New Firmware for Phantom 3 Pro/Adv has been Released
DJI-Ken
Flight distance : 1515312 ft
DJReemo Posted at 2016-10-4 19:32
I guess not because I had it for 2 years. But why should I have to pay when all I did was a simple ...
I am sorry, I did go talk to the repair shop and they cannot repair it under warranty as it's 2yrs old.
I tried though, I'm sorry.
2016-10-5
dbostock
DJI-Ken thanks for that info re flight distance. Can you advise what changes are made to the Phantom to make it FCC compliant or CE compliant?
Im aware since an earlier verion of the DJI GO app DJI have reduced the available transmission channels from 32 to 8 this is to make it FCC compliant since it was reported on an RC group that the 32 channels made the P3 fly on illegal channels used buy cellular etc, thats fine.. however the way you have gone about doing it isnt. I haven't seen any information about this when updating the DJI GO app that you made this change or anywhere else from DJI at all. If DJI could be open about this instead of pretending you dont know why people now have these issues listed in the thread. Its because there is now only 8 available transmission channels to fly on making it more difficult to get a stable connection.
2016-10-5
dbostock
Ok for the update with my P3 that was sent to DJI for range issue. When I sent it, it had the v1.8 firmware on as the range issue is more prevalent in v1.9. DJI tech did a test flight and said no issues and sent me a screen shot they flew it about 700m. I replied back asking if it was done on firmware v1.9 and what the furthest distance they got was and 700m wasn't sufficient to say they're is no issue as this is less than half of advertised range. They replied back saying they would test again and get back to me. Next day I get an email they had flown 800m and screen shot showing its still on v1.8 firmware! I replied back saying I have told them multiple times the issue is more prevalent on v1.9 firmare and to retest with v1.9 firmware, I even put a letter in the box stating this. Next thing today I get email they have shipped it back! So it was never even tested properly! I don't know how many times I need to tell them to test on v1.9. I said it once when I logged the call. 2nd time in letter I put in box and 3rd time via reply email after first test.. is that not enough times?
2016-10-5
jacmac64
DJI-Ken Posted at 2016-10-5 23:51
Who ever said anything about no more firmware updates.
There will continue to be updates, only the ...
I guess i missed understood you.
I'm not sure what you mean what procedure, Is there multiple ways to install firmware?
I'm using an micro sd card. I've tried different ones, always the same thing. Everything goes good for quite awhile. Then red light on the front of the gimble and solid beep. Then i have little to no video, so i have to reinstall previous version.
2016-10-6
DJI-Ken
dbostock Posted at 2016-10-6 05:42
DJI-Ken thanks for that info re flight distance. Can you advise what changes are made to the Phantom ...
What makes DJI aircraft go into FCC or CE mode is the GPS location when you power up the aircraft.
And the channels have been 8 for quite a while, so if you are having any transmission issues and have done all troubleshooting steps then contact support and send your aircraft to be evaluated.
It's not legal to use the 32 channels so DJI does not offer it, but search the internet and you can find more on it.
2016-10-6
DJI-Ken
dbostock Posted at 2016-10-6 15:52
Ok for the update with my P3 that was sent to DJI for range issue. When I sent it, it had the v1.8 f ...
I am sorry you are having difficulties.
What is your case# and I can file a complaint for you.
2016-10-6
DJI-Ken
jacmac64 Posted at 2016-10-6 17:37
I'm not sure what you mean what procedure, Is there multiple way ...
You say everything goes good for a while. So when powering the aircraft and it starts the update and it makes the 4 beeps and the camera LED flashes Red/Green?
2016-10-6
jacmac64
DJI-Ken Posted at 2016-10-6 23:05
You say everything goes good for a while. So when powering the aircraft and it starts the update a ...
That's correct. The update ran exactly as expected for about 5 to 10 min. (don't remember the exact amount of time because this was back when the firmware was first release,I think June). Then the LED would go solid red and the beep would change to a solid beep. I tried multiple times and every time the same thing.
I've posted about this before, some where near the beginning of this topic.
