NEW FIRMWARE v1.9.1.10 ISSUES warning!!!
28699 330 2016-6-18
brendanabbott
Henry Mo-Yung Posted at 2016-7-2 01:17
Hi Brendanabbott,
The issues were intermittent - I first encountered the issues twice amongst sev ...
Thanks Hennry. I had done an imu calibration on mine, compass calibration, stick calibration and also pre flight check of all values after the update (standard procedure I follow according to my certification manuals), and it still did it, was intermittent and once I rebooted, it went back to normal. First issues I've had with the inspire. I've now rolled back the firmware. My inspire is an Inspire 1 RAW as well.
I'm really after the revised firmware now as in back on 1.8. The bug is definitely there, however is intermittent so maybe hard to replicate
2016-7-2
nilsblix
Flight distance : 23047543 ft
========== 2014.01.01 00:00:06 remo-con disconnect======
Packet: WM610_FC550_FW_V01.09.01.21.bin
Upgrading ...
Result: Success.
After receiving a "internal" revised FW 1.9.01.21 from DJI I have today done the new update with success. It is very windy here ( Sweden ) today - just able to do a short test - seems that DJI have fixed my and others problems with FW 1.9.....
2016-7-2
Henry Mo-Yung
Flight distance : 11548839 ft
nilsblix@gmail. Posted at 2016-7-2 22:49
Upg ...
Hi Nilsblix,
I am glad to know you get positive result too.
Henry
2016-7-2
nilsblix
Fingers crossed.
2016-7-2
Arrow1969
Flight distance : 400577 ft
nilsblix@gmail. Posted at 2016-7-2 15:49
Upg ...
Glad to know that.
Cheers Tony
2016-7-2
GabeZ
Flight distance : 768448 ft
nilsblix@gmail. Posted at 2016-7-2 08:49
Upg ...
I don't even understand how you were able to get the "internal" firmware.  I've requested it and none of the reps know of its existence.  Did you get it from a rep here?  Was it some random email?
2016-7-2
RichJ53
Flight distance : 1837356 ft
Henry Mo-Yung Posted at 2016-7-1 21:50
Hi Rich,
The FW upgrade processing from FW v1.09.01.10 to the DJI's supplied "internal firmware"  ...
Henry
My gear were up and locked. I was filming a fir tree being cut down So I had the Inspire parked while the tree was being removed piece by piece. It was very obvious when I was about10 feet from the ground. I needed to hold up on the stick to keep my position. Never had this happen before... I feel if I had not given more up stick the Inspire would sink to the ground.
I was not having any trouble at the river two weeks ago and have a slow-mo showing my Inspire locked in a hover over the water with VPS turned on.
Rich
2016-7-2
nilsblix
GabeZ Posted at 2016-7-3 00:53
I don't even understand how you were able to get the "internal" firmware.  I've requested it and n ...
I got the file from DJI after sales customer support. I think they have sent it to us that have provided DJI with our internal .dat files which can tell them whats wrong with our FW.
2016-7-2
db050800
Flight distance : 2204462 ft
Henry Mo-Yung Posted at 2016-6-20 13:06
Oh No!
Did you say it came down by itself with the landing gear lifted and crashed on the X5R ca ...
Had the same happen to me this morning. What is going on????
2016-7-2
db050800
So After the 1.9 firmware upgrade, all was ok, had a warning about sensor, and it rose once, but landed ok. I changed battery, it shot the job ok.
Until this morning. Weather has been shocking. Great day today, so got up early, check the craft software etc. Checked the IMU and did a stick calibration.
At site, usual preflight procedures, performed Compass calibration, checked & formatted sd card etc. Started motors, set home point, finished camera checks, then took of manually to about 2m. let go of sticks, and it still drifted up, landing gear stayed in down position. Touched the down stick to stop the drift, and the craft started to descend, let go of stick, and it still drifted down slowly. It then shot up, by its self, fast. I pulled the down stick to stop the ascent. In then went down fast. I steadied it at about 1.5 to 2 m, and set about landing. All though this the landing gear it down, and i have issued no command to raise it.
