DJI Mavic Pro washed out/blurry right side?
38364 212 2016-10-30
spongedid
Flight distance : 638911 ft
A video is not the good way to check the lens alignment. The compression degrades the image. It shall be tested with the DNG images
2016-11-9
Stokke
Flight distance : 207339 ft
I would suggest that everyone who has issues with the camera do a top/down photo so you get almost the same distance to everything in the frame. Should be of much more analytic value. Will do this test in about 30 minutes myself and post the photos here. I have not suspected any camera misbehavior, but I have not specifically looked for it either.
Well I sort of failed.. My exposure was too bright to give a good view of the sharpness, and what there is of detail is tall trees wich makes it even harder to get something valuable from them. Added another "low contrast on the edges" image wich does seem reasonably sharp. But there is definately some softness towards the edges all around the frame compared to a pretty large sharp center.
https://dl.dropboxusercontent.com/u/6389451/image1.JPG
https://dl.dropboxusercontent.com/u/6389451/image2.JPG
https://dl.dropboxusercontent.com/u/6389451/image3.JPG
2016-11-10
ZyD
Just an update, got an email reply from RMA today.
I'm waiting for a courier service tomorrow and by Monday afternoon they should have my mavic for a repair or an exchange. Camera/gimbal is under 6 months warranty so we'll see how it turns out.
2016-11-10
henk0
As i told you. You have to take a photo of a brick wall and then its easy to compare the sharpness. Otherwise its hard to tell and you will only big errors with the lens.
2016-11-10
spongedid
You can refer to this test. The images were taken with a preserial unit.
Look at the DNG files, they show what a Mavic is supposed to do
https://www.helicomicro.com/dji-mavic-pro-la-preview/4/
for instance this one (big DNG file):
https://mega.nz/#!S0YhQCrb!biNUQ ... w1ZwbmqlUBJQQPaSwQ4
(converted in Ligthroom, slightly reduced) Click 3 times to see the big one
That is a "normal" image from a camera properly aligned.
I suggest to use one of these DNG's for any discussion with DJI support as a reference, in case you get a bad copy.
2016-11-10
fredt59
Flight distance : 164498 ft
I'm a french user of the DJI Mavic so please be kind with my poor english. I pre-ordered it on 09/27/16 and received it on 10/26/16. I didn't get much time to fly it since I received it more over I was expecting the firmware upgrade to be sure I would fly safe with the Mavic so I only gave it a try yesterday. I'm an amateur photographer and my main purpose with the Mavic is to do some aerial photography. I was very pleased with the flight capabilities of the Mavic and had encountered no problem during the flight session. Once back home I check the different shots I made and was surprised by their poor quality. Of course I was not expecting the same quality that my DSLR could offer but the shots were clearly not sharp on the borders especially the right one. Of course the gimbal cover was off as the clamp too and I center focused the shot thanks to the C1 button. So I decided this morning to put the Mavic on my sturdy tripod to be sure nothing could interfer with the quality of the shots and did some bricks wall shot. Unfortunately the shots I made just confirmed my first impression. Do you think I should send back the Mavic to DJI hoping to get a better copy? Here is some sample shots:
2016-11-12
spongedid
Retour a l'envoyeur direct (ou alors c'est un pb d'autofocus) !!!!
I guess, if everybody receiving a such crappy thing resend it, DJI will be convinced to improve (or implement...) an Image Quality control in production.
2016-11-12
ZyD
Please check upper left corner i.e the roof and windows
2016-11-12
spongedid
Omg...Visible even in small size. Not usable (for me). Rejected as well.
2016-11-12
fredt59
Hi everyone,
After contacting the support service and giving them the pictures from above, they tell me the camera might have a problem. I'm waiting to get the formular to get it back, I just hope I'll get a fine copy soon.
2016-11-14
fans730ba634
After having my Mavic for two weeks I finally got to fly it (waiting on decent weather) and I'm disappointed to have also found out I have this issue on the right-hand side, gutted. I've sent an email to DJI and I suspect I'll get asked to return it for repair/replacement.