2016-10-7
DJI-Ken
jacmac64 Posted at 2016-10-7 23:42
That's correct. The update ran exactly as expected for about 5 to 10 min. (don't remember the exac ...
I'm not sure why your aircraft will not take 1.9. Can you post a video of the process so I can see the the LED's and hear the tones?
2016-10-7
jacmac64
DJI-Ken Posted at 2016-10-8 00:08
I'm not sure why your aircraft will not take 1.9. Can you post a video of the process so I can see ...
I would gladly send you a video of this, but I didn't film it. For me to make a video I'd be installing a firmware that I know causes an issue with my Phantom. If I couldn't recover this time DJI would charge me to fix, even though it is there firmware causing the problem.
I bought mine May 2015 when they first were released. I've installed every firmware that was released with no problems until 1.9. I've seen a lot of people in the past with issues caused by firmware and they go though a lot of pain to get it resolved.
Mine is currently working now, so I'll wait till the next release. Which I'll install if I can do so without v1.9.
2016-10-7
DJI-Ken
jacmac64 Posted at 2016-10-8 00:49
I would gladly send you a video of this, but I didn't film it. For me to make a video I'd be insta ...
Myself and all the aircraft at work and all my friends who have a Pro/Adv have not had an issue installing 1.9. So that's why I was asking for a video, to see if I see anything unusual.
You can send it in and the repair shop can install 1.9 if you wish.
2016-10-7
ghoonk
Flight distance : 394626 ft
United Arab Emirates
Updated my P3P the evening before yesterday as I was traveling and needed the P3P for some footage. Latest firmware installed successfully, batteries all updated, no update warning for the RC, and DJI Go is up to date.
I'm having a significant amount of problem with this firmware as the video stream gets heavily pixelated (Note 7 and iPhone 6 Plus) and in many cases, only half the screen is displayed. I have no idea what's causing this and it certainly wasn't the case with my older firmware.
Also, I've just noticed that with the new DJI Go, I can no longer find the AEB function (even pressing and holding down the shutter button doesn't open that menu as it used to), nor the option for a HDR shot, etc
2016-10-8
Dompie
I have the same issue with the new firmware update.  I do not appreciate beeing a '' beta tester site '' for a company that could buy me out more than 2000 times within a few seconds. That said, I understand that there could SOOO much '' code 18 '' issues  ( CODE 18 MEANS THAT THE PROBLEM LIES 18'' AWAY FROMTHE DRONE ) and it could be very frustrating for DJI to cope with these issues over a day period.
Now, back to my issue, the update process does not seems to complete itself, I tried to roll back to version 1.08 without success, I get the message (( same version on drone and SD card ) when I try to install version 1.09, It does not complete, the gimball shows a RED led color.
HELP !!!!!!!
2016-10-10
ftVWqOC7qJzf
China
Today, smart phones, PDAs, cameras, etc. can be said that all the necessary digital products, but these are generally not difficult to find the digital product itself is not high capacity, to meet the digital up to people's needs is difficult, the more battery life increasingly short, we need a high-quality power bank, can be a good solution to these problems. For demand, it should be a kind of mobile power need it? Usually they want to move large power capacity, but compact and easy to carry. Simple design and unique personality. Most importantly, the use of safe, all the above are satisfied, is having a very good price.
http://www.qqpowerbank.com/powerbank/
2016-10-13
DJReemo
DJI-Ken Posted at 2016-10-5 12:10
I am sorry, I did go talk to the repair shop and they cannot repair it under warranty as it's 2yrs ...
So I guess its safe to say that if I have any firmware issues in the future, then I may as well get my checkbook out for payment.
Wow
Had no Idea a simple firmware update could damage the camera, which is basically what just happened to me.
And the sad part is my drone has been received by DJI 9/16/16, and I'm still waiting on an invoice so I can pay and have it sent back to me. This is just so frustrating, because my drone is a tool for work.