About 0.5m from landing, the landing gear then raised by itself, then landed on the X5 camera, even though I had stopped pulling the stick.
I killed the motors, and went to take a picture (attached)
As I started to take the picture, the land gear then started to lower, again by itself, with no command from the transmitter.
What is going on? Have commercial jobs this week, and cant trust the Inspire 1 Pro in this state.
I have tried to down grade the firmware to V1.8, as people have suggested, but now the craft will not accept any firmware files, and leaves no text reports when you try.
Im stuck, can anyone help?
I attached footage from the inspire, The flight record from app & picturehttps://www.dropbox.com/sh/ya5ez ... hnxzlWMXKrZR4a?dl=0
2016-7-2
GabeZ
db050800 Posted at 2016-7-2 14:19
So After the 1.9 firmware upgrade, all was ok, had a warning about sensor, and it rose once, but lan ...
Hi db050800,
   What happens when you downgrade (or attempt to) and how are you doing it?  Normally, all you have to do is put the .BIN on your SD card and let it install.  If there's more on your SD card, make sure you remove everything but the .BIN file.
2016-7-2
SkyHigh UAV
Flight distance : 2838921 ft
GabeZ Posted at 2016-7-3 02:53
Add me and I can send you the link of the internal firmware
2016-7-2
Henry Mo-Yung
RichJ53 Posted at 2016-7-3 01:30
Henry
My gear were up and locked. I was filming a fir tree being cut down So I had the Inspire pa ...
Hi Rich,
It was strange. Those you experienced on today were similar to the issues I encountered but mine was still with FW v1.09.01.10 but yours was already back to FW v1.08.01.00 5 days ago.
I hope DJI can officially release the fixing firmware as soon as possible. In the mean time, be careful and good luck.
Henry
2016-7-2
Henry Mo-Yung
db050800 Posted at 2016-7-3 04:19
Dear Db050800,
Thanks for the thick grass, you were very lucky not resulting with a damaged I1 Pro!
Did you manage to have the corresponding bin file when you tried to downgrade? It should be the WM610_FC550_FW_V1.08.01.00.bin file, not the WM610_FW_V1.08.01.00.bin file.
Henry
2016-7-2
Henry Mo-Yung
Henry Mo-Yung Posted at 2016-7-3 08:00
Dear Db050800,
Thanks for the thick grass, you were very lucky not resulting with a damaged I1 P ...
Hi Db050800,
Please note that Rich experienced the issues on today even though he downgraded the FW to v1.08.01.00.
Be prepared not to panic if you encounter the issues after successfully downgrade your I1 Pro to FW v1.08.01.00.
Good luck!
Henry
2016-7-2
GabeZ
SkyHigh UAV Posted at 2016-7-2 17:39
I tried to add you but got a "please wait" and request sent over your avatar.  I'm not sure if you got the request as it kept saying "please wait."  Alternatively, if I can't get that to work, do your have a company email I can reach you at?
2016-7-2
RichJ53
Henry Mo-Yung Posted at 2016-7-2 16:41
Hi Rich,
It was strange. Those you experienced on today were similar to the issues I encountered  ...
Hi Henry,
So now I upgraded back to 1.9.10 FW and recal'd everything again. Just flew a 12min flight and everything tested out fine. Tomorrow we are flying again (not sure where yet)  I looked at the text file shown below and I see the (17) is one of the files you said DJI changed.... Can you send me a link to the internal FW file... I think I would like to try it for the Inspire 1 V2 X3 version. DJI PM is not working right now. I am puzzled on what to do at this point....  I am worried that something is buggy but I do not know what the cause is. I will send the dat file to DJI if they would like it....  DJI ?? let me know.
hidden log RED is the downgrade to 1.8 and blue is the upgrade 1.9
00009674]========== remo-con disconnect. boot(15) ============
[00009718]Packet [C:\WM610_FW_V01.08.01.00.bin] detected, card sn [0xb0407e22].
