Phantom 3 Professional - No Signal :(
100971 201 2015-6-7
Shahradkaven
giant Posted at 2015-6-7 18:58
Maybe you should try this: reformat the original SD card and/or reset your Phantom to factory defaul ...
I have a same problem but what do you mean by reset to factory?
2016-2-8
datenpapst
I noticed that there is no signal, when the battery on my phone is below 30-40%.
2016-2-11
Jairo
Hi Guys,
Now I know that the "NO SIGNAL" problem is related to the gimbal.
I have 2 birds (P3P). swapped the gimbal from one to another bird and the problem persist.
When I tried to update the firmware using the same gimbal in different bird I receive the same update firmaware problem:
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.06.0040.bin
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
If I check the hidden log file (inside he \MISC\LOG folder) I the entries above.
As I can see, seems to me that 2 devices are not detected and these devices are that responsible for send the video signal to the smartphone/tablet.
I think that was a problem in the firmware upgrade process that caused these 2 devices do not be upgraded properly, so they will never be started again.
May be DJI can generate a software fix for this, but as a solution (for me that lives outside US) is buy anothe gimbal. :-(
[00014562]========== remo-con disconnect. boot(15) ============
[00014614]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x000cd6fa].
[00014667]Packet upgrade start...
[00014724]Packet checking...
[00014779]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014835]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014888]Done.
[00014944]Version checking[1]...
[00015033][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015134][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015194][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015334][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015457][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015562][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015662][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015762][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028311][15 00][00] device not detected.
[00028422][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028562][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028653][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028707][01 00][00] v1.26.4315 -> v1.26.4315
[00028757][01 01][00] v1.26.4315 -> v1.26.4315
[00041315][08 00][00] device not detected.
[00041475][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041528]Packet upgrade failed at version checking.
2016-2-14
Phil_godley
Jersey
Jairo Posted at 2016-2-14 21:26
Hi Guys,
I have exactly the same problem as Jairo. An upgrade has killed the video feed from my P3P and digging into the hidden file I have the same issue on these two lines and therefore a persistent firmware failure:
Result text file...
========== 2016.02.21 16:01:33 =====================
Result: Failed.
Hidden text file...
[00014554]========== 2016.02.21 16:01:34. boot(15) ============
[00014596]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x70ce1e1c].
[00014641]Packet upgrade start...
[00014688]Packet checking...
[00014730]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014896]Done.
[00014935]Version checking[1]...
[00015036][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015124][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015173][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015301][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015415][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015535][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015635][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015735][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028277][15 00][00] device not detected.
[00028358][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028483][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028555][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028599][01 00][00] v1.26.4315 -> v1.26.4315
[00028648][01 01][00] v1.26.4315 -> v1.26.4315
[00041190][08 00][00] device not detected.
[00041270][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041318]Packet upgrade failed at version checking.
2016-2-21
securenc
Guys, I got my new P3 Pro a week ago. I was having the same “no video” issue as everyone else described in the posts – but mine was no video right out of the box. I have three tablets… a Samsung 10”, LG 8”, and a LG 7” – all Android based. The 7 & 8 inch tablets had the “no video” problem when I tried them first, but then I connected the 10in and presto… I was seeing video. I’m posting this since it may work for some of you whose issue is similar to mine.
What I found: USB Debugging needed to be enabled on my 7 & 8 inch Android tablets.
To enable USB Debugging on your Android device…
1.        Navigate to Settings -> Developer options and enable USB debugging by putting a check in the box. That’s it.
Note: If Developer options is not visible in Settings – some devices it is hidden, then go to Settings -> About phone, and click on Build number 5 times to enable Developer options. Follow step #1 again.
Once I enabled USB Debugging, I turned on the P3 Pro first, then turned on then Controller second and waited for the green ready light, then I plugged my tablet into the USB port. It brought up my DJI App automatically. I selected camera mode for my specific device (P3Pro) and the video started to display correctly then.
I know that most of you guys may have more underlying issues that are firmware or hardware related. But for those of you having trouble… it is worth looking into this setting to see if it could be causing your issues. Maybe the settings went back to default on your tablet/phone at some point.
BTW… My first flight was today and the P3 Pro performed admirably. I was really skeptical about taking it out after reading through every one of these posts on this topic. But it was really easy to fly and maneuver (I have past experience with RC Helis & Airplanes). So I’m gonna chalk my first flight out with the Phantom as a success!
2016-2-28
pm07
Flight distance : 13104 ft
datenpapst Posted at 2016-2-11 19:56
Im stuck in the same boat.
its really disappointing DJI hasn't helped or had any form of input.
It would be nice if one of the forum admins left a decent message saying they are working on the issue with some sort of explantation for the problem.