2016-10-13
DJReemo
Wow
2016-10-13
DJReemo Posted at 2016-10-14 11:40
So I guess its safe to say that if I have any firmware issues in the future, then I may as well ge ...
I'm sorry you are experiencing difficulties.
Could you please provide me with your case number?
I'll help to look into your case.
2016-10-14
gilbert85295
So....Here's my issue and I am hoping someone can give me a little feedback.  My DJI DO App on my Android phone updated to version 3.0.0 today.  When I attempt to install the firmware update on my Phantom 3 Advanced to version 1.9.60 the txt log tells me it was successful and that it also failed since I was already at that update version.  When I start the transmitter and then the Phantom 3 Advanced I am told I need to install an updated firmware.  Any one have any suggestions?  Is it safe to fly with the app at 3.0.0 and the firmware for the drone itself not updated?  Thanks for the assistance and advice in advance
2016-10-14
Phantomski
Flight distance : 14869882 ft
I just upgraded the radio to 1.8.0 and the app to 3.0.0, but my advanced already was at 1.9.60, so nothing to do. Did not fly yet, but all the settings and status seem ok...
You did restart your radio and the go app after updates?
Did you re-download the firmware and put it on the sd card and then the card in the camera sd slot? Did you boot up your drone with EVERY battery you own, to allow it to upgrade every battery to that fiormware version?
Can you post a screenshot of what is happening and perhaps the about screen like the one attached?I do not remebver how to check battery, i think you havce to go into battery menu and somewhere in there, but the main screen, if it's screaming about firmware, it should say specifically what it's unhappy about.
2016-10-14
Kalvis
Flight distance : 2808 ft
Latvia
Can not update remote controller to version v1.9.60, plug usb to controller with P3X_FW_V01.09.0060.bin file  and nothing happens, red button appears on controller.
Printscreen
Printscreen
2016-10-15
roldanmoya
Flight distance : 239308 ft
Kalvis Posted at 2016-10-16 08:59
Can not update remote controller to version v1.9.60, plug usb to controller with P3X_FW_V01.09.0060. ...
You are in the last version actually.
The remote controller update from the DJI app (internet connection required) to the last version 1.8.0 (actually). The 1.9.60 is the firmware version of the aircraft, and is the latest too.
2016-10-16
zhaf91
Malaysia
I have phantom 3 advance...I use the latest firmware..1.9.6 and install DJI GO app 3.0.0 ...
i got problem with the new update which is got problem with the range.. i just can fly 300m only..then my signal of image transmission lost. sometime remote signal also lost and the A/C return to home..
i try to find the solution on youtube, find solution in forum, contact DJI Support but not resolve the problem..
i try to downgrade but there's no firmware available to be choose in DJI go app..
in 'about' the information of the A/C & R/C was "N/A"...
please help me......
-range issue with new firmware-cannot downgrade-firmware info unknown in DJI GO app
***********this is my log result AB: ************************
[00012048]========== remo-con disconnect. boot(15) ============
[00012231]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x631032b0].
[00012281]Packet upgrade start...
[00012336]Packet checking...
[00012377]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012450]Done.
[00012496]Version checking[1]...
[00012575][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012654][03 06][00] v2.4.15.5 -> v2.4.20.18 need upgrade.
[00012703][04 00][00] v1.44.0.0 -> v1.44.0.0
[00012831][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00012950][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00012997][11 01][00] v1.7.0.0 -> v2.0.0.33
[00013084][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013184][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013264][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013339][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017884][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017985][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018125][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018184][19 00][00] v255.255.255.254 -> v1.0.8.96
[00018227][01 00][00] v1.23.4920 -> v1.23.4920
[00018269][01 01][00] v1.23.4920 -> v1.23.4920
[00018324][09 00][00] v3.0.0.10 -> v3.0.0.10
[00018365]Done.
[00020410]Waiting for user confirm...
[00030450]Timeout, start upgrade automatically.
[00030539]Firmware upgrading[1]...
[00030589][11 00] Firmware upgrade start...
[00079035][11 00] Firmware upgrade finished successfully.
