D-Log Flickering Problem
2195 16 2016-10-29
No Man's Drone
Flight distance : 301545 ft
I'm not sure if this is an issue with the camera or just the D-Log color profile but all of my footage using D-Log has this flickering problem:
Settings:
ISO: 100
Shutter: 1/60
White Balance: 5000k
Style: 0, 0, +1
Some color correcton and grading applied
This one is taken with auto settings, non D-Log:
Is anyone having this issue so far? Or is D-Log is just weak?
2016-10-29
Nees
Flight distance : 80991 ft
It is not flickering. Its the height of the sun and the props that cause the "flicker" (shadow) it looks like.
In your 2nd video, the sun is lower, not casting a shadown over the camera.
2016-10-29
No Man's Drone
Nees Posted at 2016-10-29 22:46
It is not flickering. Its the height of the sun and the props that cause the "flicker" (shadow) it l ...
Actually I'm about to upload my footages taken during several time of the day, even if the sun is behind the clouds. Flicker only happens in D-Log.
2016-10-29
Nees
No Man's Drone Posted at 2016-10-29 16:58
Actually I'm about to upload my footages taken during several time of the day, even if the sun is  ...
Ok, show us Interested
2016-10-29
sploodge
Flight distance : 809350 ft
What about auto settings with D-Log? Could it be the shutter speed/ other manual settings causing the flickr?
2016-10-29
No Man's Drone
sploodge Posted at 2016-10-30 06:06
What about auto settings with D-Log? Could it be the shutter speed/ other manual settings causing th ...
I think I know what the issue is now. Whenever I use 1/60 shutter speed (because shutter speed = FPS ×2) the camera is letting in more light and it also overexposed all my footage. This is the reason why my footages have the flickering/pulsating effect that looks like propeller shadows. We badly need ND filters.
2016-10-30
Watty2000
Flight distance : 1074301 ft
It's a well known problem shooting greenery. My 4k Phantom 3 Pro footage is unusabe thanks to this.
http://forum.dji.com/thread-19810-1-1.html
2016-10-30
No Man's Drone
Watty2000 Posted at 2016-10-30 20:37
I did see your post prior to posting mine. I guess DJI has not resolved this issue. Too bad I can't even use manual mode because of this.
I'm going to try to shoot with NONE and 0,-1,-1 this time and see what happens. If it's the same, I'm going back to full auto unfortunately.
2016-10-30
No Man's Drone
Watty2000 Posted at 2016-10-30 05:37
Oh man I missed what you said. So it is a problem with greenery? That really sucks. I've seen several P3 and P4 videos that involved a lot of greenery and they don't have this issue. Where you shooting in D-Log as well when you experienced this issue?
2016-10-30
No Man's Drone
Welp, never gonna use D-Log until DJI fixes it. I think I hit the settings I am very happy with:
ISO: 100
Shutter: Depends on the scene
Color: None
Style: 0,-1,-1
White Balance: Depends on the scene
2016-10-31
Watty2000
No Man's Drone Posted at 2016-10-31 01:16
Oh man I missed what you said. So it is a problem with greenery? That really sucks. I've seen seve ...
It didn't seem to make a difference what profile I tried, sometimes the problem is there, sometimes it's not, or not quite as bad. It does seem to be mainly with heavy amounts of foliage and no amount of tweaking shutter speed, with or without manual white balance or ND filters makes any difference. I've heard people say it's a compression problem and also a limitation with the sensor when shooting 4K. When the leaves come out again here, I'm going to try 2.7K and see if that helps.
2016-10-31
No Man's Drone
Watty2000 Posted at 2016-10-31 23:39
It didn't seem to make a difference what profile I tried, sometimes the problem is there, sometime ...
If you watch the video I posted above, it is a footage I did with my Mavic this morning. I am surrounded with lots of green here, and with the new settings, I'm good. No more flicker and pulsating issues for me.
2016-10-31
Watty2000
No Man's Drone Posted at 2016-10-31 16:18
If you watch the video I posted above, it is a footage I did with my Mavic this morning. I am surr ...
Looks good although there isn't really that much green in the picture; the clouds obscure a great deal of it. It'd be interesting to see how your footage looked if the vast majority of the content was green leaves. That's one tall mast btw
2016-10-31
fans0ce85744
Flight distance : 50466 ft
Looks like framedrops to me... Did you format your memory card directly using dji go app and with the card inserted in the drone ? If not, do so. Maybe your sdcard has been formatted with a really small block size.
2016-10-31
No Man's Drone
fans0ce85744 Posted at 2016-11-1 00:42
Looks like framedrops to me... Did you format your memory card directly using dji go app and with th ...
Which footage are you referring to?
2016-10-31
fans0ce85744
The first one, actually I did not notice the flickering right away... First thing I noticed was the cloud reflections in the water seemed not to move continuously... Hence framedrops
2016-10-31
No Man's Drone
fans0ce85744 Posted at 2016-11-1 03:26
The first one, actually I did not notice the flickering right away... First thing I noticed was the  ...
Gotcha. Yeah that only happens in D-Log for me -- probably in conjunction with the greenery in the scene and the codec cannot process everything properly.
I posted another vimeo vid above with a different setting. I think I am satisfied for now.
2016-10-31
