Hi efficiency Propelers
1192 8 2016-12-31
fansa5e1fb66
Is There any Hi efficiency Propelers avelable for the Mavic, That will give better flitimes and or Prformece then the stock propelers.
2016-12-31
KerryG
Flight distance : 11736709 ft
No. The stock ones are pretty efficient already.
2016-12-31
Bent Kangaroo
Flight distance : 362510 ft
When your mavic sinks in a lagoon because of your after-market and non qualified props that fail, do you expect warranty from DJI?
2016-12-31
vashon100
Flight distance : 1671864 ft
I hanvet nees yna.   LOL
2016-12-31
fansa5e1fb66
Bent Kangaroo Posted at 2016-12-31 20:49
I Think the warranty is over rated in mini ways. What are you going to do if your Mavic flies away.
There are good aftermarket companies out there that make top quality products, as well there are bad companies.
When you find something that looks good do some research on it.
2017-1-1
Tharg (from the
Flight distance : 120784 ft
Exactly what length and chord are you looking for?
How are you calculating efficiency? RPM per volt under load and what have you worked out for thrust per corner on the stock props on a 3cell at 50% throttle?
2017-1-1
Be surprised if you will get high efficiency props, maybe ones with go faster stripes, lol
2017-1-1
damaltor
hallmark007 Posted at 2017-1-1 11:50
Yeah, I'd like some with faster stripes!!  hohoho
2017-1-1
ocelot27
Flight distance : 1163894 ft
damaltor Posted at 2017-1-1 13:07
I highly doubt any aftermarket company has the $$$, instrumentation, engineering staff etc etc etc to make something better than DJI has - you don't think that the primary design criterion for the stock props was efficiency???
2017-1-1