[00079314][03 06] Firmware upgrade start...
[00409005][03 06] Firmware upgrade finished successfully.
[00409050]Done.
[00409093]Version checking[2]...
[00409175][03 05][00] v34.2.0.9 -> v34.2.0.9
[00409275][03 06][05] v2.4.20.18 -> v2.4.20.18
[00409328][04 00][00] v1.44.0.0 -> v1.44.0.0
[00409456][11 00][05] v1.8.0.0 -> v1.8.0.0
[00409596][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00409636][11 01][00] v1.8.0.0 -> v2.0.0.33
[00409730][12 00][00] v1.10.0.0 -> v1.10.0.0
[00409827][12 01][00] v1.10.0.0 -> v1.10.0.0
[00409929][12 02][00] v1.10.0.0 -> v1.10.0.0
[00410135][12 03][00] v1.10.0.0 -> v1.10.0.0
[00410180][15 00][00] v1.1.2.0 -> v1.1.2.0
[00410279][17 00][00] v1.1.1.7 -> v1.1.1.7
[00410428][17 01][00] v1.0.2.7 -> v1.0.2.7
[00410494][19 00][00] v255.255.255.254 -> v1.0.8.96
[00410546][01 00][00] v1.23.4920 -> v1.23.4920
[00410587][01 01][00] v1.23.4920 -> v1.23.4920
[00410649][09 00][00] v3.0.0.10 -> v3.0.0.10
[00410699]Packet upgrade finish successfully.
[00011996]========== remo-con disconnect. boot(15) ============
[00012040]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x631032b0].
[00012081]Packet upgrade start...
[00012125]Packet checking...
[00012181]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012220]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00012263]Done.
[00012310]Version checking[1]...
[00012387][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012475][03 06][00] v2.4.20.18 -> v2.4.20.18
[00012523][04 00][00] v1.44.0.0 -> v1.44.0.0
[00012810][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00012926][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00012980][11 01][00] v1.7.0.0 -> v2.0.0.33
[00013080][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013155][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013260][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013338][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017883][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017955][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018075][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018147][19 00][00] v255.255.255.254 -> v1.0.8.96
[00018191][01 00][00] v1.23.4920 -> v1.23.4920
[00018235][01 01][00] v1.23.4920 -> v1.23.4920
[00018300][09 00][00] v3.0.0.10 -> v3.0.0.10
[00018351]Done.
[00020393]Waiting for user confirm...
[00030436]Timeout, start upgrade automatically.
[00030531]Firmware upgrading[1]...
[00030583][11 00] Firmware upgrade start...
[00080725][11 00] Firmware upgrade finished successfully.
[00080771]Done.
[00080813]Version checking[2]...
[00080877][03 05][00] v34.2.0.9 -> v34.2.0.9
[00080951][03 06][00] v2.4.20.18 -> v2.4.20.18
[00081125][04 00][00] v1.44.0.0 -> v1.44.0.0
[00081275][11 00][05] v1.8.0.0 -> v1.8.0.0
[00081390][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00081439][11 01][00] v1.8.0.0 -> v2.0.0.33
[00081544][12 00][00] v1.10.0.0 -> v1.10.0.0
[00081625][12 01][00] v1.10.0.0 -> v1.10.0.0
[00081724][12 02][00] v1.10.0.0 -> v1.10.0.0
[00081851][12 03][00] v1.10.0.0 -> v1.10.0.0
[00081896][15 00][00] v1.1.2.0 -> v1.1.2.0
[00081985][17 00][00] v1.1.1.7 -> v1.1.1.7
[00082100][17 01][00] v1.0.2.7 -> v1.0.2.7
[00082165][19 00][00] v255.255.255.254 -> v1.0.8.96
[00082215][01 00][00] v1.23.4920 -> v1.23.4920
[00082257][01 01][00] v1.23.4920 -> v1.23.4920
[00082325][09 00][00] v3.0.0.10 -> v3.0.0.10
[00082377]Packet upgrade finish successfully.
