Firmware Update Fail... CONSTANT BEEPING?!?!
6699 13 2016-5-20
liveloudstudios
I am trying to update my firmware to the latest v1.8.80,   And every time I try, it gets about 3 minutes into it, and then just starts screeching at me with a constant tone and the yellow lights blinking really fast! I have tried installing earlier versions, I have formatted my SD card, I have updated my controller, and I literally have no idea what is happening. I left it doing the screeching thing for about 30 minutes and nothing changed. PLEASE HELP! thanks!
2016-5-20
Dioden
Take down a new file, file could be corrupted, one byte wrong is enough
2016-5-20
bnwitt
What device are you using to update the unit?  This is what happened to me.  First I tried updating near my computer.  Too much interference from the monitors.  Then I moved to a different part of the house and the update started working but kept stopping at a different percentage of completion multiple times.  I figured out that my Samsung phone was disconnecting from the Phantom and reconnecting to my wifi router.  I could see it happening each time as the Phantom 3 picture in the go app would change to the default Inspire picture.  Each time it happened I had to go back into my settings and reconnect to the Phantom and the update continued until it finally hit 100%.
2016-5-20
Ricardo
Flight distance : 4356421 ft
Somewhere just in the last couple of days I thought I saw one of these forums, where you could force your update by making sure you have download the .bin file on a newly formatted sd-card, put in into the aircraft and upon turning it on you can hold-in the button on the camera (the one used to re-link your aircraft) and hold this in for a brief time and then it will force the aircraft to start the process over again. I hope I haven't steered you in the wrong direction here, maybe someone else could comment on this as well. And yes I think you would be better off getting away from any electronic devices before trying again. Good luck
2016-5-20
DJI-Paladin
Flight distance : 2408 ft
Hello liveloudstudios, please format the sd card and extract the 1.8.8 bin file to the card. Then upgrade the drone again. Keep your eyes on the camera indicator and ignore the annoying sound. Normally this process will take about 25 minutes. 升级指示灯.JPG
2016-5-20
johnstockdale57
DJI-Paladin Posted at 2016-5-21 04:02
Hello liveloudstudios, please format the sd card and extract the 1.8.8 bin file to the card. Then up ...
I have done exactly the same, attempted to upgrade to 1.8 and now have lost any RC link to my drone. Tried two differing sd cards, tried to load 1.8 with no success so then tried going back to 1.3. Also tried that cold start option suggested elsewhere, whereby you hold in the link button, start your aircraft and then release the button when you register the drive kick in, but all to no avail, now at wits end as seem to have lost the use of drone altogether.
2016-5-21
johnstockdale57
johnstockdale57 Posted at 2016-5-21 16:23
I have done exactly the same, attempted to upgrade to 1.8 and now have lost any RC link to my dron ...
Does anyone know of a good drone repairer in East Anglia
2016-5-21
liveloudstudios
DJI-Paladin Posted at 2016-5-20 23:02
I have done this exact process at least 10 times now... But I still get the constant D------------------- sound each time it starts to load the firmware. I have let it sit for 40 minutes making that sound and nothing changes... solid red light on the gimble... quick blinking yellow lights on the arms... I have no idea what else to do.
2016-5-23
grdarlington
Flight distance : 256929 ft
liveloudstudios Posted at 2016-5-23 15:48
I have done this exact process at least 10 times now... But I still get the constant D------------ ...
I had the same issue with a number of updates and discovered that it failed whenever I had the controller beside the quad.  When I have the controller away from the quad it works fine, about 3 metres.  Same thing happens when setting up to fly, as soon as I move a few metres away the signal is fine.
2016-5-23
grdarlington
I have had the same issue with a number of updates. I think it is a loss of signal from the controller, it turns from green to red showing a loss of connection.  It only happened when the quad was beside the controller.  If the quad was a few metres from the controller (3m or more) it works fine.  I noticed the same issue when getting ready to fly.
Sorry double post!
2016-5-23
DJI-Paladin
liveloudstudios Posted at 2016-5-23 22:48
Feel free to post the LOG file here. When the camera Indicator is solid red, the upgrade has been failed.Here is the method of finding the LOG file.
1. Enable the option of viewing hidden files in your OS. Below are the websites where you can check how to show the hidden files in your PC.
For The Windows System:
http://windows.microsoft.com/en- ... den-files=windows-7
For The Mac System:
http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2.Enter the root directory of the SD card, then find the hidden folder MISC and enter it. There is LOG folder in it.
3.The LOG txt file is under the LOG folder.
2016-5-23
Kamek
Mexico
DJI-Paladin Posted at 2016-5-23 17:44
[00016801]========== remo-con disconnect. boot(15) ============
[00016934]Firmware [C:\DM368Fw.bin] detected, card sn [0x60ce0ad4].
[00016972][08 00] Firmware upgrade start...
[00522074][08 00] Firmware upgrade finished successfully.
[00522112]Done.
[00014783]========== remo-con disconnect. boot(15) ============
[00014820]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x28545fbb].
[00014856]Packet upgrade start...
[00014896]Packet checking...
[00014936]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015005]Done.
[00015041]Version checking[1]...
[00015120][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015200][03 06][00] v2.3.0.13 -> v2.4.20.28 need upgrade.
[00015257][04 00][00] v1.41.0.0 -> v1.48.0.0 need upgrade.
[00015360][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00015460][11 01][00] v1.7.0.0 -> v2.0.0.33 need upgrade.
[00015534][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015615][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015700][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015801][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00028341][15 00][00] device not detected.
[00028429][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028549][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028603][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028641][01 00][00] v1.23.3419 -> v1.32.5432 need upgrade
[00028675][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00041210][08 00][00] device not detected.
[00041284][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00041321]Done.
[00043359]Waiting for user confirm...
[00053397]Timeout, start upgrade automatically.
[00053478]Firmware upgrading[1]...
[00064066][01 00] Firmware upgrade start...
[00014136][01 00] Firmware upgrade finished successfully.
[00014180]Done.
[00014216]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0x28545fbb].
[00014257]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014326]Version checking[2]...
[00014405][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014485][03 06][00] v2.3.0.13 -> v2.4.20.28 need upgrade.