2016-3-4
pm07
2016-3-4
edwardcollinson
Hey,
I had the exact same problem on my P3P.The 1.5 update caused the damage and essentially bricked the video feed module. It wouldn't update too.
I sent it in for an RMA and it came back as good as before.
Have you tried taking images even though it doesn't show anything?
Just to see if it actually is the same problem as I had. I could take images and they would be stored on the SD card.From the logs I've seen, it looks like you have the same issue as I had.  I suppose you should contact DJI support via email directly. They sorted it all out for me
- Ed
2016-3-4
DSM Ajans
Turkey
Herkese selam. Türkiye'den Türkçe yazıyorum. (Turkey-Turkish)
2 gün önce Phantom 3 Standard satın aldım ve ilk çalıştırmayı dahi yapmadan DJI GO uygulaması güncelleme yapmam gerektiği uyarısı verdi. Güncellemeyi yaptıktan sonra SİNYAL YOK  (NO SIGNAL) uyarısıyla karşılaştım. Araştırma yapıyorum tüm ülkelerden aynı şikayet birçok website de yazılmış. Google Translate ile çeviri yapıyorum yarım anlaşılır halde okumaya çalışıyorum ama kimse çözümü bulamamış. DJI Çin'e gönderenler varmış. Kimiside aldığım firma değişim yaptı yada onarıp gönderdiler diyor ABD'de. Bizim ülkemizde Türkiye'de ise insanlar bu konularda ölü gibi. Bir tane forumu bırak Türkçe tartışma dahi yok, bulamadım. Kendim düşünüyorum forum açmayı artık. Bu sorunun çözümü var mı? Ayrıca fabrika ayarlarına nasıl döneriz?   DJI neden sessiz kalıyor? Neden acil çözüm üretmiyor? Duyarsızlık DJI'a yakışmıyor! Bu saçmalığa son vermelisiniz DJI!.. Olumlu olumsuz dönüş yapın. - dsmajans@gmail.com
2016-3-5
office
Dominica
It seems this thread is quite old, many months since first problems with novideo feed oproblem reported. And yet - I can't find any working solution from DJI. What a shame.
I am the new guy in No Vision club, same as you all posted. I re-installed app, did updates, checked cables, all things described in this thread. nothing works. black screen. Video and photos are recorded on SD card, i can even see live histogram changes as camera moves around - but no actual image.
It is my 3rd phantom, and I experienced terrible lack of support from DJI some 2 years ago when i bought P2 with a badly assembled remote.  UIt seems DJI did not improve their service a bit. So, I still hope that someone will find out about this problem and share.
As for the POOR SIGNAL and interfererence message - I had it too after firmware updates. What helped it in my case was un-installing the app, and then downloading/installing it on my smart phone again.   I find it surprising how fragile and how prone to errors this system is.  On my P2 i added FPV home system using parts from ebay - and it works without any issues, while this high-end system has so many issues.
DJI created wonderful technology, but is plagued by bad quality control and non-existent support, so we all pay big bucks to be their beta testers. Seems that once they get our money, we served our purpose. A very short sighted strategy, and one day their good fortune baloon may burst.   Phantom 3 Professional? there is nothing professional about unit not working straight from the box.
2016-3-16
jerryjonz
I have the same problem, anyone found an answer for it?
2016-3-18
office
Dominica
the NO VIDEO SIGNAL FEED problem SOLVED - at least in my case.
After spending lots of time trying to fix it - I asked my friend to come with a brand new ASUS tablet, running the newest android on it. i think 6.1
Guess what? video magically appeared!!!
So, it shows that the app is fussy or buggy, and does not want to work on everything, even if listed as ok (I tried  before on samsung note3)
Now i need to spend another $150 or so on a new tablet - but it will work!
Cheers!
2016-3-19
jerryjonz
office@ozonezon Posted at 2016-3-19 11:11
After spending lots of time trying to ...
Has DJI shown any interest in this problem yet?
Anyone know of any response?
2016-3-19
gwilliamiv
Flight distance : 130817 ft
Having same issue on my P3 standard after replacing ribbon cable. Everything works fine after powering up but camera stops communicating and droops after about 10secs. Video is still live but no communication with gimbal and RC......
2016-4-6
gwilliamiv
Tried buying another base gimbal but still same issue. Anybody have any solutions?
2016-4-6
lesrkent
Flight distance : 83307 ft
this was posted elsewhere on here sorry I forgot who, but this got me flying again albeit only on my note 3 and not my Galaxy tab 3
for some odd reason, but at least I can fly..........
2016-5-27
stevehange
I'll add my Phantom 3 Adv to the list of MIAs. I've been flying it with no problem for several months.
