DJI Assistant2 software now available for Apple
1234Next >
300084 136 2016-3-18
DJI-Ken
Flight distance : 1515312 ft
Eye Spy Posted at 2016-10-21 07:23
DJI - Ken
Flight Record on the DJI Assistant 2 just spins the wheel. (15 minutes and waiting)... I h ...
You may have to wait a while if you have lots of flights on your aircraft as it's a lot of information to download from the aircraft. If you've already waited a while and it's not downloading, then you may want to redo the process or you can try to restart  your computer to see if that works. I will try on mine later on to see if I get the same results.
2016-10-20
Eye Spy
Flight distance : 531467 ft
"You may have to wait a while if you have lots of flights on your aircraft as it's a lot of information to download from the aircraft. If you've already waited a while and it's not downloading, then you may want to redo the process or you can try to restart  your computer to see if that works. I will try on mine later on to see if I get the same results."
Thanks, will do. I have about 50 minutes of flight time. I'll report the results...
2016-10-20
DJI-Ken
Eye Spy Posted at 2016-10-21 07:56
"You may have to wait a while if you have lots of flights on your aircraft as it's a lot of informat ...
Sounds good, thanks.
2016-10-20
Eye Spy
2 hours and counting... doesn't look good
2016-10-20
DJI-Ken
Eye Spy Posted at 2016-10-21 09:21
I got the Assistant2 installed, I will try in a few.
2016-10-20
Eye Spy
Nope. not happinging
2016-10-20
DJI-Ken
cecil.lee Posted at 2016-10-20 23:17
Hi Ken, My Mac OS is Sierra ver 10.12 and block the assistant2. Under Security and Privacy in the sy ...
Trash the Assistant2 from your Mac and download it again.
After downloading, go into the downloads page and click on the DMG file. Then click once the right Applications tab, then right click on the left tab (DJI) and click open.
It will give a "are you sure you want to open" message and click open.
If you double click the Assistant2 tab then it's goes into the security thing and even if you allow it it still won't let you open it.
So follow those instructions and it will work.
2016-10-20
DJI-Ken
I was able to download my P4 flight records to my Mac and it was no problem.It took about 20 minutes then I though it was going to get stuck then it said compressing and that took about 10 minutes and then it completed just fine.
You are on the latest Assistant2 version correct. I have 1.06
2016-10-20
Eye Spy
DJI-Ken Posted at 2016-10-21 11:23
I was able to download my P4 flight records to my Mac and it was no problem.It took about 20 minute ...
yes, 1.06.
it's interesting, when I have the Assistant 2 running and then I plug in the P4, the Assistant nor the Mac Finder recognize the P4. When I close Assistant 2 app and restart the P4, both the Mac Finder both the Mac finder and the Assistant 2 see the P4. However the DJI Flight Assistant 2 still does not respond to the Flight Record.
NOTE:
When I press the flight Record button, I first receive a message: "Entering flight Data may change the device..."
2016-10-20
Eye Spy
(tried to upload a pic)
2016-10-20
DJI-Ken
Eye Spy Posted at 2016-10-21 12:28
yes, 1.06.
it's interesting, when I have the Assistant 2 running and then I plug in the P4, the A ...
I'm sorry, have you deleted the Assistant2 and reinstalled to see if that does anything?
And you haven't crashed the P4 have you ?
2016-10-20
Eye Spy
DJI-Ken Posted at 2016-10-21 12:31
And you ha ...
No, I definitely have not crashed the P4. Only the softest of landings and it still looks new...
Yes, I have deleted and re-installed Assistant 2 ( had to use the Terminal back-door fix this time) but the same result...
This is not a huge "Flight Data" issue as the P4 flies and acts as advertised. I couldn't be more happier with it (unless it flew with my Canon D5 Mk 3) and my 7-day warranty is up now...
2016-10-20
Eye Spy
Eye Spy Posted at 2016-10-21 12:43
https://www.dropbox.com/s/alhd3u ... 27.19%20PM.png?dl=0
2016-10-20
DJI-Ken
Your totally fine with this message, I get the same.
Just hit confirm.Are you saying that after you hit confirm nothing happens?
After you hit that, you should see all your flight records then you click the boxes of the records you want to download.
2016-10-20
Drones22
Baldo81 Posted at 2016-10-19 06:25
Open Terminal and write:        sudo spctl --master-disable
press enter and write you OSx Password ...
Thank you, that did the trick!
2016-10-21
Eye Spy
DJI-Ken Posted at 2016-10-21 12:51
Just hit confirm.Are you saying that after you ...
Yes, I hit "confirm", then i get the spinning wheel...
Here's thought... On my DJI Go App, when I press the top left corner icon (airplane-like icon), I see two identical accounts. One labeled "Phantom 4" and one labeled with "my email address". Perhaps it created two profiles in the P4 and gets locked up??
How would I delete one of those profiles in the DJI Go app??
Thanks,
Doug
2016-10-21
DJI-Ken
Eye Spy Posted at 2016-10-21 21:38
Here's thought... On my DJI Go App, when I ...
I don't think that's the problem, you can sync your flight records (the cloud icon) to the DJI server then delete and reinstall the app.
The full flight records are on the flight data recorder in the aircraft and the app should have nothing to do with that.
2016-10-21
Eye Spy
DJI-Ken Posted at 2016-10-21 21:54
I don't think that's the problem, you can sync your flight records (the cloud icon) to the DJI ser ...
...deleted and re-installed the DJI GO app. Synchronized all data, and I still see two profiles...
