Mavic forced landing???
5939 51 2016-12-21
R&L Aerial
Flight distance : 298100 ft
I noticed the last few flights with mavic when ever I pull the throttle back to drop altitude a red x appears on left of screen and it starts to automatically land??? Also while hovering about 200 feet the mavic starts to climb with no stick input, it went from 200 feet up to 400 on its own when I finally brought it home. Any suggestions would be appreciated.
2016-12-21
Wes1977
Flight distance : 363862 ft
first thing I would do is replay your flight on the dji go app watching the altitude and your throttle positions to see if it is a controller or mavic issue.
2016-12-21
Is firmwear up to date, did you do a stick calibration?
2016-12-21
Could you please clarify your current firmware version? Please sync your flight records and provide me with your DJI account email. I'll help to check it.
Is your DJI account email the same as your forum email?
2016-12-22
R&L Aerial
hallmark007 Posted at 2016-12-21 15:19
Firmware up to date, I will try the stick calibration.
2016-12-22
Nees
Flight distance : 80991 ft
R&L Aerial  Posted at 2016-12-22 12:36
Screenrecord your flysession with stickoverlay and show us to learn.
2016-12-22
FlameBoy
Flight distance : 105558 ft
I'm having same issues
http://forum.dji.com/thread-77251-1-1.html
2016-12-22
Danny-B-
Flight distance : 306640 ft
Check the Camera and Sonar sensors on the bottom of the mavic, might be along shot but it sounds like its somehow wrongly detecting the ground.
2016-12-22
WilliamDJI
Flight distance : 319514 ft
Danny-B- Posted at 2016-12-22 09:08
I have the same issue and believe this is the problem
I tried VPS calib and that doesn't help...
About to try a factory reset ... will keep you updated
2016-12-24
braddahjosh808
Flight distance : 1868376 ft
DJI Mindy Posted at 2016-12-21 22:12
DJI Mindy,
I just created a new thread about this yesterday and no one has gotten back to me. My mavic started a force landing with 9 minutes of battery left and I couldn't do anything to cancel it. There were no warnings or low battery indicators. I almost lost my drone! This happened when I switched to using the DJI GO 4 app. Prior to this I had 58 flights on the original DJI GO app and no issues.
Here is the link to my thread. http://forum.dji.com/thread-77435-1-1.html
Could someone please take a look at my flight logs?
http://healthydrones.com/main?share=dMzlIS
It shows that a force landing was initiated but WHY???
2016-12-24
colonel00
Curious, why was it recording your altitude over 500ft?
2016-12-24
braddahjosh808
colonel00 Posted at 2016-12-24 13:03
I was flying at 500ft
2016-12-24
WilliamDJI
braddahjosh808 Posted at 2016-12-24 15:38
DJI Mindy,
Force landing = you holding the down stick at a 100% for a few seconds
Also as an update - factory reset does not solve this issue
2016-12-25
WilliamDJI
Danny you are right -
I carefully paid attention to my VPS - the Mavic will start ascending without input and refuse descend commands when the VPS displays 0.1 out of nowhere (20 meters off the ground) - when the reading is normal again, it allows me to start descending for a few seconds before changing back once again.
2016-12-25
JegerLars
Flight distance : 3773 ft
I have the exact same issue! Nearly lost my drone over a highway. What idiotic system is this? I do not want to start a landing 100 m above ground! Any updates?
2016-12-25
JegerLars
I tried doing a bit of troubleshooting, and what I noticed is that the problem seems to be somewhat less in sport mode. In terms of holding down the stick, it seems to me that the drone in normal mode doesn't seem to descend, it's either forced landing or no descent at all. Regardless of how careful I am tilting the left stick. I've also checked and there's no foreign objects or damage to the bottom sensors. The drone just simply won't descend it goes into full forced landing....
