colonel00
DJI-Ken Posted at 2016-12-20 15:55
It is still there, (aircraft can be on or off)
From the Gimbal Settings, choose Advanced, then Gimbal Pitch EXP.
The Smoothness is the reaction when you let go or stop the wheel. You probably want some smoothness so when filming if you let go of the wheel or stop it, it makes a ease to stop movement instead of a abrupt stop.
That's interesting. With Go 4 on a Note 3 (approved device) I can only get into the camera settings when everything is powered on. For me it's:
Main Menu -> Gimbal Settings -> Advanced Settings...
From there I don't have EXP or smoothness. I have Gimbal Speed, Gimbal Tilt Limit, Gimbal Pan Synchronous Follow, and Gimbal Start/Stop Buffer
I've figured out what these are and how the correlate to what I've seen posted like what you describe but it sure would make things a lot easier if the menus and settings were named the same thing across platforms.