[00014649][04 00][00] v1.41.0.0 -> v1.48.0.0 need upgrade.
[00014765][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00014886][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00014924][11 01][00] v1.7.0.0 -> v2.0.0.33
[00015015][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015106][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015215][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015295][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00027845][15 00][00] device not detected.
[00027930][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028050][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028106][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028144][01 00][05] v1.32.5432 -> v1.32.5432
[00028188][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00040732][08 00][00] device not detected.
[00040787][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00040825]Done.
[00040868]Firmware upgrading[2]...
[00041016][01 01] Firmware upgrade start...
[00071310][01 01] Firmware upgrade finished successfully.
[00071372][12 00] Firmware upgrade start...
[00134386][12 00] Firmware upgrade finished successfully.
[00134446][12 01] Firmware upgrade start...
[00194778][12 01] Firmware upgrade finished successfully.
[00194839][12 02] Firmware upgrade start...
[00255226][12 02] Firmware upgrade finished successfully.
[00255279][12 03] Firmware upgrade start...
[00318787][12 03] Firmware upgrade finished successfully.
[00318835][11 00] Firmware upgrade start...
[00367282][11 00] Firmware upgrade finished successfully.
[00367531][03 06] Firmware upgrade start...
[00742587][03 06] Firmware upgrade finished successfully.
[00742649][09 00] Firmware upgrade start...
[00806699][09 00] Firmware upgrade finished successfully.
[00806762][04 00] Firmware upgrade start...
[00865394][04 00] Firmware upgrade finished successfully.
[00865435]Done.
[00865473]Version checking[3]...
[00865558][03 05][00] v34.2.0.9 -> v34.2.0.9
[00865638][03 06][05] v2.4.20.28 -> v2.4.20.28
[00865797][04 00][05] v1.48.0.0 -> v1.48.0.0
[00865918][11 00][05] v1.8.0.0 -> v1.8.0.0
[00866038][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00866077][11 01][00] v1.8.0.0 -> v2.0.0.33
[00866167][12 00][05] v1.11.0.0 -> v1.11.0.0
[00866258][12 01][05] v1.11.0.0 -> v1.11.0.0
[00866347][12 02][05] v1.11.0.0 -> v1.11.0.0
[00866443][12 03][05] v1.11.0.0 -> v1.11.0.0
[00878980][15 00][00] device not detected.
[00879069][17 00][00] v1.1.1.7 -> v1.1.1.7
[00879187][17 01][00] v1.0.2.7 -> v1.0.2.7
[00879242][19 00][00] v1.0.8.96 -> v1.0.8.96
[00879282][01 00][05] v1.32.5432 -> v1.32.5432
[00879321][01 01][05] v1.32.5432 -> v1.32.5432
[00891864][08 00][00] device not detected.
[00891923][09 00][05] v3.0.0.10 -> v3.0.0.10
[00891965]Packet upgrade failed at version checking.
[00015001]========== remo-con disconnect. boot(15) ============
[00015042]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x28545fbb].
[00015080]Packet upgrade start...
[00015134]Packet checking...
[00015174]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015244]Done.
[00015285]Version checking[1]...
[00015360][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015420][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015471][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015580][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015700][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015739][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015832][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015910][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015984][12 02][00] v1.11.0.0 -> v1.11.0.0
[00016080][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028626][15 00][00] device not detected.
[00028705][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028824][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028870][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028912][01 00][00] v1.32.5432 -> v1.32.5432
[00028956][01 01][00] v1.32.5432 -> v1.32.5432
[00041494][08 00][00] device not detected.
[00041551][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041696]Packet upgrade failed at version checking.
[00050346]========== 2017.05.15 12:04:32. boot(15) ============
[00050393]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x28545fbb].
[00050430]Packet upgrade start...
[00050472]Packet checking...
[00050512]Packet vlink 01.10.0090 <-> 01.10.0090.
[00050579]Done.
[00050614]Version checking[1]...
[00050685][03 05][00] v34.2.0.9 -> v34.2.0.9
[00050766][03 06][00] v2.4.20.28 -> v2.4.20.28
[00050806][04 00][00] v1.48.0.0 -> v1.48.0.0
[00050925][11 00][00] v1.8.0.0 -> v1.8.0.0
[00051046][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00051081][11 01][00] v1.8.0.0 -> v2.0.0.33
[00051150][12 00][00] v1.11.0.0 -> v1.11.0.0
[00051250][12 01][00] v1.11.0.0 -> v1.11.0.0
[00051345][12 02][00] v1.11.0.0 -> v1.11.0.0
[00051414][12 03][00] v1.11.0.0 -> v1.11.0.0
[00063949][15 00][00] device not detected.
[00064031][17 00][00] v1.1.1.7 -> v1.1.1.7
[00064153][17 01][00] v1.0.2.7 -> v1.0.2.7
[00064210][19 00][00] v1.0.8.96 -> v1.0.8.96
[00064246][01 00][00] v1.32.5432 -> v1.32.5432
[00064279][01 01][00] v1.32.5432 -> v1.32.5432
[00076812][08 00][00] device not detected.
[00076876][09 00][00] v3.0.0.10 -> v3.0.0.10
[00076909]Packet upgrade failed at version checking.
[00014692]========== remo-con disconnect. boot(15) ============
[00014735]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x28545fbb].
[00014773]Packet upgrade start...
[00014817]Packet checking...
[00014869]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014937]Done.
[00014975]Version checking[1]...
[00015053][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015141][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015193][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015321][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015453][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015496][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015587][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015664][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015872][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015973][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028521][15 00][00] device not detected.
[00028624][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028743][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028797][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028845][01 00][00] v1.32.5432 -> v1.32.5432
[00028887][01 01][00] v1.32.5432 -> v1.32.5432
[00041432][08 00][00] device not detected.
[00041499][09 00][00] v3.0.0.10 -> v3.0.0.10
2017-5-15
fans775bca9a
Flight distance : 200584 ft
Peru
hello
After updating the firmware from 1.4 to 1.9; I can no longer have connection with my Phamtom 3 Professional.
[00016815]========== remo-con disconnect. boot(15) ============
[00016952]Firmware [C:\DM368Fw.bin] detected, card sn [0x40ce1f0a].