[00012019]========== remo-con disconnect. boot(15) ============
[00012062]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x631032b0].
[00012107]Packet upgrade start...
[00012162]Packet checking...
[00012206]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012251]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00012294]Done.
[00012347]Version checking[1]...
[00012412][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012492][03 06][00] v2.4.20.18 -> v2.4.20.18
[00012558][04 00][00] v1.44.0.0 -> v1.44.0.0
[00012812][11 00][00] v1.8.0.0 -> v1.8.0.0
[00012932][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00012988][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013066][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013166][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013266][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013366][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017917][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018009][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018123][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018202][19 00][00] v255.255.255.254 -> v1.0.8.96
[00018246][01 00][00] v1.23.4920 -> v1.23.4920
[00018290][01 01][00] v1.23.4920 -> v1.23.4920
[00018382][09 00][00] v3.0.0.10 -> v3.0.0.10
[00018425]Packet upgrade cancelled at version checking.
[00010774]========== 2016.06.26 17:25:43. boot(15) ============
[00010822]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x631032b0].
[00010907]Packet upgrade start...
[00010965]Packet checking...
[00011011]Packet vlink 01.09.0060 <-> 01.08.0080.
[00011052]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00011094]Done.
[00011135]Version checking[1]...
[00011238][03 05][00] v34.2.0.9 -> v34.2.0.9
[00011355][03 06][00] v2.4.20.18 -> v2.4.20.18
[00011425][04 00][00] v1.44.0.0 -> v1.44.0.0
[00011536][11 00][00] v1.8.0.0 -> v1.8.0.0
[00011675][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00011720][11 01][00] v1.8.0.0 -> v2.0.0.33
[00011821][12 00][00] v1.10.0.0 -> v1.10.0.0
[00011917][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012000][12 02][00] v1.10.0.0 -> v1.10.0.0
[00012096][12 03][00] v1.10.0.0 -> v1.10.0.0
[00016641][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016719][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016859][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016915][19 00][00] v255.255.255.254 -> v1.0.8.96
[00016959][01 00][00] v1.23.4920 -> v1.23.4920
[00017000][01 01][00] v1.23.4920 -> v1.23.4920
[00017055][09 00][00] v3.0.0.10 -> v3.0.0.10
[00017096]Packet upgrade cancelled at version checking.
[00012405]========== remo-con disconnect. boot(15) ============
[00012449]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x631032b0].
[00012491]Packet upgrade start...
[00012551]Packet checking...
[00012620]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012664]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00012714]Done.
[00012758]Version checking[1]...
[00012827][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012906][03 06][00] v2.4.20.18 -> v2.4.20.18
[00012973][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013085][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013206][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013251][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013335][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013600][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013707][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013807][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013862][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013957][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014073][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014155][19 00][00] v255.255.255.254 -> v1.0.8.96
[00014210][01 00][00] v1.23.4920 -> v1.23.4920
[00014258][01 01][00] v1.23.4920 -> v1.23.4920
[00014315][09 00][00] v3.0.0.10 -> v3.0.0.10
[00014367]Packet upgrade cancelled at version checking.
[00012130]========== 2016.06.26 17:56:40. boot(15) ============
[00012177]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x631032b0].
[00012229]Packet upgrade start...
[00012285]Packet checking...
[00012339]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012386]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00012440]Done.
[00012493]Version checking[1]...
[00012577][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012703][03 06][00] v2.4.20.18 -> v2.4.20.18
[00012771][04 00][00] v1.44.0.0 -> v1.44.0.0
[00012903][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013037][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013089][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013187][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013312][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013423][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013523][12 03][00] v1.10.0.0 -> v1.10.0.0
[00018072][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018164][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018305][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018381][19 00][00] v255.255.255.254 -> v1.0.8.96
[00018427][01 00][00] v1.23.4920 -> v1.23.4920
[00018476][01 01][00] v1.23.4920 -> v1.23.4920
[00018542][09 00][00] v3.0.0.10 -> v3.0.0.10
[00018589]Packet upgrade cancelled at version checking.
