X5 gimbal roll of by 1.4 degrees
1247 6 2016-3-7
Brendancleaves
Flight distance : 1039078 ft
Hi guys
No matter what I do my Inspire pro x5 gimbal roll is always off. Really getting annoying having to change it evertime i power up the drone. Also, if I'm using a two opesator set up, when the camera controler resets the gimbal it also resets te roll, leaving its off again.
Any ideas? is there a way of resetting the master calibration? I've obviosly done all the things i can on the drone, calibrated the gimable etc etc.
Cheers
Brendan
2016-3-7
DJI-Tim
there is the roll adjustment function where you can tilt it manually. Also i would do the IMU calibration as well
2016-3-7
Brendancleaves
Yeah, i can do this but doing it every flight is really annoying. I'll try and adjust the IMU today see if does a full time fix.
2016-3-8
ericfletcher
I'm having the same issue
2016-8-15
Mike-the-cat
Flight distance : 22488593 ft
Typically this happens after pitching down and yawing. It tends to reset after awhile if after you do more manoeuvres. DJI has never fixed this problem but people live with it. This sounds completely unsatisfactory but its the state of the art.
2016-8-15
kner.jiri
Flight distance : 1293199 ft
Czechia
I´m  having the same problem. IMU calibrated, new firmware, no crash............... What is happen dear DJI?
2016-8-17
DJI-Jamie
Flight distance : 112405 ft
kner.jiri Posted at 2016-8-17 17:06
I´m  having the same problem. IMU calibrated, new firmware, no crash............... What is happen  ...
To clarify, are you using the stock 15mm lens or a 3rd party lens?
2016-8-17