[00016985][08 00] Firmware upgrade start...
[00522182][08 00] Firmware upgrade finished successfully.
[00522221]Done.
[00012687]========== remo-con disconnect. boot(15) ============
[00012725]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xa0ce7eca].
[00012758]Packet upgrade start...
[00012797]Packet checking...
[00012836]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012906]Done.
[00012939]Version checking[1]...
[00013019][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013099][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00013139][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00013194][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013319][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013409][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013513][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013614][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013714][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013861][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013950][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014069][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014114][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014151][01 00][00] v1.23.3419 -> v1.23.3419
[00014186][01 01][00] v1.23.3419 -> v1.23.3419
[00014244][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014278]Done.
[00016318]Waiting for user confirm...
[00026353]Timeout, start upgrade automatically.
[00026429]Firmware upgrading[1]...
[00026485][12 00] Firmware upgrade start...
[00091343][12 00] Firmware upgrade finished successfully.
[00091396][12 01] Firmware upgrade start...
[00154258][12 01] Firmware upgrade finished successfully.
[00154317][12 02] Firmware upgrade start...
[00220462][12 02] Firmware upgrade finished successfully.
[00220513][12 03] Firmware upgrade start...
[00284755][12 03] Firmware upgrade finished successfully.
[00284967][03 06] Firmware upgrade start...
[00626472][03 06] Firmware upgrade finished successfully.
[00626645][04 00] Firmware upgrade start...
[00684778][04 00] Firmware upgrade finished successfully.
[00684816]Done.
[00684852]Version checking[2]...
[00684933][03 05][00] v34.2.0.9 -> v34.2.0.9
[00685012][03 06][05] v2.3.0.13 -> v2.3.0.13
[00685068][04 00][05] v1.41.0.0 -> v1.41.0.0
[00685116][09 00][00] v1.7.0.3 -> v1.7.0.3
[00685233][11 00][00] v1.7.0.0 -> v1.7.0.0
[00685306][12 00][05] v1.10.0.0 -> v1.10.0.0
[00685386][12 01][05] v1.10.0.0 -> v1.10.0.0
[00685487][12 02][05] v1.10.0.0 -> v1.10.0.0
[00685561][12 03][05] v1.10.0.0 -> v1.10.0.0
[00685700][15 00][00] v1.1.2.0 -> v1.1.2.0
[00685781][17 00][00] v1.1.1.7 -> v1.1.1.7
[00685921][17 01][00] v1.0.2.7 -> v1.0.2.7
[00685976][19 00][00] v1.0.8.96 -> v1.0.8.96
[00686018][01 00][00] v1.23.3419 -> v1.23.3419
[00686055][01 01][00] v1.23.3419 -> v1.23.3419
[00686099][08 00][00] v0.12.0.4 -> v0.12.0.4
[00686134]Packet upgrade finish successfully.
[00012460]========== 2015.10.13 10:08:23. boot(15) ============
[00012500]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xa0ce7eca].
[00012533]Packet upgrade start...
[00012576]Packet checking...
[00012612]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012647]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012688]Done.
[00012724]Version checking[1]...
[00012789][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012876][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012916][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012973][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013090][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013158][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013238][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013323][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013403][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013550][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013638][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013759][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013813][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013850][01 00][00] v1.23.3419 -> v1.23.3419
[00013884][01 01][00] v1.23.3419 -> v1.23.3419
[00014056][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014100]Packet upgrade cancelled at version checking.
[00012630]========== remo-con disconnect. boot(15) ============
[00012668]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00012708]Packet upgrade start...
[00012751]Packet checking...
[00012790]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012828]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012870]Done.
[00012907]Version checking[1]...
[00012978][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013039][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013082][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013147][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013278][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013348][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013447][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013538][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013612][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013750][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013823][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013944][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014008][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014046][01 00][00] v1.23.3419 -> v1.23.3419
[00014083][01 01][00] v1.23.3419 -> v1.23.3419
[00014141][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014176]Packet upgrade cancelled at version checking.
[00012474]========== 2015.10.13 10:14:36. boot(15) ============
[00012515]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00012550]Packet upgrade start...
[00012592]Packet checking...
[00012631]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012675]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012709]Done.
[00012747]Version checking[1]...
[00012835][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012911][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012955][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013017][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013110][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013205][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013302][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013508][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013582][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013736][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013816][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013941][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013987][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014028][01 00][00] v1.23.3419 -> v1.23.3419
[00014065][01 01][00] v1.23.3419 -> v1.23.3419
[00014123][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014161]Packet upgrade cancelled at version checking.
[00012498]========== 2015.10.13 10:15:30. boot(1) ============
[00012536]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00012578]Packet upgrade start...
[00012621]Packet checking...
[00012665]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012703]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012744]Done.
[00012783]Version checking[1]...
[00012872][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012953][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012995][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013071][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013192][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013309][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013405][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013479][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013732][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013819][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013937][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013997][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014037][01 00][00] v1.23.3419 -> v1.23.3419
[00014079][01 01][00] v1.23.3419 -> v1.23.3419
[00014139][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014175]Packet upgrade cancelled at version checking.
[00012482]========== 2015.10.13 10:22:03. boot(15) ============
[00012518]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00012554]Packet upgrade start...
[00012594]Packet checking...
[00012634]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012669]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012724]Done.
[00012780]Version checking[1]...
[00012997][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013093][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013140][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013192][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013335][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013431][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013531][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013630][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013732][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013872][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013961][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014081][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014152][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014192][01 00][00] v1.23.3419 -> v1.23.3419
[00014242][01 01][00] v1.23.3419 -> v1.23.3419
[00014293][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014335]Packet upgrade cancelled at version checking.
[00012775]========== 2015.10.13 10:45:06. boot(15) ============
[00012813]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00012849]Packet upgrade start...
[00012890]Packet checking...
[00012930]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012967]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013004]Done.
[00013040]Version checking[1]...
[00013119][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013199][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013246][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013304][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013419][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013518][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013618][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013719][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013819][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013962][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014059][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014188][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014285][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014325][01 00][00] v1.23.3419 -> v1.23.3419
[00014370][01 01][00] v1.23.3419 -> v1.23.3419
[00014421][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014467]Packet upgrade cancelled at version checking.