[00009770]Packet upgrade start...
[00009822]Packet checking...
[00009866]Packet vlink 01.08.0100 <-> 01.07.0090.
[00009912]Record vlink 01.09.0110 <-> 01.08.0100 (flow = 1).
[00009960]Done.
[00010007]Version checking[1]...
[00010053][01 00][00] v2.65.5033 -> v2.65.5033
[00010099][01 01][00] v2.65.5033 -> v2.65.5033
[00010181][03 05][00] v34.1.0.5 -> v34.1.0.5
[00010341][03 06][00] v2.4.20.18 -> v2.4.10.7 need upgrade.
[00010410][04 00][00] v1.29.0.92 -> v1.29.0.92
[00010501][05 00][00] v3.0.6.2 -> v3.0.6.2
[00010555][08 00][00] v2.14.9.42 -> v2.14.9.42
[00010621][09 00][00] v3.0.0.4 -> v3.0.0.4
[00010721][11 00][00] v3.9.0.0 -> v3.9.0.0
[00010821][12 00][00] v1.11.0.0 -> v1.11.0.0
[00010923][12 01][00] v1.11.0.0 -> v1.11.0.0
[00011021][12 02][00] v1.11.0.0 -> v1.11.0.0
[00011121][12 03][00] v1.11.0.0 -> v1.11.0.0
[00011259][15 00][00] v1.1.2.0 -> v1.1.2.0
[00011321][17 00][00] v1.1.0.6 -> v1.1.0.4 need upgrade.
[00011461][17 01][00] v2.0.1.6 -> v2.0.1.4 need upgrade.
[00011520][19 00][00] v1.0.8.96 -> v1.0.8.96
[00011569]Done.
[00013626]Waiting for user confirm...
[00023672]Timeout, start upgrade automatically.
[00023762]Firmware upgrading[1]...
[00023883][03 06] Firmware upgrade start...
[00243155][03 06] Firmware upgrade finished successfully.
[00243211][17 00] Firmware upgrade start...
[00285132][17 00] Firmware upgrade finished successfully.
[00285183][17 01] Firmware upgrade start...
[00318869][17 01] Firmware upgrade finished successfully.
[00318913]Done.
[00318962]Version checking[2]...
[00319008][01 00][00] v2.65.5033 -> v2.65.5033
[00319056][01 01][00] v2.65.5033 -> v2.65.5033
[00319132][03 05][00] v34.1.0.5 -> v34.1.0.5
[00319216][03 06][05] v2.4.10.7 -> v2.4.10.7
[00319274][04 00][00] v1.29.0.92 -> v1.29.0.92
[00319353][05 00][00] v3.0.6.2 -> v3.0.6.2
[00319406][08 00][00] v2.14.9.42 -> v2.14.9.42
[00319461][09 00][00] v3.0.0.4 -> v3.0.0.4
[00319551][11 00][00] v3.9.0.0 -> v3.9.0.0
[00319653][12 00][00] v1.11.0.0 -> v1.11.0.0
[00319751][12 01][00] v1.11.0.0 -> v1.11.0.0
[00319852][12 02][00] v1.11.0.0 -> v1.11.0.0
[00319951][12 03][00] v1.11.0.0 -> v1.11.0.0
[00321067][15 00][00] v1.1.2.0 -> v1.1.2.0
[00321132][17 00][05] v1.1.0.4 -> v1.1.0.4
[00321252][17 01][05] v2.0.1.4 -> v2.0.1.4
[00321308][19 00][00] v1.0.8.96 -> v1.0.8.96
[00321364]Packet upgrade finish successfully.
