measuring distances in video
1087 5 2016-10-25
ghheath
Is there a way to measure distances between points on video shot with inspire pro? I'm doing powerline survey and need to be able to see distances from trees to powerlines.
2016-10-25
DJI-Jamie
Flight distance : 112405 ft
The unit is not able to measure distance between the aircraft and its subject. The only data you will see is the current height, latitude and longitude information.
2016-10-25
Farnk666
Flight distance : 1711394 ft
Nothing on the aircraft itself, you will need to take a known measurement of an object in frame and use that to measure the gaps manually.
2016-10-25
ghheath
Farnk666 Posted at 2016-10-25 19:17
Nothing on the aircraft itself, you will need to take a known measurement of an object in frame and  ...
Thanks. Is there any way to access the geo information on the video to determine distance flown?
2016-10-26
pinpointmapping
Flight distance : 5345105 ft
ghheath Posted at 2016-10-26 08:32
You may be able to use the Video stream with some software from ESRI called FMV (Full Motion Video)
http://www.esri.com/products/arc ... y/full-motion-video
Or you could take multiple still images (you could do frame grabs from the Video, but even 4k video isn't as good as a 12mp still) and use either Drone2Map (another ESRI product) or just use Pix4D to process the images (the concept is called Structure from Motion) and create a high resolution 3d model that would allow for accurate measurements....  Let me know if you need more info to get started.  It helps if you have an understanding of GIS....
2016-10-26
Farnk666
ghheath Posted at 2016-10-27 02:32
You can set the app settings to enable a SRT file to be created that will give you a GPS let/long every second for the flight. That's about it.
2016-10-26