[00012692]========== 2015.10.14 10:04:10. boot(15) ============
[00012818]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00012860]Packet upgrade start...
[00012906]Packet checking...
[00012948]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012989]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013031]Done.
[00013073]Version checking[1]...
[00013165][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013245][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013288][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013361][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013486][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013594][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013695][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013789][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013874][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014810][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014891][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015039][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015099][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015138][01 00][00] v1.23.3419 -> v1.23.3419
[00015177][01 01][00] v1.23.3419 -> v1.23.3419
[00015229][08 00][00] v0.12.0.4 -> v0.12.0.4
[00015267]Packet upgrade cancelled at version checking.
[00012498]========== 2015.10.14 10:44:39. boot(15) ============
[00012541]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00012587]Packet upgrade start...
[00012630]Packet checking...
[00012672]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012716]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012760]Done.
[00012802]Version checking[1]...
[00012877][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012957][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013003][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013061][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013178][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013286][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013376][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013465][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013550][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013694][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013781][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014020][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014081][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014124][01 00][00] v1.23.3419 -> v1.23.3419
[00014166][01 01][00] v1.23.3419 -> v1.23.3419
[00014224][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014271]Packet upgrade cancelled at version checking.
[00012504]========== 2015.10.14 10:47:45. boot(15) ============
[00012547]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00012591]Packet upgrade start...
[00012639]Packet checking...
[00012683]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012724]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012771]Done.
[00012812]Version checking[1]...
[00012889][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012969][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013019][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013078][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013190][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013305][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013377][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013478][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013568][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013710][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013798][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013917][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013977][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014021][01 00][00] v1.23.3419 -> v1.23.3419
[00014063][01 01][00] v1.23.3419 -> v1.23.3419
[00014166]Packet upgrade cancelled at version checking.
[00014147]========== 2015.10.14 15:51:19. boot(15) ============
[00014237]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00014282]Packet upgrade start...
[00014336]Packet checking...
[00014385]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014433]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014480]Done.
[00014522]Version checking[1]...
[00014600][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014680][03 06][00] v2.3.0.13 -> v2.3.0.13
[00014736][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014789][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015027][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015126][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015209][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015295][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015395][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015557][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015629][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015755][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015809][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015852][01 00][00] v1.23.3419 -> v1.23.3419
[00015898][01 01][00] v1.23.3419 -> v1.23.3419
[00015967][08 00][00] v0.12.0.4 -> v0.12.0.4
[00016015]Packet upgrade cancelled at version checking.
[00013164]========== 2015.10.14 15:55:43. boot(15) ============
[00013210]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xb0ce6ca4].
[00013256]Packet upgrade start...
[00013308]Packet checking...
[00013356]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013401]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013447]Done.
[00013492]Version checking[1]...
[00013603][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013682][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013742][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013803][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013924][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014022][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014122][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014220][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014321][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014468][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014576][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014712][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014781][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014827][01 00][00] v1.23.3419 -> v1.23.3419
[00014878][01 01][00] v1.23.3419 -> v1.23.3419
[00014937][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014982]Packet upgrade cancelled at version checking.
[00015448]========== remo-con disconnect. boot(15) ============
[00015496]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x54e833b6].
[00015544]Packet upgrade start...
[00015601]Packet checking...
[00015768]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015821]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015869]Done.
[00015917]Version checking[1]...
[00016007][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016086][03 06][00] v2.3.0.13 -> v2.4.20.28 need upgrade.
[00016158][04 00][00] v1.41.0.0 -> v1.48.0.0 need upgrade.
[00016287][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00016426][11 01][00] v1.7.0.0 -> v2.0.0.33 need upgrade.
[00016526][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00016635][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00016735][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00016835][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00029383][15 00][00] device not detected.
[00029476][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029615][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029686][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029731][01 00][00] v1.23.3419 -> v1.32.5432 need upgrade
[00029781][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00042329][08 00][00] device not detected.
[00042408][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00042456]Done.
[00044504]Waiting for user confirm...
[00054551]Timeout, start upgrade automatically.
[00054656]Firmware upgrading[1]...
[00070246][01 00] Firmware upgrade start...
[00014435][01 00] Firmware upgrade finished successfully.
[00014488]Done.
[00014532]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0x54e833b6].
[00014581]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014635]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014682]Version checking[2]...
[00014769][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014869][03 06][00] v2.3.0.13 -> v2.4.20.28 need upgrade.
[00014922][04 00][00] v1.41.0.0 -> v1.48.0.0 need upgrade.
[00015049][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00015169][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00015215][11 01][00] v1.7.0.0 -> v2.0.0.33
[00015318][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015418][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015644][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00015742][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00028295][15 00][00] device not detected.
[00028398][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028569][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028631][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028675][01 00][05] v1.32.5432 -> v1.32.5432
[00028721][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00041270][08 00][00] device not detected.
[00041331][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00041377]Done.
[00041421]Firmware upgrading[2]...
[00041588][01 01] Firmware upgrade start...
[00071919][01 01] Firmware upgrade finished successfully.
[00071983][12 00] Firmware upgrade start...
[00133371][12 00] Firmware upgrade finished successfully.
[00133439][12 01] Firmware upgrade start...
[00195534][12 01] Firmware upgrade finished successfully.
[00195597][12 02] Firmware upgrade start...
[00256438][12 02] Firmware upgrade finished successfully.
[00256502][12 03] Firmware upgrade start...
[00321577][12 03] Firmware upgrade finished successfully.
[00321639][11 00] Firmware upgrade start...
[00368081][11 00] Firmware upgrade finished successfully.
[00368378][03 06] Firmware upgrade start...
[00732815][03 06] Firmware upgrade finished successfully.
[00732894][09 00] Firmware upgrade start...
[00785077][09 00] Firmware upgrade finished successfully.
[00785157][04 00] Firmware upgrade start...
[00842901][04 00] Firmware upgrade finished successfully.
[00842958]Done.
[00843006]Version checking[3]...
