Flying 'into' the sun results in proximity warning?
1840 6 2016-12-1
ton848
Flight distance : 120492 ft
Hi guys/ DJI
While getting myself acquainted with the Mavic I've noticed the the forward vision sensors 'detect' an obstacle when flying 'into the sun' ....
Is that expect behavior?
It doesn't really seem to affect things for now... but I'm curious to hear if it's normal.
Thanks.
2016-12-1
Chaser720
Flight distance : 400190 ft
I've seen this error from several people. You may also get a similar error in complete darkness.
2016-12-1
Frank I.
I wouldn't call it an "error" - the manual clearly states that the small front cameras will only work between 300 and 10000 lux.
When pointed directly towards the sun they'll simply be "blinded by the light"...
2016-12-1
Flight distance : 11959747 ft
Hungary
It is quite normal on all aircraft with OA .
2016-12-1
ton848
Frank I. Posted at 2016-12-1 18:45
I wouldn't call it an "error" - the manual clearly states that the small front cameras will only wor ...
Ah.. of course.. must have missed that part.. thanks... :-)
2016-12-1
RichJ53
Flight distance : 1837356 ft
The bright sun sets off the Mavic's object avoidance system.
DJI Ken has told me this is normal in another post. He said if you are clear of any structures that could effect your flight and don't require the system,  then turn the OA off.
Rich
2016-12-1
Nees
Flight distance : 80991 ft
It is in the manual, yes, it has been posted several times... yes...
2016-12-1