2016-12-25
Delsonrus
Flight distance : 4096877 ft
JegerLars Posted at 2016-12-25 09:00
The same problem here. In sport mode it's a little bit more stable and not ascending by itself as fast as in regular mode. But still, I can't land it normally without using auto land mode.
Today I checked VPS sensors at home by slowly lifting the drone from the floor and while I was doing it VPS showed strange clearance -- it slowly went from 0.3ft up to 1.9ft and then dropped to 1.3ft while I was still lifting it up.
2016-12-25
JegerLars
A temporary fix could be to maybe turn off the VPS sensors - but won't the drone be potentially unstable? Has there been any official statement by DJI on this bug?
2016-12-25
Jan_Leh
Flight distance : 3333 ft
JegerLars Posted at 2016-12-25 17:40
I had the same issue with my Mavic and constant forced auto landings even in high altitudes above 50m.
I disabled the VPS sensors last days, the problem (seems) to stop and the Mavic is behaving (decending) normally. However, would be great to know why the VPS sensors leads to such errors. I dont buy a drone for 1200€ and i cant use all sensors, its a big joke..,
Does anyone get any help from DJI site, telling us what is the matter in this case? Several Mavic pilots seems to have this same issue with forced landings...
2016-12-25
JegerLars
Jan_Leh - how does the drone behave in the air without VPS in terms of overall performance - can the machine be used almost normally without them?
2016-12-25
braddahjosh808
WilliamDJI Posted at 2016-12-25 22:43
I was fly at 500ft above he ground and was trying to descend when it initiated a force landing. I've never had this happen to me before.
2016-12-25
Danny-B-
You guys deffo have faulty VPS sensors (most likely the sonar) disabling the VPS will stop the issue, but at the risk collision from not being able to detect obstables .... they need to bed RMA'd i'd say.
Take a quick video of the drones (indoors no motors running) the video will pickup the sonar clicks beter than human hearing .. but in any case, i think you have faulty mavics.
2016-12-25
braddahjosh808 Posted at 2016-12-25 04:38
DJI Mindy,
I have replied you on your thread.
Please upload the flight data. Our engineers will help to review it.
2016-12-25
JegerLars
Can confirm, turning off the VPS allows more normal flight characteristics. Anyone tried calibrating the VPS via DJI assistant? I live in Norway, would hate to send the drone all the way to China if not absolutely necessary...
2016-12-26
MarcusPolus
wow, that probably isnt good, espesially the 200 ft climb
2016-12-26
MarcusPolus
maybe a bug flew under it? would that trigger climb? but 200 ft climb?? a little excessive I think
2016-12-26
MarcusPolus
Jan_Leh Posted at 2016-12-25 13:10
I would think that is a big issue, I hope DJI comes up with something
2016-12-26
JegerLars
Delsonrus Posted at 2016-12-25 17:30
Delsonrus - how did calibrating the VPS with DJI assistant turn out?
2016-12-26
WilliamDJI
JegerLars Posted at 2016-12-26 14:00
I tried that and it didn't help a bit
2016-12-26
Buzzyone
Flight distance : 4647913 ft
WilliamDJI Posted at 2016-12-26 23:08
I had a phantom 3 Pro that did this unstable flight, where it would climb even though not commanded to do so, the vps indicated it was descending but in fact it would climb. Replaced the VPS unit and the problem went away.
Looks like you have a faulty drone(s)  so sadly it's RMA time.
2016-12-26
Delsonrus
JegerLars Posted at 2016-12-26 13:00
I had just one flight today during which none of the symptoms showed up. I will try flying more later this week to make sure calibrating VPS actually helped
2016-12-26
fans7fc79ecf
Flight distance : 126778 ft
I have the same problem at 200 mt
2016-12-29
R&L Aerial
Delsonrus Posted at 2016-12-26 18:22
Same here, every time I think the issue has resolved, it comes back to haunt me.
2016-12-30
JegerLars
Japan
Happy new year everyone!
I did a recalibrate of the VPS sensors (fore and below) and did a test flight today. Normal mode.
