Motor life
1153 10 2016-8-14
Henry2016
Flight distance : 92215 ft
Hello all, I got a 2 part question. 1 about how long is the expected life of a motor on average. 2 How can you tell which motors you have W/O dismantling first. ( old version or new version).
2016-8-14
Barney Rubbel
I'm not going to even guess on the life of a motor. I have yet to see one go bad on a unit unless it has been crashed previously. If you hear one start to whine, don't wait until it goes out though.   I do have 2 P3P's, however, and they have different motors. The first one I got came with the traditional wrench, and the motors had notches that the wrench could latch on to. The 2nd one I got, however, has a nutcracker like tool to grip the outside of the motor because it is flat on top. I can't say for sure the the new ones are the flat ones, but that would make much more sense to me. The 1st set I describe are just like the older P2V+.
Happy Flying!
Barney
2016-8-14
labroides
The motors will last a long time.
If the top of your motors is flat with a star shape, it's the newer style.
The older has raised bits on the top.
2016-8-14
endotherm
Flight distance : 503241 ft
<=== OLD                    NEW===>
2016-8-15
DJI-Ken
Flight distance : 1515312 ft
Several things will determine the life of a motor, if you don't fly near the ocean, dirt and do not abuse your aircraft then the motors should last a very long long time. You can tell if it starts going bad by feeling it when you hand turn it. If one ever starts to not feel smooth then you are ok.
And the above post is correct on hot to tell the motor difference and here's an article about it.
http://www.dji.com/newsroom/news ... al-advanced-motors1
2016-8-15
AG0N-Gary
Flight distance : 700846 ft
Read your response, Ken.  "If one ever starts to not feel smooth then you are ok."  If they feel smooth, they should be ok.  NOT feeling smooth will require further digging to find out why, and should be replaced.
2016-8-15
Viridis
Flight distance : 2383556 ft
Might sound stupid, but are there any methods of keeping them nice and clean post flights?
Air cannisters? Or something like that?
2016-8-16
Henry2016
AG0N-Gary Posted at 2016-8-16 12:28
Read your response, Ken.  "If one ever starts to not feel smooth then you are ok."  If they feel smo ...
Thanks for all the input fellas. I am rotating them now, and although they feel smooth, they also feel like there is a pulse to them. I have flown under normal conditions, (upstate NY) and really dont remember if that pulse was there originally, since February.
2016-8-16
DJI-Ken
I would say true as a general rule I use to determine. Now of course I wouldn't wait years to go by.
2016-8-16
DJI-Ken
Viridis Posted at 2016-8-16 18:58
Air canni ...
The bearings are sealed so you don't have to worry about them but if you do take off or land in a dirty area then you can use compressed air (low pressure) to clear our any grit.
2016-8-16
AG0N-Gary
The pulses are the magnetic poles.  NORMAL.  There should be no noise or gritty feel to them as you turn them.
2016-8-16