[00010017]========== remo-con disconnect. boot(15) ============
[00010067]Packet [C:\WM610_FW_V01.09.01.10.bin] detected, card sn [0xb0407e22].
[00010116]Packet upgrade start...
[00010182]Packet checking...
[00010228]Packet vlink 01.09.0110 <-> 01.08.0100.
[00010283]Record vlink 01.09.0110 <-> 01.08.0100 (flow = 0).
[00010351]Done.
[00010407]Version checking[1]...
[00010465][08 00][00] v2.14.9.42 -> v2.14.9.42
[00010524][01 00][00] v2.65.5033 -> v2.65.5033
[00010610][01 01][00] v2.65.5033 -> v2.65.5033
[00010716][03 05][00] v34.1.0.5 -> v34.1.0.5
[00010816][03 06][00] v2.4.10.7 -> v2.4.20.18 need upgrade.
[00010884][04 00][00] v1.29.0.92 -> v1.29.0.92
[00010956][05 00][00] v3.0.6.2 -> v3.0.6.2
[00011021][09 00][00] v3.0.0.4 -> v3.0.0.4
[00011116][11 00][00] v3.9.0.0 -> v3.9.0.0
[00011216][12 00][00] v1.11.0.0 -> v1.11.0.0
[00011316][12 01][00] v1.11.0.0 -> v1.11.0.0
[00011416][12 02][00] v1.11.0.0 -> v1.11.0.0
[00011516][12 03][00] v1.11.0.0 -> v1.11.0.0
[00011653][15 00][00] v1.1.2.0 -> v1.1.2.0
[00011736][17 00][00] v1.1.0.4 -> v1.1.0.6 need upgrade.
[00011876][17 01][00] v2.0.1.4 -> v2.0.1.6 need upgrade.
[00011940][19 00][00] v1.0.8.96 -> v1.0.8.96
[00011990]Done.
[00014053]Waiting for user confirm...
[00024101]Timeout, start upgrade automatically.
[00024193]Firmware upgrading[1]...
[00024322][03 06] Firmware upgrade start...
[00259710][03 06] Firmware upgrade finished successfully.
[00259769][17 00] Firmware upgrade start...
[00300927][17 00] Firmware upgrade finished successfully.
[00300984][17 01] Firmware upgrade start...
[00334663][17 01] Firmware upgrade finished successfully.
[00334708]Done.
[00334782]Version checking[2]...
[00334837][08 00][00] v2.14.9.42 -> v2.14.9.42
[00334883][01 00][00] v2.65.5033 -> v2.65.5033
[00334930][01 01][00] v2.65.5033 -> v2.65.5033
[00335027][03 05][00] v34.1.0.5 -> v34.1.0.5
[00335127][03 06][05] v2.4.20.18 -> v2.4.20.18
[00335190][04 00][00] v1.29.0.92 -> v1.29.0.92
[00335346][05 00][00] v3.0.6.2 -> v3.0.6.2
[00335406][09 00][00] v3.0.0.4 -> v3.0.0.4
[00335487][11 00][00] v3.9.0.0 -> v3.9.0.0
[00335574][12 00][00] v1.11.0.0 -> v1.11.0.0
[00335666][12 01][00] v1.11.0.0 -> v1.11.0.0
[00335748][12 02][00] v1.11.0.0 -> v1.11.0.0
[00335847][12 03][00] v1.11.0.0 -> v1.11.0.0
[00337460][15 00][00] v1.1.2.0 -> v1.1.2.0
[00337526][17 00][05] v1.1.0.6 -> v1.1.0.6
[00337647][17 01][05] v2.0.1.6 -> v2.0.1.6
[00337712][19 00][00] v1.0.8.96 -> v1.0.8.96
[00337762]Packet upgrade finish successfully.
Rich
2016-7-2
Henry Mo-Yung
RichJ53 Posted at 2016-7-3 08:54
Hi Henry,
So now I upgraded back to 1.9.10 FW and recal'd everything again. Just flew a 12min fli ...