[00843105][03 05][00] v34.2.0.9 -> v34.2.0.9
[00843182][03 06][05] v2.4.20.28 -> v2.4.20.28
[00843250][04 00][05] v1.48.0.0 -> v1.48.0.0
[00843522][11 00][05] v1.8.0.0 -> v1.8.0.0
[00843649][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00843696][11 01][00] v1.8.0.0 -> v2.0.0.33
[00843790][12 00][05] v1.11.0.0 -> v1.11.0.0
[00843891][12 01][05] v1.11.0.0 -> v1.11.0.0
[00843996][12 02][05] v1.11.0.0 -> v1.11.0.0
[00844203][12 03][05] v1.11.0.0 -> v1.11.0.0
[00856761][15 00][00] device not detected.
[00856847][17 00][00] v1.1.1.7 -> v1.1.1.7
[00856968][17 01][00] v1.0.2.7 -> v1.0.2.7
[00857049][19 00][00] v1.0.8.96 -> v1.0.8.96
[00857104][01 00][05] v1.32.5432 -> v1.32.5432
[00857155][01 01][05] v1.32.5432 -> v1.32.5432
[00869703][08 00][00] device not detected.
[00869770][09 00][05] v3.0.0.10 -> v3.0.0.10
[00869817]Packet upgrade failed at version checking.
[00013214]========== remo-con disconnect. boot(15) ============
[00013267]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x54e833b6].
[00013319]Packet upgrade start...
[00013383]Packet checking...
[00013437]Packet vlink 01.10.0090 <-> 01.10.0090.
[00013491]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013549]Done.
[00013597]Version checking[1]...
[00013692][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013792][03 06][00] v2.4.20.28 -> v2.4.20.28
[00013866][04 00][00] v1.48.0.0 -> v1.48.0.0
[00014012][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014152][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014205][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014326][12 00][00] v1.11.0.0 -> v1.11.0.0
[00014452][12 01][00] v1.11.0.0 -> v1.11.0.0
[00014560][12 02][00] v1.11.0.0 -> v1.11.0.0
[00014665][12 03][00] v1.11.0.0 -> v1.11.0.0
[00027223][15 00][00] device not detected.
[00027337][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027477][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027547][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027598][01 00][00] v1.32.5432 -> v1.32.5432
[00027651][01 01][00] v1.32.5432 -> v1.32.5432
[00040212][08 00][00] device not detected.
[00040288][09 00][00] v3.0.0.10 -> v3.0.0.10
[00040341]Packet upgrade failed at version checking.
[00015030]========== remo-con disconnect. boot(15) ============
[00015087]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x54e833b6].
[00015137]Packet upgrade start...
[00015195]Packet checking...
[00015364]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015422]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015473]Done.
[00015528]Version checking[1]...
[00015630][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015730][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015788][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015930][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016065][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016117][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016226][12 00][00] v1.11.0.0 -> v1.11.0.0
[00016335][12 01][00] v1.11.0.0 -> v1.11.0.0
[00016434][12 02][00] v1.11.0.0 -> v1.11.0.0
[00016539][12 03][00] v1.11.0.0 -> v1.11.0.0
[00029098][15 00][00] device not detected.
[00029215][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029355][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029427][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029478][01 00][00] v1.32.5432 -> v1.32.5432
[00029535][01 01][00] v1.32.5432 -> v1.32.5432
[00042091][08 00][00] device not detected.
[00042167][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042223]Packet upgrade failed at version checking.
[00014942]========== remo-con disconnect. boot(15) ============
[00014999]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x54e833b6].
[00015055]Packet upgrade start...
[00015108]Packet checking...
[00015170]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015222]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015274]Done.
[00015333]Version checking[1]...
[00015430][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015532][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015590][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015731][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015872][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015926][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016039][12 00][00] v1.11.0.0 -> v1.11.0.0
[00016139][12 01][00] v1.11.0.0 -> v1.11.0.0
[00016244][12 02][00] v1.11.0.0 -> v1.11.0.0
[00016344][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028896][15 00][00] device not detected.
[00028995][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029240][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029330][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029381][01 00][00] v1.32.5432 -> v1.32.5432
[00029440][01 01][00] v1.32.5432 -> v1.32.5432
[00042000][08 00][00] device not detected.
[00042091][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042153]Packet upgrade failed at version checking.
[00065585]========== 2017.05.16 20:47:18. boot(15) ============
[00065644]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x54e833b6].
[00065696]Packet upgrade start...
[00065762]Packet checking...
[00065825]Packet vlink 01.10.0090 <-> 01.10.0090.
[00065880]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00065931]Done.
[00065992]Version checking[1]...
[00066087][03 05][00] v34.2.0.9 -> v34.2.0.9
[00066186][03 06][00] v2.4.20.28 -> v2.4.20.28
[00066243][04 00][00] v1.48.0.0 -> v1.48.0.0
[00066387][11 00][00] v1.8.0.0 -> v1.8.0.0
[00066526][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00066582][11 01][00] v1.8.0.0 -> v2.0.0.33
[00066695][12 00][00] v1.11.0.0 -> v1.11.0.0
[00066795][12 01][00] v1.11.0.0 -> v1.11.0.0
[00066896][12 02][00] v1.11.0.0 -> v1.11.0.0
[00067027][12 03][00] v1.11.0.0 -> v1.11.0.0
[00079584][15 00][00] device not detected.
[00079691][17 00][00] v1.1.1.7 -> v1.1.1.7
[00079831][17 01][00] v1.0.2.7 -> v1.0.2.7
[00079906][19 00][00] v1.0.8.96 -> v1.0.8.96
[00079967][01 00][00] v1.32.5432 -> v1.32.5432
[00080023][01 01][00] v1.32.5432 -> v1.32.5432
[00092577][08 00][00] device not detected.
[00092658][09 00][00] v3.0.0.10 -> v3.0.0.10
[00092714]Packet upgrade failed at version checking.
[00146662]========== 2017.05.16 20:50:38. boot(15) ============
[00146710]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x54e833b6].
[00146762]Packet upgrade start...
[00146819]Packet checking...
[00146875]Packet vlink 01.10.0090 <-> 01.10.0090.
[00146926]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00146976]Done.
[00147026]Version checking[1]...
