Litchi & P4P
1707 17 2016-12-11
Rapfife
Flight distance : 160102 ft
Has anybody had any luck using Litchi with DJI Go 4?
I have tried and all it says it "Not Connected".
Any Ideas?
2016-12-11
Jkeller84
Flight distance : 396955 ft
Litchi doesn't "work" with any of the DJI apps. In fact, you never want to use Litchi and DJI GO together. That being said, I hear that DJI has not released the SDK for the P4Pro yet, so 3rd party apps will likely not work with it just yet.
2016-12-11
BrianKushner
Flight distance : 44281716 ft
Won't work until Litchi updates the app.
2016-12-11
djmed
Flight distance : 26266 ft
None of the third party apps like Litchi and other mapping app will work with the P4Pro till DJI releases the updated SDK. Not sure why the delay. I hope it is out soon
2016-12-12
DJI-Ken
Flight distance : 1515312 ft
Jkeller84 Posted at 2016-12-11 21:13
This is correct, you do not want the 2 apps running at the same time.
2016-12-12
Rapfife
DJI-Ken Posted at 2016-12-12 22:10
Litchi will not run without DJI Go installed. they must be communicating somehow? Correct?
2016-12-12
Jkeller84
Rapfife Posted at 2016-12-12 09:40
Incorrect. On one of my iPads, I don't even have DJI Go installed. Just Litchi to prevent any interference
2016-12-12
DJI-Ken
Rapfife Posted at 2016-12-12 07:40
That is not correct, you can have both installed or just the Litchi installed.
Just do not run them at the same time.
2016-12-12
Sky173
Flight distance : 70289 ft
Litchi wont even link up to the controller if DJI is installed. I wish that was fixed because out in the field (in a slow network area like 3G or less), it can take a 1/2 hour to uninstall one app and install another. So switching apps can be unbelievably time consuming. I ended up buying two devices, one with Litchi installed and the other with DJI, and just swap as needed.
2016-12-12
Jkeller84
Sky173 Posted at 2016-12-12 11:22
This is also not correct. You CAN have both of them installed on your device, but you CANNOT have both of them running while flying. In fact, it is very dangerous to do so. As long as you know how to fully close down an app, you can reasonably function with both apps installed.
2016-12-12
Sky173
Jkeller84 Posted at 2016-12-12 11:58
Wish it was so, my friend... I've tried closing everything with no luck (including 'force stop'). I'm rather familiar with Android but for whatever reason, the machines I run the apps on will not run unless only one app is installed at a time. Got some advice? I'm all ears! It's so aggravating.
The one thing i haven't tried is possibly just a simple rename of a file to get things to run. There's some kind of conflict happening that's preventing any one program to run unless the others are deleted...
2016-12-12
Jkeller84
Sky173 Posted at 2016-12-12 12:49
Ahh well that's just an Android limitation then. It's not a problem on iOS.
2016-12-12
Sky173
Must be... wished it were different.
2016-12-12
Punchbuggy
Flight distance : 573054 ft
Jkeller84 Posted at 2016-12-13 04:53
I'll confirm that - that you can have Litchi and DJI GO at the same time. I've even had Litchi and DJI GO on at the same time last weekend. Can't remember why I thought to look at the time, but it's possible nevertheless.
The problem with Android is that it wants to allocate the USB port as default to a specific app; in this case, either Litchi or DJI GO. There is a DJI sticky thread here about resetting Android defaults. Here: http://forum.dji.com/forum.php?m ... D368%26typeid%3D368
2016-12-12
trance728-
Flight distance : 298048 ft
I have Android with Litchi, the old GO app, and the GO 4app installed. When I need to switch to a different one I go to settings, to applications, then to the last one I used with and and hit the clear defaults button. Do force close too if it happens to be running. Then you might just need to replug in the connector and it will ask you which app you want to use.
2016-12-12
JWC P4
Flight distance : 8176 ft
trance728- Posted at 2016-12-13 03:02
100% - this is the correct way to do it!  The other method is to choose "only this time" when you get asked.  It then does not set it as the default.
2016-12-12
BrianKushner
Litchi released beta software today that supports the P4P
2016-12-15
Punchbuggy
BrianKushner Posted at 2016-12-16 11:57
Yes, but what does 'added initial support for P4P' mean? Hopefully it won't be far off till when we can find out what 'initial' means...
2016-12-15
