Phantom 4 pro always showing wind warning and flying poorly
123Next >
13324 114 2016-12-3
fans589cba4b
Flight distance : 12780633 ft
So I've flown the phantom 4 pro twice in light wind but I keep getting heavy wind warnings. The gimbal keeps twitching and had dropped a few times in flight. Seems to fly very loose and keeping horizon is still an issue. I don't think this gimbal is properly balanced. Leans quite heavily when off to one side when off.
Motors also have a high pitched squeal which my regular phantom 4 does not have.
All night shots are very blurry.  Not quite the tripod advertised.
2016-12-3
isabelle
Flight distance : 1821 ft
Yes same wind problem.
2016-12-4
DRONE-flies-YOU
Flight distance : 1638323 ft
I've got the same wind warning.  I just flew a few minutes ago at 200 feet up.  Trying to fly it back to me AT THAT ALTITUDE not only gave me those warnings (as it did THE ENTIRE FLIGHT) kept giving me obstacle warnings.  It kept stopping every 5 feet, so I put it in SPORT MODE to fly it back to me no problem.  I believe the 2 issues to be related or OA is too aggressive when faced with high contrast scenarios.
The wind warning is set too sensitive, clearly.
My gimbal was twitching like yours, but after doing the "Auto Gimbal Calibration" on a perfectly level surface, THAT ISSUE went away.  Hopefully this helps you, as well.
Don't forget to tap the screen to focus (I keep forgetting).  You just got this new camera, so perfect shots aren't going to happen yet.  I know, because I was expecting that, too, until I thought about "hey, I need to learn how to shoot with THIS camera all over again."
2016-12-4
DRONE-flies-YOU
isabelle Posted at 2016-12-4 14:58
You fixed your IMU 22 code thing?
2016-12-4
isabelle
DRONE-flies-YOU Posted at 2016-12-5 00:12
No I always have the same error code
2016-12-4
Could you please upload some original images to dropbox and send me the link?Please export the flight data via DJI assistant and upload it to dropbox.
2016-12-4
isabelle
Hi
Yes Cardan is in the right place.
2016-12-5
isabelle
No answer for the wind ??
2016-12-5
fans12bc63a7
Flight distance : 44281716 ft
@ken anything on this? It's most annoying.
2016-12-5
Tommy Tenzo
Flight distance : 33051 ft
DJI Mindy Posted at 2016-12-5 01:06
Could you please take a look at the gimbal if it's in the correct place? Here is the screenshot for your reference.[view_image]
If convenient, please provide some videos of this issue. I'll help to check it.
Hey Mindy. I did some test flying today and I'm having the exact same problems as the original poster commented. Gimbal and warnings
2016-12-5
isabelle Posted at 2016-12-6 07:13
Hi isabelle, how high were you flying when you got the high wind warning?
2016-12-5
BrianKushner
DJI Mindy Posted at 2016-12-6 14:31
Hi Mindy I experienced the SAME THING at all altitudes and ZERO WIND...
2016-12-6
isabelle
DJI Mindy Posted at 2016-12-6 07:31
Hi Mindy
yes at all altitudes and ZERO WIND.
2016-12-6
method007
Flight distance : 110449 ft
Yea I just flew mine, getting wind warnings at winds under 4mph (verified).  Also, had a GPS drop out with 15 satellites connected.  Went into ATTI, popped back into GPS about 15 seconds later.
2016-12-6
Please upload the flight data to dropbox and send me the link.
I'll help to report it.
@BrianKushner @isabelle @method007
2016-12-6
Felix777
Flight distance : 71890 ft
Hey Mindy I got the same Problem with the wind warnings and also with obstacle avoidance warnings in a hight where nothing is arround.
2016-12-7
CyFA
Flight distance : 1372369 ft
Cyprus
Yes i also get those warnings although hardly no wind.
2016-12-7
Spacieman
Yeah I was thinking a Dji tech might be on here to help with this wind issue,
2016-12-7
DRONE-flies-YOU
Felix777 Posted at 2016-12-7 05:47
Yep, ditto on ALL of that.  I had trouble getting it back down to me in P-mode because of this.