[00147204][03 05][00] v34.2.0.9 -> v34.2.0.9
[00147284][03 06][00] v2.4.20.28 -> v2.4.20.28
[00147356][04 00][00] v1.48.0.0 -> v1.48.0.0
[00147484][11 00][00] v1.8.0.0 -> v1.8.0.0
[00147624][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00147677][11 01][00] v1.8.0.0 -> v2.0.0.33
[00147773][12 00][00] v1.11.0.0 -> v1.11.0.0
[00147874][12 01][00] v1.11.0.0 -> v1.11.0.0
[00147974][12 02][00] v1.11.0.0 -> v1.11.0.0
[00148074][12 03][00] v1.11.0.0 -> v1.11.0.0
[00160624][15 00][00] device not detected.
[00160708][17 00][00] v1.1.1.7 -> v1.1.1.7
[00160865][17 01][00] v1.0.2.7 -> v1.0.2.7
[00160933][19 00][00] v1.0.8.96 -> v1.0.8.96
[00160987][01 00][00] v1.32.5432 -> v1.32.5432
[00161039][01 01][00] v1.32.5432 -> v1.32.5432
[00173590][08 00][00] device not detected.
[00173675][09 00][00] v3.0.0.10 -> v3.0.0.10
[00173727]Packet upgrade failed at version checking.
[00012948]========== remo-con disconnect. boot(15) ============
[00013003]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x54e833b6].
[00013059]Packet upgrade start...
[00013114]Packet checking...
[00013172]Packet vlink 01.10.0090 <-> 01.10.0090.
[00013227]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013279]Done.
[00013335]Version checking[1]...
[00013410][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013510][03 06][00] v2.4.20.28 -> v2.4.20.28
[00013576][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013710][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013850][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013903][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013994][12 00][00] v1.11.0.0 -> v1.11.0.0
[00014094][12 01][00] v1.11.0.0 -> v1.11.0.0
[00014201][12 02][00] v1.11.0.0 -> v1.11.0.0
[00014324][12 03][00] v1.11.0.0 -> v1.11.0.0
[00026878][15 00][00] device not detected.
[00026976][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027116][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027180][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027236][01 00][00] v1.32.5432 -> v1.32.5432
[00027385][01 01][00] v1.32.5432 -> v1.32.5432
[00039948][08 00][00] device not detected.
[00040025][09 00][00] v3.0.0.10 -> v3.0.0.10
[00040081]Packet upgrade failed at version checking.
[00014015]========== remo-con disconnect. boot(15) ============
[00014067]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x24a1b4a7].
[00014117]Packet upgrade start...
[00014171]Packet checking...
[00014227]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014338]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014392]Done.
[00014443]Version checking[1]...
[00014541][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014640][03 06][00] v2.4.20.28 -> v2.4.14.5
[00014705][04 00][00] v1.48.0.0 -> v1.44.0.0
[00014840][11 00][00] v1.8.0.0 -> v1.7.15.1
[00014955][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015079][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015189][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015313][12 03][00] v1.11.0.0 -> v1.10.0.0
[00027868][15 00][00] device not detected.
[00027988][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028148][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028213][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028306][01 00][00] v1.32.5432 -> v1.30.5036
[00028356][01 01][00] v1.32.5432 -> v1.30.5036
[00040909][08 00][00] device not detected.
[00040995][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041049]Packet upgrade failed at version checking.
[00014718]========== remo-con disconnect. boot(15) ============
[00014770]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x24a1b4a7].
[00014824]Packet upgrade start...
[00014877]Packet checking...
[00014932]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014985]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015037]Done.
[00015090]Version checking[1]...
[00015194][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015316][03 06][00] v2.4.20.28 -> v2.3.0.13
[00015376][04 00][00] v1.48.0.0 -> v1.41.0.0
[00015449][09 00][00] v3.0.0.10 -> v1.7.0.3
[00015596][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015713][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015938][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016044][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016143][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028699][15 00][00] device not detected.
[00028820][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028979][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029069][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029121][01 00][00] v1.32.5432 -> v1.23.3419
[00029176][01 01][00] v1.32.5432 -> v1.23.3419
[00041730][08 00][00] device not detected.
[00041787]Packet upgrade failed at version checking.
[02414579]========== 2017.05.17 15:11:09. boot(15) ============
[02414634]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x24a1b4a7].
[02414689]Packet upgrade start...
[02414744]Packet checking...
[02414801]Packet vlink 01.10.0090 <-> 01.10.0090.
[02414857]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[02414910]Done.
[02414964]Version checking[1]...
[02415067][03 05][00] v34.2.0.9 -> v34.2.0.9
[02415167][03 06][00] v2.4.20.28 -> v2.4.20.28
[02415244][04 00][00] v1.48.0.0 -> v1.48.0.0
[02415387][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[02415526][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[02415577][11 01][00] v1.7.0.0 -> v2.0.0.33
[02415694][12 00][00] v1.11.0.0 -> v1.11.0.0
[02415794][12 01][00] v1.11.0.0 -> v1.11.0.0
[02415893][12 02][00] v1.11.0.0 -> v1.11.0.0
[02415993][12 03][00] v1.11.0.0 -> v1.11.0.0
[00012549]========== 2017.05.17 15:11:38. boot(15) ============
[00012605]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x24a1b4a7].
[00012660]Packet upgrade start...
[00012720]Packet checking...
[00012780]Packet vlink 01.10.0090 <-> 01.10.0090.
[00012839]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012894]Done.
[00012952]Version checking[1]...
[00013047][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013147][03 06][00] v2.4.20.28 -> v2.4.20.28
[00013208][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013487][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00013751][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00013807][11 01][00] v1.7.0.0 -> v2.0.0.33
[00013926][12 00][00] v1.11.0.0 -> v1.11.0.0
[00014034][12 01][00] v1.11.0.0 -> v1.11.0.0
[00014135][12 02][00] v1.11.0.0 -> v1.11.0.0
[00014234][12 03][00] v1.11.0.0 -> v1.11.0.0
[00026792][15 00][00] device not detected.
[00026891][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027056][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027134][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027192][01 00][00] v1.32.5432 -> v1.32.5432
[00027250][01 01][00] v1.32.5432 -> v1.32.5432
[00039808][08 00][00] device not detected.
[00039899][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039957]Done.
[00042015]Waiting for user confirm...