[00012363]========== remo-con disconnect. boot(15) ============
[00012406]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x4e5c7367].
[00012449]Packet upgrade start...
[00012502]Packet checking...
[00012642]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012685]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00012729]Done.
[00012770]Version checking[1]...
[00012849][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012927][03 06][00] v2.4.20.18 -> v2.4.20.18
[00012976][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013110][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013247][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013290][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013402][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013501][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013602][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013703][12 03][00] v1.10.0.0 -> v1.10.0.0
[00018257][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018352][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018491][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018562][19 00][00] v255.255.255.254 -> v1.0.8.96
[00018605][01 00][00] v1.23.4920 -> v1.23.4920
[00018649][01 01][00] v1.23.4920 -> v1.23.4920
[00018702][09 00][00] v3.0.0.10 -> v3.0.0.10
[00018753]Packet upgrade cancelled at version checking.
[00010598]========== remo-con disconnect. boot(15) ============
[00010643]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x4e5c7367].
[00010692]Packet upgrade start...
[00010744]Packet checking...
[00010795]Packet vlink 01.09.0060 <-> 01.08.0080.
[00010838]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00010881]Done.
[00010932]Version checking[1]...
[00011007][03 05][00] v34.2.0.9 -> v34.2.0.9
[00011084][03 06][00] v2.4.20.18 -> v2.4.20.18
[00011146][04 00][00] v1.44.0.0 -> v1.44.0.0
[00011265][11 00][00] v1.8.0.0 -> v1.8.0.0
[00011384][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00011426][11 01][00] v1.8.0.0 -> v2.0.0.33
[00011513][12 00][00] v1.10.0.0 -> v1.10.0.0
[00011613][12 01][00] v1.10.0.0 -> v1.10.0.0
[00011693][12 02][00] v1.10.0.0 -> v1.10.0.0
[00011793][12 03][00] v1.10.0.0 -> v1.10.0.0
[00016337][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016408][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016654][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016709][19 00][00] v255.255.255.254 -> v1.0.8.96
[00016760][01 00][00] v1.23.4920 -> v1.23.4920
[00016804][01 01][00] v1.23.4920 -> v1.23.4920
[00016869][09 00][00] v3.0.0.10 -> v3.0.0.10
[00016912]Packet upgrade cancelled at version checking.
[00012093]========== remo-con disconnect. boot(15) ============
[00012137]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x4e5c7367].
[00012188]Packet upgrade start...
[00012240]Packet checking...
[00012284]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012327]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00012371]Done.
[00012414]Version checking[1]...
[00012505][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012588][03 06][00] v2.4.20.18 -> v2.4.20.18
[00012654][04 00][00] v1.44.0.0 -> v1.44.0.0
[00012806][11 00][00] v1.8.0.0 -> v1.8.0.0
[00012945][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00012989][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013089][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013194][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013294][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013394][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017950][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018033][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018150][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018205][19 00][00] v255.255.255.254 -> v1.0.8.96
[00018250][01 00][00] v1.23.4920 -> v1.23.4920
[00018294][01 01][00] v1.23.4920 -> v1.23.4920
[00018366][09 00][00] v3.0.0.10 -> v3.0.0.10
[00018410]Packet upgrade cancelled at version checking.
[00012096]========== 2016.10.07 18:44:46. boot(15) ============
[00012142]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x4e5c7367].
[00012195]Packet upgrade start...
[00012245]Packet checking...
[00012292]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012336]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00012380]Done.
[00012425]Version checking[1]...
[00012524][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012603][03 06][00] v2.4.20.18 -> v2.4.20.18
[00012767][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013023][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013069][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013171][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013271][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013375][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013502][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013555][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013652][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013792][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013889][19 00][00] v255.255.255.254 -> v1.0.8.96
[00013939][01 00][00] v1.23.4920 -> v1.23.4920
[00013984][01 01][00] v1.23.4920 -> v1.23.4920
[00014062][09 00][00] v3.0.0.10 -> v3.0.0.10
[00014107]Packet upgrade cancelled at version checking.