The "upwards autodrift/forced autolanding glitch" happened - the drone drifted upwards right into some pine-trees and naturally crashed spectacularly.
So what now DJI? I´ve tried troubleshooting but the drone (if still flyable) is a hazard.
RMA time?
Thanks for any help!
2017-1-1
fans707604b2
Flight distance : 51066 ft
Calibrating the VPS sensors didn't make any difference for me, and the mavic still tried to land whenever the left stick was pushed down.  The main symptom that shows up on the controller is the ground clearance value is completely wrong.  I notice that initially when ascending after take off, the clearance is shown incrementing up as expected.  Eventually though when the craft gets to about 20m, it suddenly starts registering ~0.1m.  At this point, whenever any attempt to descend is registered on the controller, the mavic overrides because it thinks it is in close proximity to the ground and starts to auto land.
Using RTH also triggers this issue for me.  After starting a RTH, the mavic returns to it's starting location, and then I see a message on the controller saying that altitude is below 0.5m and confirm that I want to continue landing.  When this message is displayed, the craft is 30m in the air, altitude is shown as 30m, but clearance is showing 0.1m.
I hope this is just a firmware bug rather than a sensor issue, and the fact that many people are reporting it recently does seem to indicate this is likely.
2017-1-1
Delsonrus
So today I had my second flight after recalibrating VPS and the problem returned. All the symptoms were the same -- drone drifted upwards by itself. The only thing which helped was disabling VPS.
DJI Mindy: I've synchronized my flights and my email is the same as here, could you please look in to my latest flight? The bad thing happened on 2nd minute of the flight, where drone ascended from 130 ft up to 300ft without any input on the stick. After than I disabled VPS. Thanks!Correction: for some reason my latest flight doesn't want to synchronize, so you can see the same behaviour on last uploaded flight (Dec 24, 2016) starting from 2nd minute.
2017-1-1
braddahjosh808
Can someone point me to the directions to calibrate the VPS?
Thanks!
2017-1-1
rnrnrn
Flight distance : 430932 ft
One thing for note to all - I just checked my flight records on healthy drones and... most landings are "Mode changed to FORCE LANDING". When I hover the craft and then apply the stick down the craft stops about half a meter in the air and only after awhile goes down again and lands and then when I keep the stick down the engines stop. I do fly with VPS on and had not had the problems you all are talking about (but also I haven't flown that much due to the weather) but the notification itself is a bit off. Maybe the software should be adjusted a bit for that. I do have the latest firmware and latest DJI Go 4 app.
One other thing - do you guys have the options for moving up and back in the VPS switched on? I did look at those options and decided to leave them alone - I'd rather the drone stop in front of the obstruction and hover as opposed to going backwards - in case of a bird or a dirty VPS camera this could become an problem rather quickly. Just my two cents here.
2017-1-1
fansbcbcf80d
Flight distance : 2443947 ft
Ok! Same thing happened with me today!
Here is the flight log http://healthydrones.com/main?share=QxZhDd
Please do something. Force landing midair is not the good idea!
2017-1-13
JegerLars
Japan
So did 3 VPS calibrations, one IMU calibration and one stick calibration. Went for a test flight today. Excellent weather, sunlight, midday. VPS should be thriving.
Hovers 50 meters above ground (height registers correctly), bird tells me I have 0,0-0,5 to maybe 1-2 meters (ground) clearance - and the value flickers, as if the sensors are all jittery. Appropriately, whenever I tried to descend, the craft would start autolanding, because naturally, it believes it is just above ground.
So to bring it down, I disabled VPS and precision landing. It now flies ok. Sure, it has no clue of what ground clearance it has, but I can compensate by piloting more aware etc.
So Ive concluded that currently, the VPS is just a hazard, it serves no purpose and makes it impossible to bring the craft down.
What to do?  Wait for a software update or RMA? Or just ignore the VPS as some failed experimental sensor and fly on without it?
2017-1-14
