jalexartis
Yes, I am. My lever moves from the 6:00 [locked] position to the 9:00 [unlocked] position--or 6:00 to 3:00, with the same locking and unlocking. In the unlocked position, the complete shaft should rotate and can be lifted to vertical. With it unlocked, the outer ring can be used to tighten the rod to the Osmo Mobile.
Otherwise, either the rod or Osmo can be rotated to attach to each other. The inner ring turns independently [turns freely] of the lever position.
From your description, your lever moves a bit more horizontally than mine. That is okay. Your shaft should rotate [turn] when unlocked.
Best Mate!