All of a sudden today, I get the red "No Signal" on startup. After several shut down startups, (typically start RC, load app, turn on quad), it's never failed.
I could start the rotors and fly it w/no problem.  But screen said "No signal" and i had no video.
I brought it home and tried again in my back yard. Now I get a gray "Disconnected". The RC has a Red LED instead of green.
The rotors will not start.  I recently updated firmware and controller, but I will check for updates.
I see several posts w/this problem but they are one a year old. Was it solved?
Thanks for any new information.
2016-6-8
ottowesterlundh
I've got a similar problem.
DJI Phantom 3 4k
Samsung Note 4
I lose connection to the drone when it is 10m away in the air.
I can still control the drone and it still saves to the SD-card but I get no image to the phone.
I've only flown at 4 different locations and this has occurred at all of them but not always. Yesterday I reset the drone controller connection like in this video but I have not tried it out yet to see if it worked.
I don't use a cable between my phone and the controller. Do I need to?
2016-7-13
ottowesterlundh
I can answer my own post.
Today I test flew it again and now it seems to work better. But if I take off and fly almost directly over me I still lose contact after about 25-30m up.
What I did was to reinstall the app and to re-link the controller. I flew today at the same spot as the last.
2016-7-14
ajayrdshah
Flight distance : 9311 ft
Hi ottowesterlundh
I have the exact same set up as yours and I tried the above video and it DOES NOT work. It's really annoying. I was on a live chat with DJi today and they took so long to understand the problem that I gave up.
I will try again tomorrow otherwise will return the P3 4K and look at other models on the market because this is RIDICULOUS !!!!!!
2016-7-14
rick
After searching, it looks like there is NO FIX.
I tried all of the same tricks.
On line with support for an hour and now sending it back.
A total of 30 minutes of flight time on this unit.
DJI continues to fail to respond with solutions.
This has been going on for a year now?
{:4_154:}
2016-9-12
DJI-Ken
Flight distance : 1515312 ft
rick@ohearn.com Posted at 2016-9-12 23:40
On line with support ...
Rick,
What exactly are you experiencing, this thread is a few months old and from the last posts the camera was not working after a firmware update. Is this your issue and you've seen your hidden log file and modules 8 & 15 say device not detected?
2016-9-12
bryan1188
Philippines
Hi Ken,
I'm having the same issue. The gimbal will initialize for the first 5-10 seconds after power on but after that the gimbal will go limp and just hanging. I'm using the updated firmware.
2016-9-13
OldFlyer
DJI-Ken Posted at 2016-9-12 09:02
Rick,
What exactly are you experiencing, this thread is a few months old and from the last posts  ...
Ken,
I have  no devices  8 and 15 detected too.
[00013169]========== 2016.09.12 12:41:44. boot(15) ============
[00013253]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x1010d65b].
[00013336]Packet upgrade start...
[00013435]Packet checking...
[00013516]Packet vlink 01.09.0060 <-> 01.08.0080.
[00013605]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013686]Done.
[00013773]Version checking[1]...
[00013886][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014027][03 06][00] v2.4.20.18 -> v2.4.20.18
[00014112][04 00][00] v1.44.0.0 -> v1.44.0.0
[00014291][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014467][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014549][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014694][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014839][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014975][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015101][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027681][15 00][00] device not detected.
[00027816][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027976][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028087][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028289][01 00][00] v1.30.5036 -> v1.30.5036
[00028374][01 01][00] v1.30.5036 -> v1.30.5036
[00040954][08 00][00] device not detected.
[00041053][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041136]Packet upgrade failed at version checking.
I've read this is a hardware problem.   I purchased this p3p in March, 2015 but have never flown it.   I've been keeping the firmware up to date but the most recent update (1.9) failed and seems to have  triggered the hardware problem.  How can this happen? I can record video but nothing gets transmitted.  The Go APP show all the latest firmware versions installed.
Please advise what should be done as I've run out of things to try.
Fred
2016-9-15
DJI-Ken
OldFlyer Posted at 2016-9-16 06:52
Ken,
I'm sorry there's nothing you can do, you need to send it in for repair.
If the flight data recorder shows it's never been flown, they may offer some assistance but I'm just guessing and honestly don't know what will happen.
Call 818-235-0789 in the morning and they will send you a prepaid shipping label.
I am sorry about that.
2016-9-15
info
Indonesia
I have similar problems with my P3P.
The app on my Galaxy tab3V often shows NO SIGNAL but I am able to fly it without any problems.
The NO SIGNAL only refers to the camera signal and the screen goes to black and white.
This is very annoying as it stops you from being able to film and making pictures plus causing orientation problems.
During flight, when I go to immage transmission settings I can switch from custom to auto and this normally brings the signal back for a minute or so.
