Loud beeping
123Next >
3276 106 2016-4-10
johnnym70
Flight distance : 162953 ft
Now the SD card will not take the new up date...
2016-4-10
RedHotPoker
Flight distance : 165105 ft
If the micro sd card has been formatted in the drone, it should be easy to copy and paste the bin file into the root of the sd card.
There must be something else stopping the process.
RedHotPoker
2016-4-10
johnnym70
Now the SD card will not take the new update.
2016-4-10
johnnym70
BRB I'm going to buy a new SD card...
2016-4-10
jlcase
Ever since I did the new update today the remote controller has just not worked.
if you turn the controller on after 30 seconds it starts beeping and will continue untill it turns itself off.
it wont connect at all with my P3P and after playing with it for a while I finnally got an error message.
it says battery not connected properly, this must be in the controller because it wont connect with my P3P.
every time I do an update per directions there is a problem and this time it is stupid I should have never done the update.
2016-4-10
Donnie
Flight distance : 3636782 ft
Ok now load that new Firmware with the Bin File Only .  Make sure of this fact.
Once loaded, install SD card into the Aircraft Then fire it up.
20 minutes or so the D-dd D-dd should sound.  Look at the light on Gimbal.  Should be solid green  .
Then check for success on the "SD card
Let me know -donnie
2016-4-10
Donnie
jlcase Posted at 2016-4-10 13:13
Drone updated but the controler is still wacked out.
Just beeps.
Jlcase, did you read my tips page ? Do you have the Transmitter on while updating the aircraft?  I sure hope not .
Can you tell what version on the about page you have loaded?
Looking for
2.71 for go app or 2.72 with android
1.8 for the aircraft and camera
1.6 for the Transmitter
Let me know - donnie
2016-4-10
johnnym70
after I updated the SD card on my Mac it won't take the new fw update? I just bought a new SD card still won't take the new fw update?
2016-4-10
Donnie
RedHotPoker Posted at 2016-4-10 15:50
If the micro sd card has been formatted in the drone, it should be easy to copy and paste the bin fi ...
RHP, I sure hope not .  He is updating with a mac and had more than just the Bin file on it when he tried to update.  also he is getting a" timed out " warning when he tries to format on the aircraft.  I have never seen that one before.  Do you use a MAC ?  if so maybe you can guide him.  I hate Macs for downloads.  always a problem  .
donnie
2016-4-10
Donnie
johnnym70 Posted at 2016-4-10 16:30
after I updated the SD card on my Mac it won't take the new fw update? I just bought a new SD card s ...
The aircraft wont take the update ?   or the Mac wont download the bin file ?
2016-4-10
johnnym70
Damn..it finally did it for some reason. Got the bin file on the SD card loading on the aircraft... installed and fired up aircraft. Still have loud beep. Its sounds like it loading. hard to hear over loud beeping thought.
2016-4-10
johnnym70
gimbal light is blinking red over green
2016-4-10
Donnie
johnnym70 Posted at 2016-4-10 16:36
Damn..it finally did it for some reason. Got the bin file on the SD card loading on the aircraft...  ...
What color are the lights flashing on the AC , are they red and green ?  does the tone have a bit of a beat to it? like eeee -eeee-eeee-eeee-eeee-eeee-eeee-eeee  or is solideeeeeeeeeeeeeeeeeeeeeeeeeeeee
The lights are more important than sound , and the result file trumps both.   Give it some time up to an hour.  Look for a solid green light , this will indicate finished.  then we can check log.
does it sound different than before ????  when it failed ??
2016-4-10
johnnym70
Yes the beep has a beat. Ok it stopped the beeping from hell as well! The gimble indicator is still blinking green/ red. The aircraft is making some noises(internal noise) and the gimbal is now solid green.
2016-4-10
Donnie
johnnym70 Posted at 2016-4-10 16:45
Yes the beep has a beat. Ok it stopped the beeping from hell as well! The gimble indicator is still  ...
You are almost  golden  now.  Make sure that you check the sd card for success.  Also  you can look at the go app about page and make sure it is 1.8  .
the tone will be d-dd d-dd d-dd d-dd d-dd d-dd d-dd d-dd amd solid green light means done
2016-4-10
johnnym70
Actually this is the point I was at when i tied to update the fw the 1st time. D-DD D-DD D-DD and the gimbal is solid green now. can I shut it off? I'm scared LOL
2016-4-10
Donnie
That is about the right amount of time to 15- 20 min  for the average update.
2016-4-10
Donnie
Borrow a friends pc in the future or make a Note of EXACTLY what you did with the MAC because this should be  a 1-2-3-4 procedure and you are done.
donnie
2016-4-10
johnnym70
Ok Cool! the SD card is saying Success! Thank You Brother! no what about the RC?
2016-4-10
johnnym70
Thanks' again....You the Man Callahan!
2016-4-10
walsher
Phantom Standard flew just fine yesterday and today said we needed to update the firmware. We started the update and got to 40% and is got stuck so turned it off even though it said not to....oops.  Tried it again a little while later and it got to 60% and got stuck and turned it off again...no patience I guess.  Now it just beeps loudly.  Just formatted the SD card and still beeps.  Need some help.  PLEASE!!!