2016-11-26
fansd1794bdf
Flight distance : 223921 ft
ZyD Posted at 2016-11-12 20:02
Did u got your unit repaired/exchanged yet?
2016-11-29
dlinnell
I have the same problem in my still images but on the left side. Yes - the plastic bubble is removed and yes, it's been focused to infinity before shooting. This sucks.
2016-11-29
ZyD
fans730ba634 Posted at 2016-11-26 14:25
Hi
You'll be fine once you get yours repaired/exchanged.
2016-12-11
ZyD
fansd1794bdf Posted at 2016-11-29 22:42
Hi
Just saw your message today, yes I got my camera+/-gimbal exchanged for free(under 6 months warranty) and tested few times already.
I must say the pics+videos are way better than before.The only problem now is aliasing/moire effect and very slight jello  so I'm awaiting for my filters to be sent out.
2016-12-11
Archon810
Flight distance : 67664 ft
Hi everyone,
I am the OP and have just gotten my replacement Mavic from DJI. They sent a brand new one (I was afraid they wouldn't do anything or they'd just mess with the camera, but no - best possible case happened).
The new camera is GOOD! No more blurriness, so I'm very glad I went through with the exchange and didn't settle for a defect. Here are some samples, which if you compare to the ones in the first post are blur-free (the first one is a DJI-taken photo, the rest are stills from a video).
I'm finally happy and this is definitive proof that Mavic's picture can be clear on all sides, not just in the center. If you have a problem with uneven blurriness in your camera, don't settle and demand an exchange.
2016-12-14
Double_T
Hey all,
Received my unit yesterday and I was quite confused at the overall quality... This was taken in london and as you might guess, even though it was 1pm when I shot this, the light wasnt great and it probably induced a lot of grain. The internal degrainer that DJI embeded looks like the one you can find on phones, that's why it looks a little bit painterly (like a median effect for those who do image processing).
Anyway, point is, although the conditions were not optimal, my Mavic has the same problem. Look here on the right bottom hand corner, it's veeeeeery blurry :
I'll do another test picture with a printed checker I have laying around (I work in a digital effects company)
2016-12-15
Stewie Griffin
Double_T Posted at 2016-12-15 10:08
Hey all,
Although I do agree that it looks like there is some softness, its not as conclusive as in the other samples in the forums.  You're right, the heavy processing by DJI is quite ugly.  None of the trees have any detail, no matter if on the right, or even on the left, which is why I say its hard to figure out how much softness there is.  What ISO was this shot at?  Your best bet is to reshoot, trying to shoot at ISO 100, and for sure shoot in DNG and just make your own JPEG with photoshop.  The results will be 100 times better.
2016-12-15
Double_T
Stewie Griffin Posted at 2016-12-16 07:00
Great suggestions, thank you Stewie.
This was actually a grab from an video. If it matters, presets are as follow:
Custom : -1 0 0
Grade : Art
2.7k 25fps
2016-12-16
josh5
I am experiencing the same problem, its blurred on both edges, much worse than the images/footage you have provided.
2016-12-19
dotfiles
I've got exactly the same problem as you OP. Looks like I'll be applying for an RMA as well
2016-12-19
dCUfOcwi4nnk
Flight distance : 73238 ft
It looks from an initial test that I've also got some major OOF issues with my Mavic Camera.
What do you guys think, is this a defective camera lens issue?
I had noticed it in general scenery/landscape images but figured the best test would be some 'brick wall' test shots.  These were taken parallel to the brick wall and I think there is some very clear softness/out of focus anywhere outside of the very centre of the image and in particular in the right hand side of the images.
All images have used centre focus prior to taking the images.
I'd really appreciate some feedback as to whether to take this officially to DJI for a warranty claim.
I am also going to print out some ISO 12233 test images at work tomorrow at A0 or A1 and pin to the wall to do a static tripod tests of the camera just be 100%.
