DJI-Ken
![](https://forum44.djicdn.com/data/attachment/common/c7/common_16_usergroup_icon.png) DJI team
Flight distance : 1515312 ft
For those who are having trouble with the firmware update on your P4 and getting RC Signal Lost it means that you do not have the update done on both the Aircraft (1.1.301) and RC 1.6). This means you probalbly uodated the RC first, If the aircraft will not take the update, you can update the aircraft through the Assistant2 PC or Mac program.
OR, downgrade the 1.6 RC firmware to 1.5.8. To do this, from the home page upper right corner is a graduation hat icon. That takes you into the Academy section of the app when you press it.
Have the RC on connected to the app and the aircraft OFF.
DO NOT give it a quick press, instead keep it pressed down for 5 seconds or so and let go. Then you will see the RC firmware downgrade to 1.5.8 page.
This should take care of the update, and it takes a wile to update the aircraft firmware.