[00010562]========== 2016.10.07 19:05:58. boot(15) ============
[00010607]Packet [C:\P3S_FW_V01.09.0060.bin] detected, card sn [0x4e5c7367].
[00010657]Packet upgrade start...
[00010706]Packet checking...
[00010755]Packet vlink 01.09.0060 <-> 01.08.0080.
[00010800]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00010849]Done.
[00010892]Version checking[1]...
[00010995][03 05][00] v34.2.0.9 -> v34.2.0.9
[00011075][03 06][00] v2.4.20.18 -> v2.4.20.18
[00011126][04 00][00] v1.44.0.0 -> v1.44.0.0
[00011258][11 00][00] v1.8.0.0 -> v1.8.0.0
[00011436][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00011481][11 01][00] v1.8.0.0 -> v2.0.0.33
[00011597][12 00][00] v1.10.0.0 -> v1.10.0.0
[00011694][12 01][00] v1.10.0.0 -> v1.10.0.0
[00011807][12 02][00] v1.10.0.0 -> v1.10.0.0
[00011909][12 03][00] v1.10.0.0 -> v1.10.0.0
[00016455][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016566][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016704][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016768][19 00][00] v255.255.255.254 -> v1.0.8.96
[00016813][01 00][00] v1.23.4920 -> v1.23.4920
[00016861][01 01][00] v1.23.4920 -> v1.23.4920
[00016920][09 00][00] v3.0.0.10 -> v3.0.0.10
[00017078]Packet upgrade cancelled at version checking.
i don't know what's the problem......
pic 1
pic 2
pic 3
pic 4
2016-10-16
Kalvis Posted at 2016-10-16 14:59
Just as roldanmoya said. Your RC firmware is up to date.
2016-10-16
zhaf91 Posted at 2016-10-17 09:27
i got p ...
I'd suggest you to fly in a different area to see if it's the same or not.
It's recommended to adjust antenna to the optimal range during flight, and fly it farther firstly then raise the altitude.
This video tutorial may help.
2016-10-16
zhaf91
Malaysia
DJI Mindy Posted at 2016-10-17 14:48
It's recommended to adj ...
already did that... the far thet i can go 400m only.. how about DJI GO cant recognized my A/C and R/C?
2016-10-17
zhaf91 Posted at 2016-10-18 12:49
already did that... the far thet i can go 400m only.. how about DJI GO cant recognized my A/C and  ...
Could you please clarify what mobile device you are using?
2016-10-18
pboilard
Just did the upgrade and it crashed. Got a "Propulsion Output Limited, Overcurrent during Discharge (Battery) and Motor obstructed message." It completely lost control and fell out of the sky. What now?? Phantom 3 Pro. Camera snapped off the gimbal with major damage to the Drone.
2016-10-18
pboilard Posted at 2016-10-19 03:56
Just did the upgrade and it crashed. Got a "Propulsion Output Limited, Overcurrent during Discharge  ...
Sorry for your crash,pboilard.
Please get in touch with our tech support via support.us@dji.com and send it in evaluation.
Our engineers can analyze the data and let you know what could have caused the issue.
2016-10-18
dbostock
Just want to add. In most instances anyone having range issues is not because of firmware. Its because DJI have decreased the amount of available channels to fly on from 32 to 8. This was done through DJI GO app update. That means ur drone has less chance of finding a stable non busy channel which is why u get short flight range. This happened since DJI Go app v1.0.2 for Appke and DJI Go app v1.0.7 for Android
2016-10-20
FlyingCircles
Flight distance : 76309 ft
dbostock Posted at 2016-10-21 06:49
Just want to add. In most instances anyone having range issues is not because of firmware. Its becau ...
Is this just a theory or factual knowledge that fewer channels causes reduced range?
2016-10-21
Redbeard_Drone
Hi all,
I have only flown my new P3A once - and it seemed to go well. Was able to get some decent range, even with interference around from apartment buildings.
