Phantom 2 Assistant
4199 16 2014-10-9
rivera_albert
Flight distance : 377966 ft
I cannot connect to the radio or Phantom on my PC or laptop, I tried installing the drivers now when I go into the Phantom assistant program it keeps asking me for login username & password & I keep getting an undefined error message 299.  Ive been at this for two days & getting very frustrated, please help.   What can I do?
2014-10-9
johnwarr
Flight distance : 6467 ft
Did you download and run the WIN drivers first ?
2014-10-9
rivera_albert
johnwarr@live.c Posted at 2014-10-10 02:44
Hello;  Yes I installed the driver, in my device manager it shows under ports DJI USB Virtual COM (COM7), I assume this means its working, I go into the Assistant program when I log in I get an undefined error message 299 & cannot log in,  I was in it last night & today nothing, I went over to my laptop & I get the same error.
2014-10-9
rivera_albert
I just installed the RC system assistant plug in controller, it works just fine, but I still get the 299 error message on the Phantom Vision Asistant
2014-10-9
johnwarr
OK lets go through the connection procedure from the start.
Plug USB lead into PC and the socket at the front of the phantom (not the USB port on the gimbal if you have the V+)
Turn on the phantom then run the PT2 3.2 assistant, it should connect to the phantom by its self, no need to press skip.
If the login message comes up, either login or press cancel.
The Transmitter is the same process, Plug in the USB lead to the PC and Transmitter, Turn on the transmitter, run the RC Assistant.
Use the USB lead that came with the Phantom.
2014-10-9
b.w.j
johnwarr@live.c Posted at 2014-10-10 03:43
Plug USB lead into PC and the socket at ...
Mine and others assistant have worked until today, i think its a general failure at DJI, have you tried yours ???
2014-10-9
johnwarr
No, not since my phantom was fresh out of the box.
Just ran the assistant without the phantom connected and I get the login message, but click cancel and it loads as normal.
Are you saying that no ones able to connect from today ?
2014-10-9
brianm66
I can't connect today either. Just received my Phantom 2 Vision+, can't log in to Android app, which means I can't use it for what I bought it for. Pretty terrible.
2014-10-9
Nightwalker1974
Don't look for any problems on your side. Seems like DJI has a server problem...
2014-10-9
deisal211
I have this same issue today as well. Does anyone know who we contact for this?
2014-10-9
rprachun
Nightwalker1974 Posted at 2014-10-10 05:56
Same here! Worked yesterday.
2014-10-9
T J Gilbert
Flight distance : 74659 ft
Everyone dances to the beat of IT today...
Unfortunately DJI is no exception.
They have server problems occasionally.
As I'm posting this it's 6:37 pm CDT.
It's 7:37 am in China.
Server maintenance usually occurs at night.
DJI is probably not concerned that their night is our day...
The DJI servers have never been down for very long in the over three years that I've been using their equipment...
2014-10-9
gwizz509
I am having the same problem as well. I'll wait until tomorrow and try and upgrade my new Phantom then.
2014-10-9
jimjamz2
Flight distance : 2425410 ft
Just got my P2V+...same problem...I can connect phantom and RC to computer and calibrate...but when I try to login for firmware updates...I get "undefined error 299".  Looks like I'll be updating tomorrow as well.  Glad to see its not just me.
2014-10-9
insitb
As an FYI, you can upgrade without having to log in first. I did. Just cancel the login dialogue and proceed as per normal.
2014-10-9
b.w.j
The issue is solved.
2014-10-10
rivera_albert
Ok everyone, say hello to the idiot, I figured out wht I was doing wrong, I thought I needed to connect the micro USB to the camera port, I didn't realize the phantom has one too, I plugged it correctly, I was able to get into the assistant program without a hitch,  all is well,  I was even able to switch to naza mode without any issues, so thank you all for your help and input
2014-10-10