2016-4-10
Donnie
johnnym70 Posted at 2016-4-10 16:51
That should already be done, I thought you said that was done ?  It should be a t 1.6
check the about page of go app with ALL on , like about to fly
1.8 for aircraft and camera  1.6 for RC and 2.71 for go app   or 2.72 android
2016-4-10
johnnym70
Yep and Yep! if you don't get paid for this you should!
2016-4-10
jlcase
I did the update to the remote without the P3 being on.
I am using android
did the P3 with no problems
the controller is what I am having problems with
30 seconds no beeps then it will beeps untill it powers off on its own.
it was all working great before I did the update. I flew it this morning all good now it does not see the drone at all and just continues to beep.
it wont give me an ABOUTat all
2016-4-10
Donnie
walsher Posted at 2016-4-10 16:54
Phantom Standard flew just fine yesterday and today said we needed to update the firmware. We starte ...
Remeber Phantom standard is NOT updated through sd card .  It is Wi-FI only.  Make sure you have a solid Internet Wi FI signal and try again.. I  am only expert at advanced Pro and Inspire,  I am sorry .  Do not use cell system for downloads !!!
Good luck  donnie
2016-4-10
johnnym70
Donnie,
just checked all Aircraft, RC, and App are all the correct versions!
We are golden!!
Thanks' again!!
2016-4-10
Donnie
johnnym70 Posted at 2016-4-10 16:56
I dont but tell that to DJI ken , he will get a kick out of that !  Glad you are up and running.
Cheers - donnie
2016-4-10
walsher
Donnie Posted at 2016-4-11 05:58
Remeber Phantom standard is NOT updated through sd card .  It is Wi-FI only.  Make sure you have a  ...
OK thanks.  How do we update the Aircraft itself?
2016-4-10
Donnie
jlcase Posted at 2016-4-10 16:57
I am using android
did the P3 with no proble ...
Ok what color is the light on the Transmitter ( controler ) with aircraft off, is it blue or red ?
2016-4-10
johnnym70
Will do... I think i have a few extra gray hairs from the beep from hell!
Pease
Johnny Mo
2016-4-10
jlcase
Donnie I cant find a download for 1.6 for the controller
All I get for errors is a battery error
2016-4-10
johnnym70
Peace
Johnny Mo
2016-4-10
Donnie
I am using android
Keep in mind if it has low battery it will beep and if the sticks are not moved it will beep after  about 4 min.
If you want my help please answer all my questions please,  did the update go ok  on the Aircraft ?  What version did you jump from 1.7 to 1.8 ?  Was the transmitter on when you updated the aircraft ?
Is the transmitter charged right Now ? if so how much ?
donnie
2016-4-10
jlcase
Donnie Posted at 2016-4-10 18:03
Ok what color is the light on the Transmitter ( controler ) with aircraft off, is it blue or red ? ...
after 30 seconds red
2016-4-10
Donnie
I am using android
In the future do not have the aircraft on when updating the transmitter  and DEFINITLEY  do not have the transmitter or when updating the aircraft, this can cause damage to the Video Transmission Board.
Also did you update the RC  through the go app?  or did you use another method ?
2016-4-10
jlcase
Donnie Posted at 2016-4-10 18:08
Keep in mind if it has low battery it will beep and if the sticks are not moved it will beep after ...
I went from 1.7 to 1.8 because I was flying and it came on the screen I needed to update. the controller was the only thing on when I did the update from wifi. it gave all indications as being done, battery was just charged this morning.
The update on the aircraft went perfect as far as I know, havent been able to fly it yet. the transmitter was not on when I updated the aircraft.
when I turn the transmitter on all four lights lite up.
I used the go app
2016-4-10
jlcase
I just turned on the controller red light no sound for 30 seconds then red light starts blinking and the beeping starts.
2016-4-10
Donnie
jlcase Posted at 2016-4-10 17:15
I went from 1.7 to 1.8 because I was flying and it came on the screen I needed to update. the contr ...
Ok , so when you did the update to the RC on the go app did it go to the end and say success ?
The beeping could just be low battery on the RC or if the RC sits for a few minutes it will beep .
can you go to the about page with everything on and read me what it says for each version
example does it say 1.6 for RC and 1.8 for Aircraft and camera and 2.71 for go app.
also very important when you turn on EVERYTHING like about to fly what color is the Transmitter light
is ist red or green.  It should be green if hooked up to the aircraft.
I just dont want to start re loading FW if we dont need to.
2016-4-10
Donnie
I wonder if you give the RC a solid charge of 8 hours, your problem of beeping will go away.
if you have 1.6 on the RC and 1.8 for the AC and camera and 2.71 for go app.  That will be my recommendation, charge the transmitter battery.
donnie
2016-4-10
jlcase
Donnie Posted at 2016-4-10 18:24
yes it said success
controller indicates 4 white lights full battery
cant get to the about page (wont open)
transmitter light is only red wont connect to aircraft
2016-4-10
123Next >
