VPS On/Off - Another Request for an option to Disable VPS
12
6707 57 2016-6-6
DJI-Ken
Flight distance : 1515312 ft
Vasek Posted at 2016-6-23 04:59
I would appreciate this on/off otion as well Ken. When flying lower over water it is not quite sta ...
I totally understand and flying low over water is one of it's limitations.
I too would like to see a on/off option.
Maybe someday.
2016-6-22
willem
I too would like this as an option.  Please include the ability to disable the VPS.  Currently when using a controlled zip line in Autopilot it is not able to come down close the bottom of its run due to VPS.
2016-6-22
willem
Black tape over the vision sensor does the trick.  This is an extremely hokey fix for an expensive bird but its the only thing that works for me in order to capture those cinema quality shots that involve coming close to the ground.  Seriously DJI - why?  If you are worried about crashes then have those people interested sign an agreement that they won't hold DJI liable.  Include it as an unlock option in the application.  Simple.
2016-6-22
doug.upthink
Flight distance : 861621 ft
willem@pcfish.c Posted at 2016-6-22 19:17
Black tape over the vision sensor does the trick.  This is an extremely hokey fix for an expensive b ...
I experimented with taping over the sensors as well. Didn't really notice much of a change. Are you just taping over the two cameras on the bottom? That's all I tried...
2016-6-23
Vasek
Czechia
willem@pcfish.c Posted at 2016-6-23 01:17
You mean to tape the cams only? Taping the ultrasonic downward sensors wouldn't have effect i think.
2016-6-24
jwatt
Flight distance : 427867 ft
DJI-Ken Posted at 2016-6-22 14:21
That's great you are getting good results.
We'll see if it becomes an option.
Kelly and I would also like to add our request to have a VPS off option in GPS flight.
Thx...Jim Watt
2016-6-24
DJI-Ken
willem@pcfish.c Posted at 2016-6-23 07:17
If you do have a crash and it's due to the camera sensors being blocked then it would not be a warranty repair.
2016-6-24
DJI-Ken
Vasek Posted at 2016-6-24 22:29
You mean to tape the cams only? Taping the ultrasonic downward sensors wouldn't have effect i thin ...
Anything that would get in the view of the sonar would cause unwanted altitude movement and possibly a non warranty crash.
Do not block the sensors.
2016-6-24
DJI-Ken
jwatt@bennett-w Posted at 2016-6-24 22:47
Thx...Jim  ...
It's been noted.
2016-6-24
j.cabresos
Flight distance : 60807 ft
Philippines
Any updates on the VPS On/Off option? it sucks, that you can't disable it. Almost crash my Phantom 4 over water because of the VPS making the Phantom ascend and almost hitting a branch. The option to turn off VPS is essential.
2016-7-11
doug.upthink
After hiking over 50 miles with my P4, I'm seeing the VPS issue showing up in my footage while editing this week. Here's a great example of VPS ruining a shot. I was flying between 5 and 10' above the alpine stream and you can clearly see the subtle height undulations created by VPS errors.
Source file is 4k, 24. Preview file has been encoded at HD resolution.
VPS Issue - Phantom 4 - Alpine Stream, Canadian Rockies
2016-7-14
Flight distance : 10186312 ft
I read from another thread, from dji guy, they are working on vps issue, I expect to see it soon maybe next firmwear, you can use litchi app this allows you to switch of Vps.
2016-7-14
mjanzou
Flight distance : 14820 ft
+1 vote to add this option for me....
Perhaps confirming the vps on/off setting with a disclaimer, like for altitude limit over-ride would make it good with the folks upstairs???
2016-7-14
DJI-Ken
mjanzou@gmail.c Posted at 2016-7-14 23:47
Perhaps confirming the vps on/off setting with a disclaimer ...
We'll see what happens.
2016-7-14
Jim Watkins
Flight distance : 9132172 ft
In the latest firmware, my p4 DOES NOT follow changes in terrain using VPS.  In earlier versions, it did adjust its altitude for variations in terrain below the quad.  I can completely understand why some people in some circumstances (such as situations where a cinematographer is shooting low shots) need to disable it, but now that it no longer adjusts for terrain, I would like to have it switchable too so that I can turn it BACK ON.  Not so I can turn it off, but rather so that I can turn it ON!  Are you guys who are complaining about this on the latest firmware, because it definitely DOES NOT compensate for varying terrain anymore at least not in P mode.  I would very much like for this to be selectable by the operator bassed on what ones needs are at the moment.
Jim
2016-7-15
gsxr07boy
Litchi app can turn off VPS on p4
2016-7-15
gsxr07boy
2016-7-15
asimokid
Indonesia
I worries when fly in indoor and vpn on. When vpn detect not fly in flat surface, drone increase or decrease altitude...
So what i do when fly indoor? The best setup i mean
Thx
2016-7-15
12
