How to determine Firmware Update Installed
5631 6 2015-2-10
miketeel
Flight distance : 184567 ft
I'm confused at bit by Firmware versions. The current version of the Firmware (package) is v1.2.0.16. I can't tell what package is installed on the Inspire. When I go to Settings/About I get a listing of the verious firware versions installed but can't tell which package of firmware versions is intalled.
How can I teel which package or overall version is installed?
2015-2-10
dundee
Flight distance : 33550 ft
Latest version = Latest version.
dont worry. its fine
2015-2-10
rsghowellnj.gma
Flight distance : 508255 ft
dundee Posted at 2015-2-11 14:49
Quick question guys
I just ordered my Inspire 1.  I'm assuming that DJI will have updated the firmware to the latest version.  But don't want to take a chance.  Once I connect my controller to my Inspire 1.  Please confirm that all I will need to do to see the current version of the firmware is:
Launch the App
Go into Settings and about to see the current version of the firmware installed
I would appreciate the feedback.  Thanks
2015-2-11
UM305
Just compare this screen with your device.
2015-2-11
miketeel
I think, not sure, that the new app does check via the internet (checks with DJI). That must be how the app can report Firmware is Current the system status window.
2015-2-11
FoxSTI
Flight distance : 11286 ft
very confusing with the versions. Apparently from what I am seeing, what the controller/app shows as 1.15 = 1.02.00.16... Why not just be consistent DJI?
BTW I have Remote Controller 1.04
2015-2-13
andi.witech
What you need to do to check if firmware is updated.
1: unzip firmware in the root folder
2: put it in your inspire 1
3: turn it on(maybe look in app for firmware update progress"it will not show anything if you are on the newest firmware)
4: then you need to turn your inspire off.
5: put the sd card back in your pc and open the .txt file to look at firmware progress log
Or look in app, either way is good :-)
2015-2-14