[00052073]Timeout, start upgrade automatically.
[00052190]Firmware upgrading[1]...
[00052258][11 00] Firmware upgrade start...
[00099267][11 00] Firmware upgrade finished successfully.
[00099328]Done.
[00099384]Version checking[2]...
[00099492][03 05][00] v34.2.0.9 -> v34.2.0.9
[00099592][03 06][00] v2.4.20.28 -> v2.4.20.28
[00099668][04 00][00] v1.48.0.0 -> v1.48.0.0
[00099812][11 00][05] v1.8.0.0 -> v1.8.0.0
[00099961][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00100015][11 01][00] v1.8.0.0 -> v2.0.0.33
[00100126][12 00][00] v1.11.0.0 -> v1.11.0.0
[00100254][12 01][00] v1.11.0.0 -> v1.11.0.0
[00100361][12 02][00] v1.11.0.0 -> v1.11.0.0
[00100466][12 03][00] v1.11.0.0 -> v1.11.0.0
[00113023][15 00][00] device not detected.
[00113136][17 00][00] v1.1.1.7 -> v1.1.1.7
[00113289][17 01][00] v1.0.2.7 -> v1.0.2.7
[00113376][19 00][00] v1.0.8.96 -> v1.0.8.96
[00113435][01 00][00] v1.32.5432 -> v1.32.5432
[00113492][01 01][00] v1.32.5432 -> v1.32.5432
[00126053][08 00][00] device not detected.
[00126135][09 00][00] v3.0.0.10 -> v3.0.0.10
[00126193]Packet upgrade failed at version checking.
[00013059]========== 2017.05.17 15:21:32. boot(15) ============
[00013117]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x24a1b4a7].
[00013280]Packet upgrade start...
[00013361]Packet checking...
[00013420]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013475]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013533]Done.
[00013591]Version checking[1]...
[00013685][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013784][03 06][00] v2.4.20.28 -> v2.3.0.13
[00013848][04 00][00] v1.48.0.0 -> v1.41.0.0
[00013924][09 00][00] v3.0.0.10 -> v1.7.0.3
[00014065][11 00][00] v1.8.0.0 -> v1.7.0.0
[00014192][12 00][00] v1.11.0.0 -> v1.10.0.0
[00014292][12 01][00] v1.11.0.0 -> v1.10.0.0
[00014418][12 02][00] v1.11.0.0 -> v1.10.0.0
[00014537][12 03][00] v1.11.0.0 -> v1.10.0.0
[00027097][15 00][00] device not detected.
[00027213][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027362][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027436][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027490][01 00][00] v1.32.5432 -> v1.23.3419
[00027548][01 01][00] v1.32.5432 -> v1.23.3419
[00040108][08 00][00] device not detected.
[00040167]Packet upgrade failed at version checking.
[00012579]========== remo-con disconnect. boot(15) ============
[00012635]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x24a1b4a7].
[00012693]Packet upgrade start...
[00012758]Packet checking...
[00012817]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012875]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012929]Done.
[00012988]Version checking[1]...
[00013092][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013214][03 06][00] v2.4.20.28 -> v2.3.0.13
[00013279][04 00][00] v1.48.0.0 -> v1.41.0.0
[00013373][09 00][00] v3.0.0.10 -> v1.7.0.3
[00013512][11 00][00] v1.8.0.0 -> v1.7.0.0
[00013627][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013736][12 01][00] v1.11.0.0 -> v1.10.0.0
[00013841][12 02][00] v1.11.0.0 -> v1.10.0.0
[00013945][12 03][00] v1.11.0.0 -> v1.10.0.0
[00026502][15 00][00] device not detected.
[00026619][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026763][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026833][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026999][01 00][00] v1.32.5432 -> v1.23.3419
[00027060][01 01][00] v1.32.5432 -> v1.23.3419
[00039619][08 00][00] device not detected.
[00039678]Packet upgrade failed at version checking.
[00013568]========== remo-con disconnect. boot(15) ============
[00013628]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x24a1b4a7].
[00013684]Packet upgrade start...
[00013749]Packet checking...
[00013806]Packet vlink 01.05.0030 <-> 01.04.0010.
[00013865]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013925]Done.
[00013984]Version checking[1]...
[00014069][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014151][03 06][00] v2.4.20.28 -> v2.4.0.5
[00014218][04 00][00] v1.48.0.0 -> v1.41.0.0
[00014350][11 00][00] v1.8.0.0 -> v1.7.0.0
[00014439][12 00][00] v1.11.0.0 -> v1.10.0.0
[00014539][12 01][00] v1.11.0.0 -> v1.10.0.0
[00014670][12 02][00] v1.11.0.0 -> v1.10.0.0
[00014779][12 03][00] v1.11.0.0 -> v1.10.0.0
[00027338][15 00][00] device not detected.
[00027441][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027574][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027659][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027718][01 00][00] v1.32.5432 -> v1.26.4315
[00027779][01 01][00] v1.32.5432 -> v1.26.4315
[00040339][08 00][00] device not detected.
[00040420][09 00][00] v3.0.0.10 -> v2.13.0.0
[00040477]Packet upgrade failed at version checking.
[00013432]========== remo-con disconnect. boot(15) ============
[00013509]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x0000393f].
[00013586]Packet upgrade start...
[00013668]Packet checking...
[00013750]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013825]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013899]Done.
[00013978]Version checking[1]...
[00014077][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014177][03 06][00] v2.4.20.28 -> v2.4.10.7
[00014259][04 00][00] v1.48.0.0 -> v1.41.0.0
[00014418][11 00][00] v1.8.0.0 -> v1.7.15.1
[00014527][12 00][00] v1.11.0.0 -> v1.10.0.0
[00014657][12 01][00] v1.11.0.0 -> v1.10.0.0
[00014871][12 02][00] v1.11.0.0 -> v1.10.0.0
[00014986][12 03][00] v1.11.0.0 -> v1.10.0.0
[00027564][15 00][00] device not detected.
[00027702][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027861][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027966][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028209][01 00][00] v1.32.5432 -> v1.26.4315
[00028289][01 01][00] v1.32.5432 -> v1.26.4315
[00040870][08 00][00] device not detected.
