dabassham
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 176936 ft
Actually you can do head tracking with Litchi in "rotate aircraft mode". Not only can you tilt up and down, but you can also head track rotate the bird. It's an advanced VR feature. You must be in F mode on the P3, or P mode on the P4.
Below is a snippet from the Litchi website and the URL: (bottom of the page)
Aircraft head tracking https://flylitchi.com/help#vr-p3
Aircraft Head Tracking
This advanced VR feature requires the RC's flight mode switch to be in F mode (or P for the Phantom 4) and the aircraft to be in the air.
In Immersive mode, rotating your head left/right causes the aircraft to rotate left/right mirroring the angle you are looking at relative to the reference which is established when VR mode is started.
In Joystick mode, rotating your head left/right is similar to using the left joystick's left/right axis (mode 2). As an example, the more you rotate your head to the left, the faster the aircraft will rotate to the left. The zero point, at which the aircraft will not rotate, is set when VR mode starts using the current mobile device orientation at that time.
