Extend range in Europe
6518 7 2016-12-4
ueuezaza
Flight distance : 457976 ft
In the US (FCC) the maximum range should be 7 km whereas in Europe we "only" have 4 km. I know it's because of the different regulations and I also know that 4 km are probabily more than enough, but anyway...it kind of sucks to know that your friends on the other side of the ocean pay the same product 25% less and that it even has better performance.
I tried to read myself into it, but from th P3 on it seems to be impossibile to switch to FCC. If I am right, the hardware changes between EU and US controller.
Is there any other solution exept buying it directly from the US?
2016-12-4
Harbourside
Flight distance : 6467 ft
FCC / CE mode is software controlled from the GPS reading on the craft.
Most countries UAV regulations limit you to visual range, so anything over 500m is purely academic anyway.
So no point trying to buy a USA Mavic as it will still set itself to CE when you turn it on...
2016-12-4
ueuezaza
Harbourside Posted at 2016-12-4 23:23
Most countries UAV regulatio ...
So it sets itself whether to FCC or CE depending on where I am?
If so, than if I go tho the US with my European drone than the controller switches to FCC and I can fly 7 km away and viceversa? Sounds a bit strange to me
2016-12-4
ueuezaza
2016-12-4
Harbourside
Yes that's how it works.
You don't have to believe me if you don't want to
2016-12-4
Danny-B-
Flight distance : 306640 ft
ueuezaza Posted at 2016-12-4 22:44
If so, than if I go tho the US wi ...
Yes this exactly. FCC or CE transmission is set by GPS location.
it's all due to radio frequency/power regulations, the US allows higher output (26db for US and 20db for EU and rest of the world)
2016-12-4
ueuezaza
Ok ok ok I believe you
Thanks for the help!
So there is nothing I can do to extend the range? I would have used it to fly around the summit of a mountain next to my house. The problem is not the maximum distance, but the height (400 m)
2016-12-4
Watty2000
Flight distance : 1074301 ft
ueuezaza Posted at 2016-12-4 23:07
You can set the maximum height at up to 500m I believe.
2016-12-4
