phantom 3 can't take a picture or film
3285 19 2016-6-18
pierre.alexandr
Flight distance : 1107910 ft
Hey every one I have a phantom 3 adv, I've never crashed or any thing. Every thing is working (take off, image transmission, ...) but when I tap the picture button or filming one it loads and then I lose the image transmission but it comes back after 30 sec. So I really dont know what to do, if you have some thing that could help please tel me.
2016-6-18
DJI-Paladin
Flight distance : 2408 ft
Hello Pierre, what kind of mobile device and SD card do you use? Will the drone lose signal by the time when you tap the button if it doesn't take off and stand on the ground?
2016-6-18
pierre.alexandr
DJI-Paladin Posted at 2016-6-18 12:31
Hello Pierre, what kind of mobile device and SD card do you use? Will the drone lose signal by the t ...
i use the iPhone 6 an the lexar sd that comes with. and yes it loses signal but it comes back
2016-6-18
DJI-Paladin
China
pierre.alexandr Posted at 2016-6-18 20:07
Do you use the RC or app to take a photo? Do other devices have the same result?
2016-6-18
Take a look at the files on the SD card and see if the video or still did in fact record. It is more like an issue of the iPhone crashing, not the recording. Another thing would be to copy any stills or video off the SD card and then re-format it.
2016-6-18
sven_dc
Hi Pierre,
I have all the same problem.
Things that still work:
- Live video transmission
- Playback videos that are on the SD card already
- Firmware updating process (writes the logs on txt file)
- Configuring camera settings
- Formating SD card directly from the APP
Things that doesnt work:
- Taking photos and store them on SD
- Taking videos and store them on SD
This is was happening in detail:
1. I push the button to make a photo (resp. video) at the remote controller
2. The iPhone makes the photo sound.
3. The video transmission turnes into a black screen.
4. The gimbal fan stops working
5. Sometimes the dji logo gets displayed in the DJI GO app
6. The drone beeps a code: Long - Short - Short
7. The fan starts working again
8. The black screen turnes into live video transmission again
9. No videos/photos stored on SD
I'm using an iPhone 6.
Do you have the same problems?
It seems that all actions with camera and SD card reader do work, but as soon the task is to store footage on SD there is this problem.
I installed the latest update yesterday and maybe there is a connection!? I had also a problem during the update process and had to restart it.
I hope this topic gets solved
Thanks for the replies!
Greetings from Germany.
2016-6-19
What happens if you use the button on the RC controller to take a photo or start recording, not the one in the Go App? Seems to me I have seen this problem before and it always involves an iPhone 6.
2016-6-19
pierre.alexandr
yes I have exactly everything that is the same. Tel me if you find a solution, I've contacted DJI I'm Waiting for the answer
2016-6-20
pierre.alexandr
Geebax Posted at 2016-6-20 09:02
What happens if you use the button on the RC controller to take a photo or start recording, not th ...
Hey I have also tried that but everything acts the same as I press the button on the iPhone or RC. I've tried also with an iPhone 5S it does exactly the same thing
2016-6-20
pierre.alexandr
2016-6-20
pierre.alexandr
Geebax Posted at 2016-6-19 05:43
Take a look at the files on the SD card and see if the video or still did in fact record. It is more ...
i have already done the formatting and there is no picture that ads it self when i take one
2016-6-20
sven_dc
pierre.alexandr Posted at 2016-6-20 19:54
yes I have exactly everything that is the same. Tel me if you find a solution, I've contacted DJI  ...
Ok I tell you if I find a solution. Please do the same for me.
Today I try to downgrade the drone to the previous firmware and connect a Samsung smartphone.
Maybe this will shed light on the issue...
2016-6-20
pierre.alexandr
sven_dc Posted at 2016-6-20 15:29
Today I try to downgrade the drone ...
I don't know if downgrading could help. if it works tell me. I'll tell you if I find any solution
2016-6-20
pierre.alexandr
hey @sven_dc I've contacted DJI they ask me to send it back to Netherlands.
2016-6-21
pierre.alexandr
DJI-Paladin Posted at 2016-6-19 04:50
it does the same on both and i've tried with iPhone 5s it does the same
2016-6-21
DJI-Paladin
pierre.alexandr Posted at 2016-6-21 18:19
It seems there is something wrong with the camera mainboard. I'd suggest you to get in touch with our tech support via support@dji.com and send it to our service center for diagnosis.
2016-6-21
pierre.alexandr
DJI-Paladin Posted at 2016-6-21 12:25
It seems there is something wrong with the camera mainboard. I'd suggest you to get in touch with  ...
thanks I'm in touch with them
2016-6-21
Alex L.
Malaysia
pierre.alexandr Posted at 2016-6-21 22:40
Hi Pierre, did you manage to fix your drone already? Mine having the exact problem as yours too.
2016-6-23
pierre.alexandr
Alex L. Posted at 2016-6-23 12:00
I'm sending it back to netherlands to DJI in July-August
2016-6-27
SSharkey
Flight distance : 42966 ft
Just started talking to support - mine has developed exactly the same symptoms - I assume yours was resolved? I have pointed my support contact at this thread in the hope that maybe there is some easy resolution.
2017-6-22
