-points, Follow Me .  Now follow me can only be used if you have active gps on your device.  And Way-points must be flown first and then recorded,  this can be used for future use.  To close out of "F" mode simply toggle back to "P"  it just takes some time using these settings.  You can not access them unless you are in the air "DUMB".  They say they will change it in the future.
Hope this helps,-  donnie                                domaldjames1990@gmail.com   if you have other questions and cant find then here, i will try to help
2016-3-19
Donnie
mizzle09 Posted at 2016-3-19 15:01
Same here. Signal bounces between 'good' and 'poor'. I don't believe it did that prior to the firm ...
If the Aircrafat is  right next to Trasmitter   the signal is getting"SWAMPED", keep them a few feet apart and should be OK.
Hope this helps- donnie
2016-3-19
al_greenfield
Looking for HELP .. I put this post up about 3-4 mins ago ::
Hello All
I turned on my Bird today to find that there was a Firmware Update.  I started that update and at 75% complete I lost power ... Battery should of been charged!  I turned everything off and charged the battery and the transmitter.  I went back into the dji Go app , turned on the transmitter & bird !  Now the Bird is doing a repeatedly BEEP, BEEP, BEEP it jus keeps going  Loud ..  No lights come on !  The tablet still works as I have the video feed, GPS location, Gimbal works but the Bird with not arm.  I figured I would reload the Update but now that line reads "No Firmware Update" ... and the Bird is still beeping!
I contacted (via Email)) dji but today is Saturday and they are not open.  Has anyone else had this problem?  I there a way to fix it?  I put a volt meter on the battery and it has full charge.
If someone is willing to help I will make a video and post it to YouTube if needed!
Let me know .... Thanks
Do you know of this and is there any way to fix it.?
2016-3-19
powersofts
The last weeks I was reading a lot of articles about the firmware update issues. Today I gave it a go. I went from firmware v1.4 to 1.7 with my p3A.
I did this in 2 steps:
1) form 1.4 to 1.6      (because of the battery update in 1.6)
2) 1.6 -> 1.7.60
The RC went from 1.5.7 ->  1.5.80 earlier today, also without problems.
Updates went without any problems up till now.
Tomorrow when the battery is full and ice-cold I will do the calibrations of IMU, gimbal, remote controller and the compass.
Happy with this so far.
Up to date today
Up to date today
2016-3-19
patryshoek
mjlstudios@yaho Posted at 2016-3-19 19:40
Thanks for the feedback. Will do so.
2016-3-20
DutchDrone
I got vibratings issues after the update of the DJI Phantom 3 Standard
Really unusable videos now..
please DJI give me a fix
2016-3-20
Nicola90s
Flight distance : 3060869 ft
DutchDrone Posted at 2016-3-20 18:51
https://www.youtube.com/watc ...
Did you done IMU and gimbal calibration?
2016-3-20
scooterman
al_greenfield@m Posted at 2016-3-19 20:47
Hello All
I have the same problem but mine updated and now bleeps continually !! i have also emailed Dji
2016-3-20
carsforlife150
Croatia
digdat0@gmail.c Posted at 2016-3-19 16:12
Thank you! I will try it!
2016-3-20
ssunman
waynegknott Posted at 2016-3-15 22:21
one other issue I have is that when you go to about when it does connect all I get is the version 1. ...
  Similar situation here....I do see the the app version (version 2.7.1) the aircraft (version 1.4.60+) , which is not the 1.6.40+ I've seen elsewhere in this thread,  and the flight controller serial number.  I did the update on my Standard the other day with success, according the the log.  Another thing I've noticed since the app update is that I cannot find where to calibrate the compass.  This used to come up immediately.
What am i missing here?
2016-3-20
Not A Speck Of
Flight distance : 666493 ft
al_greenfield@m Posted at 2016-3-19 13:47
Hello All
Try to reload the firmware regardless of what the Go app says using this method:
  • Turn off the RC and Go App.
  • Download the 1.7.x zip from the DJI site:
    http://dl.djicdn.com/downloads/phantom_3/P3X_FW_V01.07.0060.zip
  • Unzip and extract the BIN file from the ZIP
  • But the BIN file on an SD card that has plenty of free space afterwards
  • With a fully charged battery, turn on the bird
  • Let it beep for at least 30 minutes. For this step, you can put the bird in the basement or a closet to reduce the annoying beeps.
  • After that long period, turn it off and check the .TXT file on the SD card. Scroll to the bottom to see if you have a Success message. Turn the craft back on to be sure it no longer beeps.
This is what I did when I stopped the firmware process before it was complete and it worked.
Speck
2016-3-20
klauw004
DutchDrone Posted at 2016-3-20 11:51
Here exactly the same since 1.3 software after each update again a problem there at now again weak signal and trembling he does long the P3A
2016-3-20
klauw004
2016-3-20
Barney Rubbel
Not A Speck Of  Posted at 2016-3-20 23:17
This is what I am doing, except there is no beeping. I turned it on with the .bin file on the SD.  It goes through its little boot up, and then the camera update starts (flashing green/red) and then turns green. All this time, the front arms flashing white (possibly because not connected to controller, I'll have to look into that). I let it run for about 45 minutes, shut it off and looked for a txt file, but the only one there was from the last successful update. Nothing from today. I'm trying it a second time now, and will let it run until the battery is running out unless I hear the finish beeps. I only saw that it would beep at the end, not throughout the process though. Thoughts?
Thanks!   Barney
2016-3-20
rreindl
Flight distance : 6491926 ft
I updated my P3A  and iPad  Air 2 with the latest firmware and software and now having my video recordings are stopping randomly. I hear the same sound as when you start or stop the video on my iPad.