On the tablet I'm using I have WiFi turned off as to not get interference - but just now while at home and connected to WiFi, the DJI GO app said 'updates available'.
It says:
App: 3.0.0
Version: 1.5.30+
Remote Controller: 1.6.0
1.6.0 seems ok for the RC - but 1.5.30+ seems pretty old for the aircraft?
My question is - should I update? Is there any gains to be had? Or is it pointless if the aircraft appears to be flying normally?
It seems 1.8.80 is a good version to have - but if I do an auto update it will update the aircraft to the latest 1.9.6 which from what I've read has various issues?
Can anyone confirm if doing the steps below will work? Allowing the RC to update to the latest, and the aircraft to be on 1.8.80:
With the aircraft off, plug in controller to phone/tablet and power it on.
Open DJI GO app
Touch the 'Firmware upgrade required' at the top in the aircraft status bar at the top and click 'Updates required at the top'.
Follow instructions to upgrade the RC firmware.
Once completed, format the SD card using the DJI GO app.
Plug SD card into computer and copy 1.8.80 .bin file to the root directory.
Plug SD card into aircraft, and without the RC on, turn aircraft on and let it update itself off the SD card.
Will that work? Is it advisable?
Cheers
Hunt
2016-10-21
dbostock
FlyingCircles have a Google on it plenty of stuff out there re this. And the reason it was done etc
2016-10-22
MC13579
Flight distance : 203107 ft
I am having horrible screen updates with my phone. Supper glitchy and  Cant even see what I am shooting after the update. Please help
2016-10-22
gatekeeper
When i was running FW 1.8.8 on my Nvidia i had no issues with the lightbridge video quality. I had issues upgrading to FW 1.9.6 and had to send the drone back to the shop i brought it from for them to do the upgrade. I also upgraded my Nvidia K1 and my Samsung S5 to 3.0.0
Now i am getting bad interference when i fly and lose connection to the drone. I was talking to DJI and they sent me a link to downgrade the app to 2.9.1 which i did on both Android devices but still have the issue of bad interference, losing connection and poor range
Drone is a P3P
Link to video of issue - HELP!!
2016-10-22
rwin05
I have a question, I bought, about a year ago to batteries that must have been made by someone other than dji. They worked fine when I bought them but after a firm ware update and 200.00 bucks later they won't work. Is there a fix for this or am I screwed out of 200.00 bucks? Not happy!
2016-10-23
mstrand
Bad video stream after 1.8 RC upgrade.........everything worked fine with my AC 1.9 and my RC 1.6 and Go app 2.8..NOW AFTER RC UPGRADE 1.8 AND GO APP 3.0 IT DOESN'T  WORK VIDEO IS PIXELATING SHIFTING COLOR BARS ALL OVER .....HELP.HELP.....IF HAVING SAME PROBLEM THERE IS A TREAD IN TUTORIALS WITH HUNDREDS OF PEOPLE WITH SAME PROBLEM...PLEASE FIX DJI....I NEED TO FLY MY P3P....IT'S NEW AND I SPENT $1250.00 And only have 13 charges on battery.......
2016-10-23
gatekeeper
mstrand Posted at 2016-10-24 10:37
Bad video stream after 1.8 RC upgrade.........everything worked fine with my AC 1.9 and my RC 1.6 an ...
yes sounds just like my problem see video above. Is this what you are getting too?
2016-10-23
nabzo
Flight distance : 353310 ft
I have the Dji P3A .after updating my dji go app  when I go to About to see aircraft and remote FW it shows N/A .
can someone tell me why im getting this  ? it used to always display before I updated the app
2016-10-24
Drone Dude Alga
Flight distance : 14227470 ft
Portugal
Dji we need new update !! This last one completely screwedup the phantom 3 pro{:4_142:}
2016-10-28
Colorado68
Flight distance : 312858 ft
Drone Dude Alga Posted at 2016-10-28 17:58
I'm still on the 1.2.6 version for over a year. I don't fly much but maybe once a month.
Couldn't keep up with the updates.
Fly's great!
2016-10-29