Hi Rich,
I added friend with you. Do you need to confirm it so that we can send PM to each other? It seems I can't send PM to you.
Henry
2016-7-2
RichJ53
Henry Mo-Yung Posted at 2016-7-2 20:54
Hi Rich,
I added friend with you. Do you need to confirm it so that we can send PM to each other? ...
Henry
Yes, I see you did......  The PM is currently not working .. Ken has reported it to the web guys.
we are like 15 hours apart so if you fly again today please post how everything is working. I will check it before I fly tomorrow.
Rich
2016-7-2
db050800
GabeZ Posted at 2016-7-3 00:22
Hi db050800,
   What happens when you downgrade (or attempt to) and how are you doing it?  Normall ...
Thanks GabeZ, have been trying to do that all night. It just sit there with a green light on the camera, and does not go in-to the firmware mode.; Tried different sd cards, formating them in the inspire etc.
2016-7-2
Henry Mo-Yung
Hi Rich,
I set off my I1 Pro twice in this morning and it performed consistently as it used to be.
Good luck!
Henry
2016-7-2
db050800
Henry Mo-Yung Posted at 2016-7-3 01:00
Dear Db050800,
Thank you Henry,
Yes, seems to be the correct BIN.
It will not go into firmware mode at all. Shame theres not a reset switch....or is there??
2016-7-2
RichJ53
Henry Mo-Yung Posted at 2016-7-2 22:52
Hi Rich,
I set off my I1 Pro twice in this morning and it performed consistently as it used to be.  ...
That's awesome news Henry..    To bad we cant get this new FW link!
Rich
2016-7-2
Rob W
Flight distance : 96152 ft
RichJ53 Posted at 2016-7-3 08:00
Rich
Yes, hope we can get the new FW link. My Inspire is grounded because of this and I want to fly now on the holiday. Glad though that the internal firmware seems to fix the issues!
2016-7-2
db050800
db050800 Posted at 2016-7-3 06:49
Thanks GabeZ, have been trying to do that all night. It just sit there with a green light on the c ...
Thanks for that.
Bit of an update. I use mac. I just pinched my sons window laptop, down loaded the bin, extracted, just put it into the bird, and its in firmware mode!
So is this all an Apple issue? interested to see if the firmware issue is from an apple download, or if I'm clutching at straws.
2016-7-2
Henry Mo-Yung
RichJ53 Posted at 2016-7-3 14:00
Rich
Hi Richard,
Please check message in your SkyPixel account.
Henry
2016-7-3
unyks
Flight distance : 710085 ft
I'm reading several DJI related boards and issues (or better say crashes) are reported more and more.
OK, s*t happens even after you've tested the stuff before it is released - i get that, BUT what i don't get is that this Firmware is still available for download. DJI takes the risk at their full knowledge that customers could crash their copters due this faulty firmware, not even a little WARNING that this Firmware should be used at the customers own risk OR EVEN BETTER that customers should downgrade if they experience a strange behaviour with their bird.
It is not a shame to play with open cards, it will just gain the trust of your customers!
Chris
2016-7-3
GabeZ
unyks Posted at 2016-7-3 09:19
I'm reading several DJI related boards and issues (or better say crashes) are reported more and more ...
Actually,
   They have this nasty little disclaimer on their webpage..... I don't get how they cannot be liable for something they create and provide as publically downloadable.....Furthermore, I've heard stories about how they will, at their sole discretion, consider the current firmware necessary and probable cause for why you may have had a failure and not cover it under warranty.
* Disclaimer of Warranties:
SZ DJI Technology Co. Ltd. provides the firmware “as is” and “as available” for your use, without warranty of any kind, either express or implied, including all implied warranties of merchantability, and fitness for a particular purpose. You expressly agree that your use of, or inability to use the firmware is at your sole risk. In no case shall SZ DJI Technology Co. Ltd. be liable for any direct, indirect, punitive, special, or consequential damages arising from your use of any of the firmware, including but not limited to, any loss or damage of any kind incurred as a result of your misuse, transmitted, etc.