2017-1-1
mavicme
Flight distance : 35738 ft
Well gosh darnit.. i  have it too.  Purchased this from Best Buy.. I guess I can just return it and wait for a new one to come in or do an RMA w/ DJI.  Hmm, which route should I take?
2017-1-1
SBT1979
i just same problem the image not good in right area video...its incredible dji no response...if the firmware is no suficient? dji replace camera??? i have phantom 3 and i very happy...but mavic...seems a perfect dji horror...please, repair all issues with firmware and replace bad pieces. thanks.
2017-1-2
fans2a5b3e69
Flight distance : 156509 ft
Think my camera is having the samething. I have center focus bound to C2.
The left side is soft/blurred. If I tap to focus on the left side then the right side goes soft/blurred
2017-1-7
fansc0efe0a6
Flight distance : 41424 ft
Archon810 Posted at 2016-12-14 11:40
Hi everyone,
Hi @Archon, how long did it take for DJI to issue the replacement? I've got the same problem, and a trip coming up in three days. I guess I'm taking the blurry camera for now
2017-1-8
Elly
Flight distance : 119446 ft
South Korea
I have same issue.
Right side is blurry.
Please, Check my video.
This is C4K 24frame
2017-1-16
mcd0nald
Flight distance : 3717 ft
Exactly the same issue I've got. I am now just waiting for a reply from support@dji.com
2017-1-17
lachyb
mcd0nald Posted at 2017-1-17 04:51
Let me know what you hear back from them as I've just got my mavic and notice that the right hand side is very soft.
2017-2-4
eagle_one
Flight distance : 129442 ft
Just flew my Mavic for the first time today and encounter the same problem with the bottom right corner of the photo/image
Will email to get a RMA.
2017-2-4
mcd0nald
lachyb Posted at 2017-2-4 09:25
mine has been collected and returned last week
they will confirm if everything is correct, like never crash...such and such,... they'll replace with new one
2017-2-13
TylarO
Flight distance : 8593 ft
Just received mine today and mine seems to have this issue as seen in this image. Bottom right is blurry. Guess i'll be emailing support.
2017-2-13
lachyb
mcd0nald Posted at 2017-2-13 18:38
I ended up applying for a refund and will order a new drone (going overseas and want it delivered there). Hopefully this isn't a problem with my next one!
2017-2-14
gnom
Flight distance : 716572 ft
If anyone have this issue, dont fly around any more with your mavic and sent it back. Otherwiese DJI will say its your fault because of dust as in my case.
2017-2-14
evaldomain
Lithuania
Same problem. Received my mavic tested and got this blurry right side of image. contacted support got ups ticket. send mavic to dji and after 3 weeks waiting got replaced drone with diferent serial number. Tested it and now blurry image apears in other side not sure what i should do contact support again and wait or fly it with a defect and ignore it. Even if i contatc support again i am not sure i get quality item.
2017-2-14
Rafaocon
I am facing the blur problem too, but as you can see in my photos it is extrem when the problem happens. I am facing the same problem on the videos. Any soluton or must be sent to warranty service?
2017-2-14
Rafaocon
2017-2-14
alirz5
Flight distance : 609833 ft
I've had the same issue. I opened a case with Dji. I'm pretty sick of the quality issues and decided to open a case with PayPal for a refund.im not willing to spend $1300 on an experimental product.while it's a great flying drone, it comes no way near the quality of the previous Dji drones. Video is the main reason I got this. If that is not going To work fine then no point in banging my head around with support folks who can't really fix this problem
2017-2-14
adx
Flight distance : 208606 ft
And AF doesn't work, right? You can fix it through re calibrate IMU and reset camera settings. Yep, that sounds crazy but it works. IMU calibration is necessary, i got exactly same issue and IMU calibration helps me, but it's not a permanent fix, problem goes  back sometimes.
2017-2-14
alirz5
Yikes..that's one of the worst picture taken by the mavic I have seen so far. Please open a case with Dji. The more people report this, the better luck we will have of getting some solution.
2017-2-14
