P4P+ USB, micro-SD, and HDMI ports (here's what they do)
1647 16 2016-12-2
DRONE-flies-YOU
Flight distance : 1638323 ft
The USB 2.0/3.0 (not the micro-USB) is just for storage.  I plugged-in a Galaxy S5 (with DJI GO 4 on it) and the R/C read it like a USB drive.  The R/C auto-switched to "Gallery" and it took a minute with a spinning disk, but all the media on the phone populated on the P4P+ screen.  Cool.
The micro-SD is READ-ONLY and can only be accessed thru the Gallery/Media as I see it.  Basically the same as the USB then.
The micro-USB is for updating.  Haven't had to use this yet.
The HDMI OUT outputs up to 1080p/60.  That's right, the built-in screen P4P+ model's HDMI port can output 1080p/60.  There's a selection to change this to whatever you want (1080/30, 1080/24, 720/60, etc.); given your TV supports said resolutions/framerates.
The entire "port module" is also a fan.  There are several vents on all sides, so if you set this in your lap you 'might' impede the airflow.
2016-12-2
Ethanflux
Flight distance : 450190 ft
I haven't tried this yet.  But won't the MicroSD card also serve as storage for local recorded streamed video while you are also recording on the drones MicroSD?
2016-12-2
DRONE-flies-YOU
P4P+ R/C close-ups
2016-12-2
DRONE-flies-YOU
Ethanflux Posted at 2016-12-2 11:25
I haven't tried this yet.  But won't the MicroSD card also serve as storage for local recorded strea ...
You'd think so, right?  Sadly no.  Check "System Settings" and see "Storage."  There you will see that the SD card NEVER changes available space.
BTW, what's your P4P battery say for maximum capacity?  Mine said 5892 when I got it, and now 5890 since I've flown it/charged a few times.  SO MY P4P battery is GREATER THAN the 5870 advertised!  VERY cool!  lol
2016-12-2
CW Hobbies
How do you like the screen, did you instantly tell it's alot brighter?
2016-12-2
DRONE-flies-YOU
CW Hobbies Posted at 2016-12-2 11:58
OMG dude, YES!  It's the PERFECT screen (well it could be bigger) for THIS APPLICATION.
It's extremely matte, so it soaks up all the reflections - all you see is screen, not yourself & clouds behind you.
It's also super bright AND CLEAR.  The clarity is astounding, even though it's a little small.  I can see the Phantom 5 having a larger built-in screen.
There's also 1 more trick DJI had - SRE.  There's this toggle called SRE in the drop-down notification panel (Android style).  When you tap this, the screen gets EVEN BRIGHTER, lol.  But some of the accuracy is lost and some stuff looks slightly blown out.  So it's a toggle for desperate direct, bright sunlight moments.
2016-12-2
DRONE-flies-YOU
OH, and the latency...  THERE IS NONE (well it feels like it).
It feels like no latency even at distance!  So this isn't just right up by me, this is far away, too!  It INSTANTLY responds to my commands.
2016-12-2
DJI-Ken
Flight distance : 1515312 ft
DRONE-flies-YOU Posted at 2016-12-2 13:11
It's extr ...
Yes indeed the screen is extremely bright out in direct sunlight.
I could not believe how well I could see the screen when I had my back to the sun and the sun directly in the screen.
2016-12-2
CW Hobbies
DRONE-flies-YOU Posted at 2016-12-2 15:13
It feels like no latency even at dis ...
Awesome, Thanks for info.
Looking forward to see some video's.
2016-12-2
DRONE-flies-YOU
Just used the HDMI out again.  I was getting no tapping sounds or voice prompts from the R/C like usual.  I then realized the TV volume was turned way down.  Turned it up & THERE WAS THE SOUND!  Cool, so the HDMI out on the P4P+ GL300E R/C also OUTPUTS AUDIO (didn't test OR CARE if it was stereo or mono).
2016-12-5
Zatx
Flight distance : 158166 ft
Is there an obvious way that monitor/arm combo can come off to upgrade to the Crystalsky monitors when they become available? I'd like to purchase the P4P+, but don't want to have to replace the controller et. all just to upgrade to the larger Cystalsky when it hits the streets.
2016-12-6
DRONE-flies-YOU
Zatx Posted at 2016-12-6 04:39
No.  It looks like it is bezeled into the R/C a little.  It'd look like garbage if you ripped that off.
Just get a GL300F later-on.  There's always eBay for your GL300E (the built-in screen).
2016-12-6
Tsavo
Flight distance : 129203 ft
DRONE-flies-YOU Posted at 2016-12-2 10:33
You'd think so, right?  Sadly no.  Check "System Settings" and see "Storage."  There you will see that the SD card NEVER changes availabe space.
Mine is now showing 6004 milliamps max capacity?
2016-12-19
DRONE-flies-YOU
Tsavo Posted at 2016-12-19 20:51
Yep, I believe they are all about 6000mAh batteries.  This is why it is easy getting the 30 minutes.
2016-12-19
multirotorrd.co
Flight distance : 6176932 ft
Dominican Republic
It sure is output hdmi 1080p-60 With my phantom 4 pro with the hdmi port i have 720-60
2016-12-19
DRONE-flies-YOU
multirotorrd.co Posted at 2016-12-19 21:12
Be sure to connect to an HDMI device capable of 1080p/60 -or- be sure to have your resolution (on your device/TV) set to NATIVE, if possible.
I had 1080p/60 on several televisions with different technologies.
2016-12-19
Telrin
Flight distance : 29767 ft
DRONE-flies-YOU Posted at 2016-12-5 17:19
That is good and I suppose to be expected with HDMI, but is it optional?
If you are using the HDMI out to go to a monitor or to feed other recording or retransmission equipment it is going to be a bit annoying to lose your audio feedback from the controller...
2016-12-20