Doesn't make it non-airworthy, but it is MOST annoying.  Using a P4P+
MAIN CAMERA obstacle detection is too sensitive.  Perhaps it is also tied-in with the wind warnings.
2016-12-7
BrianKushner
DJI Mindy Posted at 2016-12-7 11:50
Hello Mindy
Here is a link to a flight that the wind warning was going off constantly. Calm day.
https://www.dropbox.com/s/lf93gk ... 6-08-21%5D.txt?dl=0
2016-12-7
BrianKushner
method007 Posted at 2016-12-7 10:41
Here's what it looks like oncscreen
2016-12-7
BrianKushner Posted at 2016-12-8 06:36
Hello Mindy
Please upload the flight data as well.
You can use the same method as for the Phantom 4.
Here is a video tutorial for reference:
2016-12-7
Felix777
@DJI Mindy should I upload my flight data too?
2016-12-7
isabelle
Hi mindy
https://www.dropbox.com/home?pre ... -07+08-49-14%5D.DAT
https://www.dropbox.com/home?pre ... -02+12-37-35%5D.DAT
2016-12-7
BrianKushner
DJI Mindy Posted at 2016-12-8 15:19
I gave you flight data in the message before the picture???
2016-12-8
BrianKushner Posted at 2016-12-8 16:27
Hi Brian, there's only flight records in your link instead of the flight data file.
Could you please follow the video tutorial find the flight data?
2016-12-8
isabelle Posted at 2016-12-8 15:32
Hi mindy
https://www.dropbox.com/home?preview=DJI_ASSISTANT_EXPORT_FILE%5B2016-12-07+08-49-14%5D.DAT
Sorry Isabelle, I don't know why your link always link me to my own home page.
I cannot see your flight data files.
2016-12-8
Felix777 Posted at 2016-12-8 15:25
Yes, please upload your data files as well.
Thank you.
2016-12-8
isabelle
DJI Mindy Posted at 2016-12-8 11:01
Hi Mindy
I hope it works
https://www.dropbox.com/s/sc5na6 ... 8-49-14%5D.DAT?dl=0
https://www.dropbox.com/s/67rgt2 ... 2-37-35%5D.DAT?dl=0
2016-12-8
isabelle Posted at 2016-12-8 18:18
Hi Mindy
I hope it works
It finally works.
Thank you for your cooperation.
I'll help to pass your data files to our engineers.
2016-12-8
isabelle
Thank you Mindy
2016-12-8
Neoh
Malaysia
isabelle Posted at 2016-12-5 06:58
I am having this issues of wind warning too even though there was only a slight breeze. Moreover when I tried to use Point Of Interest feature the DJI Go 4 app crash on me with firstly the No Signal & follow by Unfortunately DJI Go has Stop message appear & the app disappear & replaced by the Samsung J7 main menu. Anyone having the same issue?
2016-12-8
agonz
I went out today wind speed was very minimal.....nice day!  Im getting the wind warning as well! I also have a phantom 4 (non pro)that does not get the wind warning.
2016-12-10
BrianKushner
DJI Mindy Posted at 2016-12-8 18:27
It finally works.
Hi Mindy...any word on this. It's a very annoying problem that many are having.
2016-12-15
BrianKushner Posted at 2016-12-16 08:58
Our engineers are working on it.
And could you please upload the flight data files as well?
2016-12-16
fans4c5e3b97
Flight distance : 753163 ft
where does it get the wind info from? the drone or the gps?
2016-12-16
DRONE-flies-YOU
fans4c5e3b97 Posted at 2016-12-16 08:03
The Weather Channel
2016-12-16
fansdc88257a
Same wind warning in light to wind
2016-12-16
fansdc88257a Posted at 2016-12-17 04:51
Hello, could you please upload the flight data to dropbox and send me the link?
Our engineers will help to check it.
2016-12-20
Neoh Posted at 2016-12-8 19:33
Could you please follow the video tutorial and upload the flight data to dropbox and send me the link?
2016-12-20
123Next >