But then it is lost again.
I had this issue actually from the beginning but it is getting worse and worse. Now to such a point where I am no longer able to film and make pictures.
I tried all the advices and tips as mentioned in previous postings but nothing fixes the problem permanently.
I am an expat living in Indonesia and sending it for repair is not a doable option.
Any new tips or fixes on this matter?
2016-9-16
info@lumbalumba Posted at 2016-9-17 12:45
The app on my Galaxy tab3V often shows NO SIGNAL but I am able ...
The first thing DJI is going to say to you is to try a different device other than the Galaxy.
2016-9-16
skylabboston
It is related to failed hardware in board. No signal error can be repaired. We repair them daily!
2016-9-19
usere3817a6b33
I bought a Phantom 3 Professional lastweek and found the signel wasn't as great a claimed (was getting alot of interference in flight and loosing signal) i went flying with a friend who has a Phantom 4 yesterday who told me to put my phone on 'airplane mode' reconnect the wifi. I done just that and was blown away with the difference. Such a massive improvement i have no issues now
2016-9-25
warloc59
Flight distance : 209160 ft
Same issue also with a disconnected error.  I was using a third party lightning cable because I forgot my iPhone brand cable.  Borrowed an iPhone cable from friend.  Problem solved.
2016-9-25
mhardgrave
warloc59 Posted at 2016-9-25 21:37
Same issue also with a disconnected error.  I was using a third party lightning cable because I forg ...
I have this same problem an this is how I have solved it.  It is a pain, but it works.
I use the short cord that came with the controller to the port on the P3P.  I turn on the controller and then turn on the P3P.  It beeps a few seconds and then I get a green light on the controller. I turn both of them off and unplug from the P3P.  Start up as normal and I get the green light and can fly.  I am not sure why this works, but that's how I have to get my controller to talk to the aircraft.  Hope this will help.
2016-9-26
paxos2k
Flight distance : 335860 ft
I had the same problem I guess, video signal dropped in flight or as soon as i moved the Phantom.
Solution: Remove the gimbal, check the cables, replace if necessary. Fixed it for me.
2016-9-27
lumbalumba
Indonesia
info@lumbalumba Posted at 2016-9-17 10:45
In addition to my earlier post, I am now only flying in 'no-flight' mode on my tablet. Not sure if it is completely solved but it is much much better than it was before. After 6 flights I did not have a lost signal any more...
2016-10-1
smoowall
I found out I am having same trouble with my drone  advance I am using a Samsung tap  today I started after it was working last night was blank again I shut the remote off had the app running for 3 min then turned remote on and it connected been trying all the other stuff it's the app is missed up
2016-10-2
smoowall
kill1308 Posted at 2015-6-7 10:57
Forgot to mention, I did search the forum beforehand, but all similar posts seem to be related to th ...
Having same problem  iam on a samsung tab getting disconnected  what i had work for me now is leave the app on shut the remote off for about 3 min then turn the remote on and it connected  only thing i have found that worked other then uninstall the dji go app then reinstall then I had it work for the night lost all the pics my first time trying all the other but this worked for me
2016-10-2
Dan O
Flight distance : 650768 ft
Romania
Is there a fix?
2016-11-12
Dan O
Romania
Just to make ti clearer:
P3P-all went fine from one day to another i could not see the image anymore. No error message instead
2016-11-12
usere20b33e1db
Vanuatu
Hi guys I'm french.
I have a problem with my dji phantom 3 advanced.
Wen I put one my drone they telling me there's "NO SIGNAL"
like this video
So I would like to now how to fix it
2017-1-11
fans35ba6f62
Georgia
You need shortest and the best quality cable. Most probably, you use central USB outlet. That one may not show image for known to only DJI and Apple reason, but my guess is that video is sent over there with very precious timing, and long low quality cables just drop something.
Try original short cable from microusb outlet, it should work fine.
2017-2-27
Pgregory
kingroad18 Posted at 2015-7-25 19:58
Update:  It appears that my system goes into an update mode which it does not ever recoverfrom, leaving a loud sound (not noise) from the gimbal area.  If I completely clean my SD card and insert it, it does not try to do the update and there is no gimbal sound.  Still not video on Apple, but no noise.
Looking at the .txt file, it appears to me that this P3P has been attempted to have downloaded firmware many unsuccessful times prior to my owning it?????
I know it's been ages since you posted this, but I am having the EXACT same problem. My .txt file shows every update ever, including ones that I didn't do, and many of them failed, a few say success, a few say abort. NO solution yet. Tried everything. About to just junk the thing. It was working fine before I attempted to update... Anyone have a solution for this yet?
2017-4-7
