You must update both the Aircraft and the RC for everything to work on this particular update . Also Capt Russ. If you just bought a battery You can update it with the new FW. I would just do my update with the new battery pack installed and then it will be updated . Then after success upload, you can place any additional battery packs and begin the process again, it will only take a couple of minutes this time. As far as deleting the Go App, keep in mind the update is for android devices only this time. (Be sure to Uninstall the old one completly first ) also you can symc if you wish , go to the GO App and select "Me" then go to "Flight Records" and sync. You wont have much but sync if you want Be sure to save any flights you may want to keep . Also most of the settings are stored in the aircraft but still look them over and after the update be sure nothing changed. Be sure to check the RTH "Return To Home" settings and the RTH height as well. I am going to add my tips page for those who may need the help.
TIPS For Phantom Advanced and Pro Uploading firmware: Updates will look like this when complete: MUST UPDATE RC AND AIRCRAFT FOR 4-7 2016 UPDATE 1.8 App version 2.71 ( Android 2.72) Aircraft version 1.8.80 or the old FW with a + RC version 1.6.0 If you have a + sign after the old firmware it means it has loaded but must get confimed with DJI servers. Make sure you have WI- FI internet connection ( Like during FW download) **This is still Not entirely figured out . Just know you can fly like this and you are updated. When I get more information I will post. I am talking with Tech assistance NOW April 7th to get answers.
- After 1.3 the update FOR the Transmitter is NOT through the SD Card it is through The DJI go app and WI-FI connection. MUST HAVE WI- FI CONNECTION WITH INTERNET ACCESS.
-Always update the aircraft first. This is Mandoatory in some cases during updates. For example on the Inspire 1 update 1.8 it must be done in this order to prevent problems with the landing gear. ALSO NEVER DO THE UPDATES AT SAME TIME, DO AIRCRAFT, STOP, TURN OFF AIRCRAFT AND DO THE RC.
-When updating theTransmitter , use a dedicated reliable WI-FI system. Avoid using Cellular systems if possible (Phone calls , etc) You want to make sure to close all apps besides the GO App as well. Do NOT interupt the upload. Make sure the cable from the Transmitter to the Go App is Pristine and Perfect.
-Make sure you download the proper firmware. If you have the Pro make sure not downloading for the Advanced or Standard. Double check!
-Make sure you only download the Bin File to the FRESH FORMATTED SD CARD Root Directory. Root directory is just a fancy name for " Make sure it is not in a file or folder " Make sure the BIN file is the only thing on the SD card.
-Make sure transmitter is NOT on when downloading Firmware to aircraft (VERY IMPORTANT) and Aircraft is not on when uploading the Transmitter !
-When installing SD with firmware to the Aircraft, make sure it is off. Then turn on aircraft, the firmware will then begin load. 1- Load sd card with firmware to aircraft 2- turn on aircraft
-You can jump FROM 1.3 TO 1.6 or ** (1.8 ) BUT if you have any difficulty you must stair step from current firmware to get to the latest firmware. If at 1.2 must install 1.3 then you jump or stairstep to 1.7 .** I am getting conflicting reports and your best bet is to stop at 1.6 and do battery upgrades then go to1.7 ( I see a lot less problems when Pilots go in order.......Play it smart) This is much easier if you just stay up to date. If you have not done the battery updates you can do so with 1.7 or 1.8 as well.
-All the firmware numbers for the RC - aircraft- Go App - Camera WONT BE THE SAME. For example the current aircraft firmware is 1.8..80 but the RC Firmware is 1.6.0 )
-Sometimes only the aircraft gets an update and not RC Transmitter Read the pdf on the downloads page so you know what’s going on for example 1.6.0.40 was only for the aircraft and batteries
-Make sure to read what each update is effecting. For example 1.6.0.4.0 will require each battery to be updated as well. Keep Informed.
-Macs’ sometimes do not format SD cards well. When Formatting Success is in doubt FORMAT ON THE AIRCRAFT, go to camera settings on dji go app , open the tool icon , on bottom is Format SD card option.
When Updating on the aircraft you will hear a "Four beat tone" dddd-dddd-dddd-dddd-dddd-dddd-dddd-dddd-dddd-dddd-dddd-dddd-dddd and flashing gren and red lights .
-Updates sometimes take a while, wait for the tone to change to a " One beat pause two beat tone" d-dd d-dd d-dd d-dd d-dd d-dd d-dd or the solid green light even better. Now it is done ( Phantom Camera Gimbal Assembly )
-If you hear a long " No pause beat " dddddddddddddddddddddddddddddddddddddddddddddd update has failed. Try again. Remove SD card and Place in computer and look at the File "Result" or the Hidden file to get to the Nitty Gritty. Use search magnifying glass "Hidden File" tutorial.
-Updating is not an option for just the aircraft, IF there is also an update at that time for the Transmitter you MUST do it.
-To find out your current Firmware: Make sure The Aircraft, Transmitter, and GO-APP are all on. Now go to the “Main Video Flight Screen” , Tap the right hand corner for “ Settings” on the Very Left Bottom of tab icons you will see - - - this is the “ General Settings Go to “About “ Here you will find current Firmware on each device. If you only see the “App Version it is because you did not turn everything on .
-If you load the firware with success but it does not update in the “About” section on the Go App “General Settings” be sure to Re- Boot your Device with the Go App, also restart the aircraft and Transmitter .
-If you get a + sign after you install the firmware, (ie: 1.7.04.00+) It is OK, re-boot and make sure your device has wi-fi and internet access. It should update once it is up to date with DJI servers. ( This may take a couple days though because of all the updates) Once again waitign on DJI for exact cause.
-Make sure when you are powering up to fly you always do it in theis order : 1 RC Transmitter 2 Aircraft 3 Go app You can have your device ( I-pad ) "on" when you place it on the RC cradle but do NOT have that Go App opened up. Make sure you have no other apps opened in the backround. Be sure to "Enable Hardware Decode" on the go App. This takes some of the strain off the processor for better performance.
-Updates for the Phantom Standard are Only Done through GO-App and Wi-Fi, no SD Firmware to upload.
-Look over your "General Settings" after an update most of the settings are stored in the MC Master Control of the Aircraft but sometimes things change. Make sure the RTH Return To Home settings have not changed and the Umits of measure have not gone back to Metric or Imperial. I personally go through each page of the settings to be sure. - You cant Rollback the Battery Firmware once installed. Once Installed that’s it. ( Battery Only)
-When doing a Rollback, confirm the Current firmware on the Aircraft and then Rollback Firmware in Order. If at 1.6 you can only Rollback to 1.5. If at 1.7 can only rollback to 1.6 etc.
I hope this helps anyone struggeling , Please add your tips and I will add them to the list.
All the best to you and yours ![](//forum44.djicdn.com/static/image/smiley/default/handshake.gif) - donnie
