My first crash at night : DJI could you look into this
2054 14 2016-11-19
LaCcTv_com
Flight distance : 54885 ft
So just got in after climbing the roof of a commercial building next to me after the mavic crashed.
Please have a look at the video it happens at the end of video.
you can see it veer off onto the building
so while cruising at 200 feet for a while i used the return home fuction it came back just fine then hoverd for 48 sec then I pulled the stick down, it came down then when it got close to the building i moved the stick to the left then the mavic forced its way towards the building and crashed on the roof.
DJI could you look into this???
and if someone could tell me how to get the flight logs I would appreciate it.
<iframe width="560" height="315" src="https://www.youtube.com/embed/wWShneuUOFo" frameborder="0" allowfullscreen></iframe>
2016-11-19
AusAir
Flight distance : 425049 ft
Out of VLOS and flying at night.
I'm going with pilot error.
2016-11-19
LaCcTv_com
AusAir Posted at 2016-11-19 21:52
why would it just vear like that?
2016-11-19
AusAir
Replay the flight from the Go App and check your stick inputs. Looks like you panicked and went the wrong way.
2016-11-19
LaCcTv_com
AusAir Posted at 2016-11-19 22:05
Replay the flight from the Go App and check your stick inputs. Looks like you panicked and went the  ...
i assure you i didn't.
2016-11-19
fullswing
"Crashed" on the roof? At what point in the video?
Looks like you landed it on the roof.
2016-11-19
dotfiles
AusAir Posted at 2016-11-20 14:05
Honestly seems like you moved the stick in the wrong direction, maybe as a result of not being sure of the orientation of the quad. But as was mentioned, review the stick inputs in the Go App. You can record them and post the video of that here to help rule that out as a factor in the crash.
2016-11-19
LaCcTv_com
dotfiles Posted at 2016-11-19 22:15
Honestly seems like you moved the stick in the wrong direction, maybe as a result of not being sur ...
whats strange is why did it hang in the air for long time and why head for the roof like it did?
2016-11-19
Sgt_Throatpunch
Seems like pilot error. Night flying over traffic on your 2nd day with new hardware probably wasn't a good call.
2016-11-19
fansbb5b373a
out of VLOS for me is bettere no use the drone..
so in case you were able to reture the drone manually and not using the RTH,
rth is good  but if the sensor find a obastacle , if you don't calibrate the FAILSAFE RTH , the drone is not able to avoid them
2016-11-20
fans628b7609
Flight distance : 234948 ft
So did you use RTH on the drone, remember the drone uses the camera to find the right spot if its dark well.............
2016-11-20
fansce3b84f6
Yeah, it would be good to know if RTH was still active.
Also OP, is there any chance course lock could have gotten enabled? I believe that could cause opposite movements than expected.
2016-11-20
https://healthydrones.com/?cm=3& ... vQ_qfbWcxoCl1Pw_wcB
Hi LaCeTv_com
Sorry to hear about your crash, you can upload you logs to above link, you really can't tell much from the video, but as Aus air said you can replay your flight in the app at the bottom of the screen you will be able to see stick movements.
Flying at night around a lot of buildings and other stuff that can cause interference it's a risky business,
You may need to speak to a dji mod here and he will be able to tell you where to load your logs for dji to look at, to see if it was a malfunction or not.
But make sure you sync your flight , you can also do this on your flight page sync flight in upper right hand corner.
Good luck..
2016-11-20
Could you please sync your flight records from DJI GO app and provide me with your DJI account email?
I'll help to check it.
2016-11-21
ENG101
Flight distance : 19642 ft
p.51 of the manual "If Landing Protection determines that the ground is not suitable for landing, the Mavic Pro will hover and wait for pilot confirmation".
Looks like RTH didn't like landing in the dark so was hovering. Did you see any prompts on the screen?
2016-11-21
