The bettery is liss than 20m
1208 14 2015-2-7
khameesalmasry.
Palestine
Hey guys The bettery is liss than 20m , it's the new p2v+ v3
is ther better than this bettery ? like 1 houre or some thing like that
thank you
2015-2-7
Gerry1124
You will never get a battery that will go an hour.  20 minutes to 23 minutes is about as much flying time as you will get.
2015-2-7
JATO
That battery flight time ~20 mins is about right with maybe 25 mins being the absolute tops. How you fly also determines the flight time. I you just hover it will use less battery than flying aggressively. Also weight plays a role also. In it's heaviest configuration (lights, tracker, QuickRelease w/Zenmuse gim!bal, Hero3 Black, extended skids) my P2V+ weighs in at a whopping ~1490+ grams and my max safe flight time is about 15mins with easy flight.
2015-2-7
gnixon2015
god what we all wouldnt do for an hour of flying time
2015-2-7
PanamonCreel
Mexico
20 minutes, that is actually pretty good for a P2V+,  25 minutes maybe for a bare P2.
Weight is enemy #1 for flight times and the weight it can safely fly with is also limited so your hour or so will have to remain a dream for such a small sized multicopter.
2015-2-7
khameesalmasry.
Palestine
Gerry1124 Posted at 2015-2-8 01:30
You will never get a battery that will go an hour.  20 minutes to 23 minutes is about as much flying ...
it's just to save money for more battery's
2015-2-7
khameesalmasry.
Palestine
JATO Posted at 2015-2-8 01:34
That battery flight time ~20 mins is about right with maybe 25 mins being the absolute tops. How you ...
thank you my friend thees details is very helpfuel thank you
just ime thinking about the lights it's spend most of the bettery i think
2015-2-7
khameesalmasry.
Palestine
gnixon2015 Posted at 2015-2-8 01:50
the qustion is what well do in 20 m ?
you start agame in your pc or ps3 or 4 non stop for 10 hour's
it's agame like atoy >>> yes
2015-2-7
khameesalmasry.
Palestine
PanamonCreel Posted at 2015-2-8 02:14
Weight is ene ...
welly ime not series about a 1 houre but pefor 3 years the dji phantom was adream !!! and now we are talking about it
have anice day my friend
2015-2-7
talk2t_c
As mentioned in other threads the weather can affect the flying time.  Windy conditions can reduce the time as it fights to stay in position.  The temp can also reduce the flying time especially low temps.
Sounds like you're getting some good times there.
2015-2-7
grangerfx.gmail
Flight distance : 817713 ft
I got less than 15 minutes on my last flight and the claxon warning was going off when I landed it. However it seemed like a very long flight to me. I kept checking the battery meter but it seemed go forever when I was flying. I think it was because I was flying all over the place almost never remaining stationary and changed altitude a lot. I bet if I just hovered it would have lasted the full 20-25 minutes.
2015-2-7
fxcrespo.gmail
Ecuador
Someone know if the propellers protectors affect on speed and battery life flying because the longer I can fly is 15 min
2015-2-7
PanamonCreel
Mexico
grangerfx.gmail Posted at 2015-2-8 07:31
I got less than 15 minutes on my last flight and the claxon warning was going off when I landed it.  ...
actually hover is more inefficient than having a constant forward movement
2015-2-7
grangerfx.gmail
PanamonCreel Posted at 2015-2-8 10:44
I guess that's possible but isn't the standard battery life test simply hovering in place?
2015-2-7
khameesalmasry.
Palestine
what do you think guys about this bettery ?
11.1V 6000mAH Battery For DJI Phantom 2 Vision + Quadcopter 66.6wh 10C
2015-2-8