Not to worry though, everything works and I'm happy with the product. (although the Assistant 2 issue is worrisome)
2016-10-21
DJI-Ken
Eye Spy Posted at 2016-10-21 22:12
...deleted and re-installed the DJI GO app. Synchronized all data, and I still see two profiles... ...
I'm sorry, it worked totally fine for me on my Mac last night.
When you get a chance, try a PC and if there's still an issue, it could be an aircraft thing.
2016-10-21
allanbranch
Anyone else with Sierra OS issues? I can't export flight records...fun stuff...day #1.
2016-11-28
allanbranch
DJI-Ken Posted at 2016-10-20 10:28
Yes, it does the same on mine as well.
I already reported it, sorry for the inconvenience.
Ken, I've had my DJI Mavic Pro for one day and I'm unable to get assistant 2 to function properly. It show no videos in my flight record even though the card is full.
2016-11-30
DJI-Ken
allanbranch Posted at 2016-11-30 06:24
Ken, I've had my DJI Mavic Pro for one day and I'm unable to get assistant 2 to function properly. ...
The Assistant2 is not for playing back your videos.
You remove the SD card from the Mavic and put it into your computer and then open the DCIM files and all your photos/videos will be there.
2016-11-30
fans9a1ac4d9
Can't sign into assistant 2. Trashed it and downloaded it 5 times and each time I am unable to put txt into the sign in box. So unable to sign in. Using MacBook Pro.
2016-12-3
DJI-Ken
fans9a1ac4d9 Posted at 2016-12-3 21:08
Can't sign into assistant 2. Trashed it and downloaded it 5 times and each time I am unable to put t ...
I too have a Macbook Pro and am not experiencing any login issues.
Can you make up another email and try.
2016-12-3
EyeSky
I'm using Sierra 10.12.2 on a 27" iMac and works fine.
2016-12-15
DJI-Ken
EyeSky Posted at 2016-12-15 06:47
Good to hear, thanks for posting.
2016-12-15
Titomix
Me too, i'm using a iMac 27" Late 2012 with the Inspire 2 and works great.
The latest version of the DJI Assistant is the 1.0.9?
2017-1-21
DJI-Ken
Titomix Posted at 2017-1-21 14:20
The latest version of the DJI Assistant is the 1.0.8?
Yes, 1.0.9 is the latest.
2017-1-21
Aardvark
Flight distance : 384432 ft
DJI-Ken Posted at 2017-1-21 17:24
Yes, 1.0.8 is the latest.
Hi Ken
Assistant 2 V1.0.9 was released 5th January.
2017-1-21
DJI-Ken
Aardvark Posted at 2017-1-21 17:34
Hi Ken
Sorry, about that.
2017-1-22
KensPhantom4
So DJI I,m not the only one having problems with their Firmware! I see now your solution is asking people to visit this forum so that your own users can fix your customers problems. I now have access to yet another PC as a guest user, but fear this is not going to help, because most people are instructed and I quote ' On a PC, make sure to run as administrator' is not helpful!!!!!!!!!!!!
These are my ticket numbers: 423305, 410620, 408953.
2017-2-9
DJI-Ken
KensPhantom4 Posted at 2017-2-9 00:15
I scanned through your tickets and you got everything resolved correct?
Your latest question was about the batteries updating, if a battery needs updating then the app will notify you. But since you have the latest firmware, if additional batteries needed updating it would be done automatically.
2017-2-9
ThorH
Baldo81 Posted at 2016-10-19 02:25
press enter and write you OSx Password and press enter.
This will enable in SIERRA the following menu
This disables a very important security feature on the Mac. This is how you get malware and crap installed.
Why are not DJI a registered developer?
2017-2-24
Lb650
Flight distance : 1217762 ft
Hello DJI Ken. I have a mac book air   When I installed the assistant the only driver that asked to be installed was the "horndis " driver to tether an android device. I tried to calibrate the sensors and the start button is greyed out, I was able to do a firmware refresh, are you able to recallabrate the sensors if  the app doesn't prompt you to?
2017-3-5
Lb650
cecil.lee Posted at 2016-10-20 07:17
Hi Ken, My Mac OS is Sierra ver 10.12 and block the assistant2. Under Security and Privacy in the system preference there is no longer any choice "anywhere" but instead a button open anyway which I click and a small window appears verifying the app, immediately thereafter the same window appears saying the software is block. I tried a few times and it keeps looping back to the initial screen saying the app is not from Apple.
Please advise a work around.
Thanks Cecil
Check out baldo81 post. Has a fix for sierra users
2017-3-5
DJI-Ken
Lb650 Posted at 2017-3-5 21:04
Yes, you can calibrate the sensors at any time.
Maybe try to delete and reinstall the Assistant2, I have a Macook Air and it works fine on mine.
2017-3-6
Lb650
DJI-Ken Posted at 2017-3-6 07:33
I have tried multiple times and get the same result every time    The video I wanted on the install says to drag the software file and driver file into the applications folder and I never see the driver folder. It only asks to install the "horNDIS" driver   I'm using el capitain
2017-3-6
DJI-Ken
Lb650 Posted at 2017-3-6 09:01
I'm on Sierra 10.12.3, can you update?
2017-3-6
Lb650
DJI-Ken Posted at 2017-3-6 09:43
From what' I read there is a problem wiith sierra and or the app.  I think I will wait till your team gets it fixed
2017-3-6
DJI-Ken
Lb650 Posted at 2017-3-6 12:54
The app has nothing to do with the Assistant2, calibrating the sensors works just fine for me on my Macbook Pro or my PC.
2017-3-6
1234Next >
