2.4G data link transmitter (LK24-BT) antenna
4397 9 2014-10-16
johannes
Flight distance : 771434 ft
Iceland
Hi there.
I hope someone can help me on this.
One of those two antennas on the 2.4G data link transmitter (LK24-BT) just got cut of, the one marked with EXP.
Is it possible to get a replacement antenna for this transmitter?
My best
  Johannes
2014-10-16
DJI-Cathy
China
please contact your dealer or contact the nearest support center, support center info. see below:
http://www.dji.com/support
2014-10-16
johannes
Iceland
Thank you Cathy
I will contact them.
My best
2014-10-17
Kevin Gould
johannes@digi-f Posted at 2014-10-17 19:30
Thank you Cathy
My best
Johannes - I just had the same thing happen.  Were you able to get a replacement antenna for EXP.?
Thanks,
Kevin
2015-5-10
nig_smith
If you have trouble obtaining an antenna from DJI or one of their dealers you can use the FrSky replacement antennas such as this one
http://www.t9hobbysport.com/frsky-xr-receiver-antenna
Most FrSky dealers supply these and they are a direct replacement for the DJI part. I know because I managed to shred mine also .
Regards
Nidge
2015-5-10
johannes
Iceland
Hi there and sorry for late response.
I did get a antenna: https://www.thecommerce.es/epage ... 40/Products/3300.11
and replaced it and it is working grate as before the old one got damaged. It took me about half an hour to replace the antenna.Just be really cerful taking the old one of. It is so easy to damage the board. A great need for patience. i do not regomend doing it exept you are experienced in such work!
Regards
  Johannes
2015-5-11
johannes
Iceland
Nidge
What is the length on this antenna and plug size?
It seams to be the right one.
Regards
  Johannes
2015-5-11
johannes
Iceland
nig_smith@o2.co Posted at 2015-5-11 10:11
If you have trouble obtaining an antenna from DJI or one of their dealers you can use the FrSky repl ...
Nidge
Regards
  Johannes
2015-5-11
nig_smith
johannes@digi-f Posted at 2015-5-11 22:43
Nidge
Hi Johannes
My apologies for the very late reply, I've been away from the forum and don't receive notifications of replies.
Anyways, the replacement antennas that FrSky supply are identical in every way to those that are fitted to the air component of the Datalink. As I mentioned earlier in the thread I managed to clip the ends of mine and used the FrSky replacements. They clip firmly to the surface mount coaxial connectors on the Datalink circuit board.
Regards
Nidge
2015-6-8
johannes
Iceland
Hi there Nidge.
No problem, no hurry, I do not get notifications ether.
I did fix mine with one from  thecommerce.es that is also identical to the original and works.
But it is good to know about the Frsky  antenna for there they are easy to find on so many web stores.
Regards
  Johannes
2015-6-9