2016-7-3
Tharg (from the
Flight distance : 120784 ft
unyks Posted at 2016-7-3 16:19
No, no....it can't possibly be the firmware causing this as the only thing that was changed was the NFZ database in v1.9
That MUST be true because that's all DJI said was changed!!!!
We are being treated like idiots.
2016-7-3
RichJ53
Rob W Posted at 2016-7-2 23:39
Yes, hope we can get the new FW link. My Inspire is grounded because of this and I want to fly now ...
Hi Rob
I am sure DJI will release this soon as they know it is confirmed to address the issue (whatever that was)
Hang in there....  we are going flying today
Rich
2016-7-3
RichJ53
GabeZ Posted at 2016-7-3 08:40
Actually,
   They have this nasty little disclaimer on their webpage..... I don't get how they can ...
The statement certainly sums up that they take no liability, but the last line is interesting...
"loss or damage of any kind incurred as a result of your misuse, transmitted, etc."
So this means if you misuse the FW or do not follow the installation steps?
Rich
2016-7-3
RichJ53
Henry Mo-Yung Posted at 2016-7-3 04:06
Hi Richard,
Got your message ... thanks for reaching out Henry.  We are flying today batteries are charging
Rich
2016-7-3
GB44
Flight distance : 343848 ft
This is the first firmware that I have not installed and I am thinking I will wait for the next firmware release as there seems to be some real issues here.
Any feedback or update from DJI would be welcome.
2016-7-3
thephotoseen
Flight distance : 12539 ft
am new to the DJI Inspire platform, after flying a Yuneec Q500 4K for more than a year. I recently purchased the Inspire 1 from Aerial Media Pros in Costa Mesa CA, and as part of their service they made sure that the Inspire 1 and Z5 camera had the latest firmware. I have only had a chance to fly the drone once since purchasing it. Having time this weekend to take her out, upon start up noticed the "software update warning". After downloading the update on the cameras SD card and reinstalling it in the z5, i couldnt figure out how to launch the update. Upon searching out "How To's" I came across this forum.
THANK YOU FOR THE WARNINGS!!!!!
I will check back daily to see if DJI offers a revision to 9.1
2016-7-3
GabeZ
RichJ53 Posted at 2016-7-3 11:00
It almost seems like they take no liability what so ever, but they especially wanted to highlight misuse.
2016-7-3
GabeZ
thephotoseen Posted at 2016-7-3 16:17
am new to the DJI Inspire platform, after flying a Yuneec Q500 4K for more than a year. I recently  ...
I still have a Yuneec Q500 4K as well.  I would recommend staying away from the 1.9 for now.  But just in in case you were wondering, you place only the .BIN file on the SD card, insert it into your camera, and power up.  The update process starts automatically once it sees the .BIN file.  You want to keep your RC off when you do this.
2016-7-3
GabeZ
I have an interesting thought.......  or rather an observation....   How many of you used auto take off before the trouble began?
2016-7-3
RichJ53
GabeZ Posted at 2016-7-3 21:06
I have an interesting thought.......  or rather an observation....   How many of you used auto take  ...
I cannot speak for the others, but I have never used auto take off to date. My trouble started after I had been flying awhile.  I did not think my issues were the same as the others.
Rich
2016-7-3
GabeZ
RichJ53 Posted at 2016-7-3 22:19
I cannot speak for the others, but I have never used auto take off to date. My trouble started aft ...
There goes that theory.  I thought I was on to something
2016-7-3
RichJ53
GabeZ Posted at 2016-7-3 21:34
Hey now ... that's only me   lets see if anyone else has some thoughts.
Rich
2016-7-3