[00040969][09 00][00] v3.0.0.10 -> v2.13.0.0
[00041048]Packet upgrade failed at version checking.
[00013463]========== remo-con disconnect. boot(15) ============
[00013541]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x0000393f].
[00013617]Packet upgrade start...
[00013698]Packet checking...
[00013781]Packet vlink 01.09.0060 <-> 01.08.0080.
[00014016]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014106]Done.
[00014186]Version checking[1]...
[00014309][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014431][03 06][00] v2.4.20.28 -> v2.4.20.18
[00014516][04 00][00] v1.48.0.0 -> v1.44.0.0
[00014664][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014850][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014926][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015033][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015157][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015289][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015417][12 03][00] v1.11.0.0 -> v1.10.0.0
[00027995][15 00][00] device not detected.
[00028114][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028274][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028379][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028459][01 00][00] v1.32.5432 -> v1.30.5036
[00028538][01 01][00] v1.32.5432 -> v1.30.5036
[00041117][08 00][00] device not detected.
[00041220][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041299]Packet upgrade failed at version checking.
[00016033]========== 2017.05.17 17:51:28. boot(15) ============
[00016111]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x0000393f].
[00016189]Packet upgrade start...
[00016402]Packet checking...
[00016484]Packet vlink 01.08.0080 <-> 01.07.0060.
[00016574]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016653]Done.
[00016731]Version checking[1]...
[00016854][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017154][03 06][00] v2.4.20.28 -> v2.4.14.5
[00017256][04 00][00] v1.48.0.0 -> v1.44.0.0
[00017433][11 00][00] v1.8.0.0 -> v1.7.15.1
[00017562][12 00][00] v1.11.0.0 -> v1.10.0.0
[00017688][12 01][00] v1.11.0.0 -> v1.10.0.0
[00017802][12 02][00] v1.11.0.0 -> v1.10.0.0
[00017927][12 03][00] v1.11.0.0 -> v1.10.0.0
[00030505][15 00][00] device not detected.
[00030622][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030788][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030878][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030959][01 00][00] v1.32.5432 -> v1.30.5036
[00031039][01 01][00] v1.32.5432 -> v1.30.5036
[00043616][08 00][00] device not detected.
[00043708][09 00][00] v3.0.0.10 -> v3.0.0.10
[00043787]Packet upgrade failed at version checking.
[00015951]========== remo-con disconnect. boot(15) ============
[00016029]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x0000393f].
[00016111]Packet upgrade start...
[00016201]Packet checking...
[00016285]Packet vlink 01.08.0080 <-> 01.07.0060.
[00016364]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016445]Done.
[00016526]Version checking[1]...
[00029104][03 05][00] device not detected.
[00041682][03 06][00] device not detected.
[00041771][04 00][00] v1.48.0.0 -> v1.44.0.0
[00054353][11 00][00] device not detected.
[00066935][12 00][00] device not detected.
[00079514][12 01][00] device not detected.
[00092096][12 02][00] device not detected.
[00104678][12 03][00] device not detected.
[00117257][15 00][00] device not detected.
[00129836][17 00][00] device not detected.
[00142415][17 01][00] device not detected.
[00154995][19 00][00] device not detected.
[00155073][01 00][00] v1.32.5432 -> v1.30.5036
[00155155][01 01][00] v1.32.5432 -> v1.30.5036
[00167738][08 00][00] device not detected.
[00167941][09 00][00] v0.0.0.0 -> v3.0.0.10 need upgrade.
[00168019]Done.
[00170101]Waiting for user confirm...
[00180184]Timeout, start upgrade automatically.
[00180346]Firmware upgrading[1]...
[00180515][09 00] Firmware upgrade start...
[00015940]========== remo-con disconnect. boot(15) ============
[00016023]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x0000393f].
[00016101]Packet upgrade start...
[00016195]Packet checking...
[00016280]Packet vlink 01.08.0080 <-> 01.07.0060.
[00016362]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016444]Done.
[00016527]Version checking[1]...
[00029107][03 05][00] device not detected.
[00041691][03 06][00] device not detected.
[00041784][04 00][00] v1.48.0.0 -> v1.44.0.0
[00054365][11 00][00] device not detected.
[00066945][12 00][00] device not detected.
[00079525][12 01][00] device not detected.
[00092108][12 02][00] device not detected.
[00104691][12 03][00] device not detected.
[00016875]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x0000393f].
[00016948]Packet upgrade start...
[00017034]Packet checking...
[00017114]Packet vlink 01.01.0000 <-> 01.01.0000.
[00017187]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 6).
[00017256]Packet upgrade failed at packet checking.
[00016152]========== remo-con disconnect. boot(15) ============
[00016234]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x0000393f].
[00016315]Packet upgrade start...
[00016406]Packet checking...
[00016492]Packet vlink 01.10.0090 <-> 01.10.0090.
[00016572]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016654]Done.
[00016748]Version checking[1]...
[00029328][03 05][00] device not detected.
[00041910][03 06][00] device not detected.
[00042000][04 00][00] v1.48.0.0 -> v1.48.0.0
[00054582][11 00][00] device not detected.
[00067166][11 01][00] device not detected.
[00079748][12 00][00] device not detected.
[00092463][12 01][00] device not detected.
[00105045][12 02][00] device not detected.
[00117624][12 03][00] device not detected.
[00130203][15 00][00] device not detected.
[00142783][17 00][00] device not detected.
[00155362][17 01][00] device not detected.
[00167941][19 00][00] device not detected.
[00168019][01 00][00] v1.32.5432 -> v1.32.5432
[00168102][01 01][00] v1.32.5432 -> v1.32.5432
[00180687][08 00][00] device not detected.
[00193266][09 00][00] device not detected.
[00193344]Packet upgrade failed at version checking.
Saludos,
Jose Alejandro
2017-5-20
BlackCactus
I write on this topic because I have exactly the same problem.
After 2 years on non-using my P3P, I updated it. I formated SD card, remote was turned off, and I start the aircraft update. At the end of the update, it started to make a constant beep like "beeeeeee---------------------------". And aircraft was flashing yellow. I tried to turn it off, and on. Formated SD card again. Nothing works.
Can someone please know how to deal with this issue ?
Thank you to all
2018-8-17