Yesterday on battery one, the first flight after the updates the video stopped three times. Battery two and three had no issue. Battery four had the same issue as battery one but only stopped once. I recharged all batteries and tested battery one again with no issues. Today I had random stops on the first two batteries of the day (not sure which ones they were compared to yesterday).
Today's videos stopped after 12:27 on the first battery and after 1:40 on the second battery.
I see no other issues before the recordings randomly stop. The videos on the SD are in separate files as if they were stopped intentionally.
Has anybody else experience this or know a solution to fix it?
2016-3-20
wayne710
Flight distance : 6198 ft
after update the follow me mode will not work
2016-3-20
Vermontflyer
Hello, hoping someone can advise what I did wrong or if there is aprobelm with the firmware,
    followed the usualy firmware thought I did eberything right but when I put the sd card in the drone it does the normal start up and never goes into the update process with the ddd-ddd etc. I left it running for 30 minutes and nothing.
Tried deleteing it off the card then reinstalling it and same results.
   never had this happen before always had succes on firmware updates.
could it be a corruped card now even though I did nothing to it.
one note is my pc recently updated to Windows 10 and I get  popup when I put the sd card in that says -
Photogallery
X an error is prventing photo or video from being displayed error code O x8000000A
any help would be greatly appreciated !
   cheers
[00013342]========== 2016.03.06 10:43:04. boot(15) ============
[00013420]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x80ce6499].
[00013486]Packet upgrade start...
[00013566]Packet checking...
[00013638]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013713]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013787]Done.
[00013858]Version checking[1]...
[00013976][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014097][03 06][00] v2.4.10.7 -> v2.4.10.7
[00014183][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014336][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014476][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014600][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014725][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014859][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015045][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015161][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015324][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015414][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015485][01 00][00] v1.26.4315 -> v1.26.4315
[00015563][01 01][00] v1.26.4315 -> v1.26.4315
[00015646][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015756][09 00][00] v2.13.0.0 -> v2.13.0.0
[00015823]Packet upgrade cancelled at version checking.
[00013358]========== 2016.03.19 11:19:03. boot(15) ============
[00013502]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x80ce6499].
[00013580]Packet upgrade start...
[00013655]Packet checking...
[00013736]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013805]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013883]Done.
[00013954]Version checking[1]...
[00014080][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014194][03 06][00] v2.4.10.7 -> v2.4.10.7
[00014273][04 00][00] v1.41.0.0 -> v1.41.0.0
[00019415][11 00][00] v1.7.15.1 -> v1.7.15.1
[00019536][12 00][00] v1.10.0.0 -> v1.10.0.0
[00019640][12 01][00] v1.10.0.0 -> v1.10.0.0
[00019766][12 02][00] v1.10.0.0 -> v1.10.0.0
[00019886][12 03][00] v1.10.0.0 -> v1.10.0.0
[00020054][15 00][00] v1.1.2.0 -> v1.1.2.0
[00020184][17 00][00] v1.1.1.7 -> v1.1.1.7
[00020338][17 01][00] v1.0.2.7 -> v1.0.2.7
[00020424][19 00][00] v1.0.8.96 -> v1.0.8.96
[00020494][01 00][00] v1.26.4315 -> v1.26.4315
[00020567][01 01][00] v1.26.4315 -> v1.26.4315
[00020656][08 00][00] v0.13.0.7 -> v0.13.0.7
[00020764][09 00][00] v2.13.0.0 -> v2.13.0.0
[00020836]Packet upgrade cancelled at version checking.
2016-3-20
CC8877
Flight distance : 51093 ft
This is the issue I have after update my Phantom 3 Advanced:
2016-3-20
Not A Speck Of
Barney Rubbel Posted at 2016-3-20 09:39
This is what I am doing, except there is no beeping. I turned it on with the .bin file on the SD.  ...
No thoughts from me, if it's not beeping. At this point, you may have to wait for DJI to get back in the office on Monday and show them the contents of your text file.
2016-3-20
jaycee
China
rreindl Posted at 2016-3-21 02:50
I updated my P3A  and iPad  Air 2 with the latest firmware and software and now having my video reco ...
Same experience but no solution.
P3P. Two flights. Two batteries.  16 and 14 minutes each.
It's a test flight after the update to the latest FWs and GO App so I tried to record the video of the whole flight but I ended up with 2 videos for each flight instead.
2016-3-20
pgrover516
Banned
2016-3-20
rreindl
pgrover516 Posted at 2016-3-20 21:02
I had that out of the blue one day and had not done any updates but had before flying used the in  ...
Thanks. I was going to format the SD card but wanted to wait for feedback from this group in case I needed some file from the SD.
I did clear the video cache and a following battery did not have an issue but of course that is only one battery. If the issue does occur again I will format the SD card.
Oh one more thing the last video this occurred on the file was corrupt.
2016-3-21
jaycee
China
rreindl Posted at 2016-3-21 20:53
Thanks. I was going to format the SD card but wanted to wait for feedback from this group in case  ...
Hi, I just checked my video files. Once the video size reaches 3.91 GB, it is saved to the micro SD card but the camera continuous to record using a new file. My "issue" has nothing to do with the new FW or formatting of the SD card in the Phantom and might be totally unrelated to your problem.
Cheers
2016-3-27
rreindl
jaycee Posted at 2016-3-27 07:20
Hi, I just checked my video files. Once the video size reaches 3.91 GB, it is saved to the micro S ...
I formatted my SD and flew using all batteries twice ( I have 4 batteries) and have not seen the issue with my recordings stopping randomly.
As normal the files do break up after 4 GB but continue to record.
I did get a request for another  firmware upgrade needed by the RC which was strange because I already updated and confirmed it was upgraded days ago.
2016-3-27
1234567
